bustedtype2 Samba Member
Joined: May 07, 2005 Posts: 417 Location: The arm pit of california
Posted: Fri Aug 23, 2013 9:15 pm Post subject: My 60 convert won't start?? Help please. |
I have a 1960 convertible bug. Still all original and running a 6 volt system a few months ago my battery seemed to be getting weak. I replaced the battery and was able to drive it. Now I get in it and I have no power. I replaced the battery agin and now all my electric works but it won't turn over I get nothing. I replace the egnition and starter also replace the positive and negative battery cables. Still nothing not a sound when I turn the key completely dead.
I want to take it to bug o Rama please any ideas?
The battery is new!!
I am a bus guy so I am not framilyer with the bug. I am only seeing 4 fuses for lights. Is their more? _________________ Gas, Grass or Ass ? No one rides to the show for free!! |
zabo Samba Member
Posted: Sat Aug 24, 2013 4:27 am Post subject: |
double check your starter wiring, ground strap from trans to chassis, also check your headlight switch connections.
theres 8 fuses- 4 by speedo to 4 left of gas tank. _________________ 1960 6 volt sedan- 1978 adventurewagen
–wanted bill spreen atlanta dealer tag frame |
Posted: Sat Aug 24, 2013 6:21 am Post subject: |
Why the headlight switch connections? I will check for the other fuses when I get home. Do those fuses conect to the eng?
Thanks for the help _________________ Gas, Grass or Ass ? No one rides to the show for free!! |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Sat Aug 24, 2013 6:47 am Post subject: |
The power comes from the battery to the headlamp switch, then to the fuse box and ignition switch. A dirty contact on the headlamp switch terminal can mess up your whole car. |
Posted: Mon Aug 26, 2013 9:03 pm Post subject: |
Ok I found the fues by the gas tank. It seems someone painted over the fues box and fuses. I changed the fuses out and removed the paint from the terminals. I got all the lights working but still won't start or even want to turn over. I checked the Trans strap and head light switch. All complete. Anything else I can try.
Help 6 days until Sac!!! _________________ Gas, Grass or Ass ? No one rides to the show for free!! |
phatdawg Samba Member
Joined: November 16, 2004 Posts: 189 Location: Eureka CA
Posted: Mon Aug 26, 2013 9:12 pm Post subject: |
bustedtype2 wrote: |
Help 6 days until Sac!!! |
You need to trace the power. Maybe start at the starter and work back. Might help to have someone try and start it while you check with a voltmeter. Here is a 1960 pic from the samba.
http://www.thesamba.com/vw/archives/info/wiring/feb60busfuses.jpg _________________ -1966 T1 2-tone W/1915 cc
-1965 T1 Project car. Have had for 25 years.
-2000 Jetta VR6. Black and Quick! (GONE)
-2010 Jetta TDI. White and sips fuel.
The older I get the beter I was!!
http://www.thebugshop.org/gotech.htm
http://www.wolfsburgwest.com/ |
Posted: Mon Aug 26, 2013 9:22 pm Post subject: |
Thanks will give it a try. _________________ Gas, Grass or Ass ? No one rides to the show for free!! |
grandpa pete Samba Member
