Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Aug 26, 2013 3:47 pm Post subject: Thicker Valve Cover Gaskets for Type 4 Engines |
has anyone ever used these before?
http://shop.914rubber.com/914-Valve-cover-gaskets-Improved-to-stop-oil-leaks-914VCG2.htm
my 72 has a 914 style motor in it with the upper filler neck and dipstick, and a 914 friend turned me on to this site. i have replaced the gaskets, 3 times, and used sealer, but it just wont quit leaking. so i ordered some and will report back, but curious if anyone has thoughts.
theres also an oil tower gasket (upper breather box) thats slightly thicker for the same reason...i got one of those also. thoughts on that? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
wny72westy Samba Member
Posted: Mon Aug 26, 2013 4:17 pm Post subject: |
I need a new set of valve cover gaskets for my upcoming valve adjustment. I think I may give these a go.
I suspect that new, true valve covers wouldn't need thicker gaskets, but if these do the job, that is certainly cheaper than replacing the valve covers any time they get tweaked. _________________ 1972 westfalia: 1700cc, l-jet, bfg all-terrains; a constant work in progress
1987 BMW 325: 2.7, DD/autocross/ice-race; "gods chariot"
1997 miata: autocross, cruiser; I keep meaning to sell it, but its too much fun. |
SGKent Samba Member
Posted: Mon Aug 26, 2013 4:54 pm Post subject: |
valve covers get tweaked taking them on and off and eventually they are like a table with uneven legs. One corner leaks. You have to put them on the head without a gasket, rock them, and figure which way they are tweaked to untweak them. Also old stock gaskets get harder over time and don't seal as well when the cover has a little tweak in it. T4 covers are worse for doing this than T1 covers because of the size. I had a tiny leak that would not go away and finally figured out what was going on. I've thought about picking up a junk head just to check the covers before installing them. |
Posted: Mon Aug 26, 2013 4:56 pm Post subject: |
ill try that tocking trick, but i know that if i can pull the bails on by hand, with minimal effort, i have a problem. ill also see about getting some different bales from ken at the busco too, but the gaskets are already on their way. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Aug 26, 2013 6:40 pm Post subject: |
The bales are not hard to rebend a little tighter, but wear safety glasses, throw a towel over them and do it in a vise as they can get nasty if they get loose mid tweak. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Mon Aug 26, 2013 10:27 pm Post subject: |
tootype2crazy wrote: |
Get some from these people and you won't have to buy valve cover gaskets for a long, long time. http://www.realgaskets.com/ |
cept those say they fit all 4 cylinder engines.....type 4 and type 1 engines are different....
i was going to try and bend the bales also, but the gaskets are already ordered and on their way. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
airschooled Air-Schooled
Posted: Mon Aug 26, 2013 10:40 pm Post subject: |
Stuartzickefoose wrote: |
Porsche 914 Type4 gaskets from the same site
[img]http://www.realgaskets.com/files/popups/popup67.htm[/img]
Gotta get creative with that there computer _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
Posted: Mon Aug 26, 2013 10:47 pm Post subject: |
Read the whole catalog. They make good parts. |
ned Samba Member
Posted: Tue Aug 27, 2013 12:01 am Post subject: |
asiab3 wrote: |
Gotta get creative with that there computer |
after all that i totally didnt even think to look those up as a 914 gasket...
i have tried the rubber gaskets before and they sucked.....i have NOT tried silicone. maybe ill try a set for my bus later on down the line? who knows. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Tue Aug 27, 2013 5:42 am Post subject: |
I run them and they are kosher. I have hydraulic lifters so the covers don't come off often, however I think for those with solid lifters they would be real nice because you wouldn't have to replace your seals every time you adjust the valves. A real cost savings over time. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
kamara Samba Member
Joined: January 27, 2008 Posts: 142 Location: Tallahasee, Fl.
Posted: Tue Aug 27, 2013 8:12 pm Post subject: |
Nice find! I am going to try them out.... _________________ "Spirit is the journey - body is the bus
I am the driver - from dust to dust." J. Clegg
- President of CCvdub (Tallahassee's VW Club)
([email protected])
73 Type2 Riviera, 74 Type2 Westy, 69 Type1 Standard, 72 Type4 412 Variant |
Francoc Samba Member
Posted: Fri Oct 19, 2018 12:36 pm Post subject: |
I know this is an old thread, but I just bought the Porsche 914 gaskets from that site and I’m happy with them. Thank you for the recommendation. |
Posted: Wed Oct 24, 2018 8:44 pm Post subject: Re: Thicker Valve Cover Gaskets for Type 4 Engines |
Just got a set of Porsche/Type 4 gaskets in the mail today, part # RG-914-S. Inexplicably they also list "361, 383, 400, 413, 440" which are Chrysler R and RB engines.
I would like to note that they say to install the gasket dry after cleaning the surface with solvent. When reused the gaskets need to be washed in hot soapy water. The gaskets seem thin so the bales may need to be bent a bit. |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Oct 24, 2018 9:09 pm Post subject: Re: Thicker Valve Cover Gaskets for Type 4 Engines |
Wildthings wrote: |
Size them up next to a new cork set.
Ones bails may need bending (bench vise) to get them taunt. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Manfreds78bay Samba Member
Posted: Wed May 15, 2019 10:01 am Post subject: |
kamara wrote: |
Nice find! I am going to try them out.... |
I bought a set of these based on the reviews on this thread. I've been trying to solve a valve cover leak.
They did work, but it ended up being a bale issue. When I took them out for testing purposes and only having put maybe 100 miles on them, there were chucks missing from the gasket. It looks like bite marks along the top ridge of the lower part of the gasket if that makes sense. I think I will trim them down a bit next time put them in. They were probably rubbing on my rocker arms.
Also, the heat seems to make these things expand. When I tried to pop them back in while warm they would not fit back in to the valve cover. After I let them sit over night they seem to fit in fine. _________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
SGKent Samba Member
Posted: Wed May 15, 2019 10:17 am Post subject: Re: Thicker Valve Cover Gaskets for Type 4 Engines |
I have posted on this before. If the valve cover is warped no gasket will seal, especially the thinner ones. The fix is to fit the cover to the head with no gasket and re-tweak it so it no longer rocks. Then it will seal fine most of the time even with the thinner cork gaskets. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
