I made some 40 stainless retaining plate shims. Have a look.
Page: Previous  1, 2, 3
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Fri Apr 10, 2015 3:11 pm    Post subject: Reply with quote
[email protected] wrote:
I got my shim set today. what a joke.
I saw that post take a drastically different direction in my head. They MUST be good! Cool
Summer (and fall, and winter practically,) Tour is wrapping up. Now booking Fall/Winter lessons in Southern California!
www.airschooled.com/learn-to-fix-your-volkswagen
[email protected]
Samba Peckerhead
PostPosted: Fri Apr 10, 2015 5:39 pm    Post subject: Reply with quote
they are better than good. not only are they so pretty you want to put them in plain view and THEY WORK and fit perfectly .
I am glad to have had the opportunity to purchase a set. it's nice that he was able to offer them at such a good price.
as I said, I will but more if he had anyone flake out on him and he has a pile laying around.
I just wanted to get everyone's attention Very Happy I seem to be pretty good at that
Jake Raby wrote:
Brian wrote:
ChipWrecked
ChipWrecked is offline
PostPosted: Sat Apr 18, 2015 8:37 pm    Post subject: Reply with quote
Thank you for the kind review. I'm glad they're meeting the need.
[email protected]
Samba Peckerhead
PostPosted: Sun Apr 19, 2015 5:54 am    Post subject: Reply with quote
thank you for making them. I hope you didn't have a bunch of people flake out on you
Jake Raby wrote:
Brian wrote:
curtis4085
curtis4085 is offline
PostPosted: Sun Apr 19, 2015 7:03 am    Post subject: Reply with quote
Just bought me a set!!
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
obx71super
obx71super is offline
PostPosted: Fri May 01, 2015 9:52 am    Post subject: Reply with quote
Haven't used mine yet, but skills is right these things are purty! I'd be down to buy another set of need be! Also thanks from me as well, love buying quality, much appreciated!👍👌🍻
71 super auto stick basically original minus a couple resprays
73 Westy automatic with a 2 liter gex, soon to be a 1.8 liter Headflow masters
Newest Addition!! Solid straight 74 thing totally disassembled!! YEEEWWWW
ChipWrecked
PostPosted: Fri May 08, 2015 5:04 pm    Post subject: A new direction Reply with quote
A few packs of shims remain... If anyone is interested.
Now I'm threadjacking my own thread...
I'm having a new need, and in turn possibly a new product.
I was able to procure a NOS heat shield for my 72'. It's so off-the-shelf perfect that I'm reluctant to use it on my planned daily driver. So, instead of bolting it up, I took caliper measurements to make a few in stainless steel.
316L stainless in 0.030" (22g) for the body, and 18g for the hangers. The benefit of this type of SS is it's lower thermal conductance, high resistance to oxidation and chemicals (road salt), and most importantly - it's super sparkly shiny. Razz
Now, the originals were internally lined with woven chrysotile, just like our late bay heat exchangers.
Since asbestos liner is out of the equation, I am leaning towards woven fiberglass blanket (like header wrap). The glass will be sandwiched b/w two SS sheets like the NOS design. I'll spot weld the hangers and then crimp the edges - which should be much better than the cheesy aftermarket ones that are out there. I am also tempted to replicate the bead roll that the OEM has. This adds rigidity I presume to keep the shield from flexing? But is it really necessary? The aftermarket ones lack this from what I can see.
More to come later...
1975 Kombi
1975 Kombi is offline
PostPosted: Fri May 08, 2015 6:07 pm    Post subject: Reply with quote
I'm guessing as long as there is a space between the two sheets life is good. So anything that can withstand the heat and not react with the stainless would be a good choice.
Brett
Hes decieving you boy! Reach into his pocket and take what hes got. Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Peace: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v
Tcash
Tcash is offline
PostPosted: Fri May 08, 2015 7:55 pm    Post subject: Reply with quote
Material for the heat exchangers where discussed in this thread.
http://www.thesamba.com/vw/forum/viewtopic.php?p=7460708#7460708
Good Luck
Tcash
[email protected]
Samba Peckerhead
PostPosted: Fri May 08, 2015 8:43 pm    Post subject: Re: A new direction Reply with quote
that is the most important part! if it's anything like the shims, you will make yet another quality product!
Jake Raby wrote:
Brian wrote:
raygreenwood
raygreenwood is offline
PostPosted: Sat May 09, 2015 11:10 am    Post subject: Reply with quote
Also...as far as heat shields go......as one mentioned....having space between the panels is key.
In that respect....the fiberglass or rock wool (which is also excellent for this use) http://www.energyauditingblog.com/what-is-mineral-wool-rock-wool/
...is a good heat barrier and also a sound deadener because all of the little spaces inside the wool or fiberglass matting are zillions of little spaces where sound can bounce around until energy is spent (sound trap).
In that same vein.....getting something that creates both a spacer between the upper and lower parts of the shield....which helps to block heat....and arrests sound....can be done almost as well with expanded metal grid/sheet like this
https://www.google.com/search?q=galvanized+expande...B800%3B600
Another method that is used on many catalytic converter heat shields and downpipe manifold heat shields is to dimple one surface...top or bottom.....in a geometric pattern and and use a handful of those dimples...with a hole drilled through the sheet...as spot weld locations. The dimpled areas acct as heat reflectors as well and subdivides the inside area into zones.
This makes a superbly rigid triangulated construction that actually allows the use of thinner, lighter sheet on one side...is much more rigid than just two flat sheets welded together at the edges.....and in many cases allows actually leaving the outer perimeter edges open so that heat can flow through or out of the edges. It actually makes for a much better heat shield because its more difficult to saturate with heat all the way through because it has a method of dumping heat.
This is a product that works by this exact concept
http://www.verociousmotorsports.com/Shop-by-Brand/...ield-4-Ply
Something to think about. Ray
ChipWrecked
PostPosted: Sat Dec 03, 2016 12:19 pm    Post subject: Re: I made some 40 stainless retaining plate shims. Have a look. Reply with quote
At the request of several members, more retaining plates have been made.
I can't recall all of the members that requested them, otherwise I would have PM'd you directly. This might come across as a shameless plug, but that's not really my style. Mods feel free to nuke this if it's sketchy. No worries.
http://www.thesamba.com/vw/classifieds/detail.php?id=1995576
"You're too retarded for a retard." Amskeptic
VWRICK69
VWRICK69 is offline
PostPosted: Thu Sep 28, 2017 4:15 am    Post subject: Re: I made some 40 stainless retaining plate shims. Have a look. Reply with quote
I might have missed it, but do these fit the 71-72 or 73-79? Is there a difference. Are these still available? Thanks Rick
1969 CREWCAB and UHAUL camper
Page 3 of 3
