Hatracks Samba Member
Joined: July 10, 2016 Posts: 660 Location: Renton, WA
Posted: Mon Oct 03, 2016 9:19 pm Post subject: Re: '75 UK 1303 Build Thread |
I cant believe you saved that door, I thought I jumped in on projects but man you are deep on saving that thing. I feel like a butcher after reading through your thread _________________ 73 Super Build |
Dodgy Samba Member
Joined: January 30, 2006 Posts: 517 Location: Leicester, UK
Meiang Samba Member
Joined: September 27, 2016 Posts: 656 Location: Perth, Western Australia
Posted: Fri Oct 07, 2016 5:38 am Post subject: Re: '75 UK 1303 Build Thread |
I can't believe the rust in the car that you have removed.
My 1968 1500 Beetle is rust free after 48 years.
Even my 1973 Alfa Romeo Giulia Super 1.3 (not known for being rust free and came from a tropical climate) never had that much rust.
My hand goes out to you for the effort that you have put in - seriously good |
Dodgy Samba Member
Posted: Sat Oct 15, 2016 11:22 am Post subject: Re: '75 UK 1303 Build Thread |
I’m hating bodywork already... The cutting / welding bit is OK, but sanding and prepping for paint is just tedious...
Anyway, I’ve got the front RH inner wing sanded back to a good key, temporary primer previously applied has been sanded back, all original seam sealer removed to check no nasty surprises (there weren’t any, just a few small areas needed sanding / blasting to get rid of surface rust)
New seam sealer applied
Etch primer and standard primer sprayed on
The whole inner wing will be sprayed with stone chip, not sure if it’s worth doing one quarter at a time. But seeing some parts change colour and look ‘finished’ is a good motivator!
As a distraction from tedious bodywork I’ve started to play with the Porsche front suspension... I’ve posted details of this here: Porsche 944 Brake conversion on 1303
I’m sort of swapping between the bodywork and the suspension depending on time / budget and inclination, but either way, slow progress is being made! _________________ '75 1303 (current project) owned since 1989!
'72 Squareback - full resto completed 2008 - now sold
356 Speedster kit, completed 2005 - now sold |
jerrybromley Samba Member
Joined: August 06, 2016 Posts: 124 Location: Michigan
Posted: Sun Dec 04, 2016 9:11 am Post subject: Re: '75 UK 1303 Build Thread |
Thanks for all the great photos these will be of GREAT assistance on my project ! |
Dodgy Samba Member
260KMN Samba Member
Joined: January 17, 2014 Posts: 236 Location: Devon UK
Posted: Fri Mar 24, 2017 3:24 pm Post subject: Re: '75 UK 1303 Build Thread |
Just read through this, i went through similar deliberations when building my 03 cab back in 2000, Originally i was going to run 944 early front stub axles with the full early 944 front brake set up and 6x16 Fuch wheels, cant recall the offset.
Assembled it all on the car and then widened a pair of steel front wings to cover the resulting wideness.
car went for paint and only then did i realise it was too wide at the front, so rethink required.
I eventually went back to modified 03S front stubs, kersher struts and early 944 calipers on Kersher vented discs with 7.5x17 et 52 MM Cup 2 replicas under stock front wings.
Wideness
Front end after mind change
For the rear i stuck to my guns even after a wheel change.
Originally 6x16 Fuchs with early 944 brakes using steel 944 diagonal arms and spring plates.
Not much track width change, but then the wheel change came in, same as fronts.
The original idea required a wing wider than stock so i widened a pair of steel ones 30mm, after the wheel change there was one issue.
The wheels stuck out, so i narrowed the diagonals a bit about 10 mm. Using stock 1303 drive shafts it all works.Done about 15k miles and all seems ok.
So my car runs 944 early front calipers on stock spindles with kersher discs and struts and 7.5 x17 rims under stock wings.
Rear has stock early 944 complete brake set up with slightly narrowed steel 944 diagonal arms, same rims as front but under 30mm wider steel wings.
heres how it looks
I dont suppose this is of any use but its what i did and it seems to work, even after 10 years on the road.
These guys who run 4 and 6 pot calipers make me chuckle, my car has a CSP master cylinder and i can lock the wheels easily so the early 944 calipers are fine for road use as far as i am concerned.
good luck,
Paul |
Dodgy Samba Member
Posted: Sat Mar 25, 2017 11:39 am Post subject: Re: '75 UK 1303 Build Thread |
That's a cool car! (and kudos for your Notchback thread in the Type 3 forum... I miss my Squareback!)
Thanks for the info, I'm happy with some moderate widening but not if it looks too extreme. I now have a 'flat' 944 rear hub to try, just have to get the Porsche rear hub nut undone first...
Looks like this will reduce the rear projection by ~30mm, and front & rear will fit under +4cm wings with space to spare.
Weird:
Cool:
Yeah the 4/6-pot calipers are more for looks than anything else. The VW is lighter than the Porsche so am sure the single pot calipers will be improvement enough. Even though (a) I hope I never have to use the full braking performance in anger as it means some terrible situation is happening and (b) I'm not expecting to take my car to the track anytime. But I'm an engineer by profession, so just fancied the challenge of the conversion!
Dedicated thread on the brakes / suspension part of my build is here Porsche 944 Brake conversion on 1303 _________________ '75 1303 (current project) owned since 1989!
Dodgy Samba Member
Posted: Wed Dec 20, 2017 1:34 pm Post subject: Re: '75 UK 1303 Build Thread |
A couple of people have commented on this thread over the last few months, didn't realise it had been quite so long since I last posted - but there are some more recent posts on my Porsche 944 Brake conversion thread with progress updates there on that side-project (not yet complete).
Well, the car recently got an outing into fresh air for the first time in 5 years
I should point out that it made it onto the trailer under it's own power! But it has no brakes right now, just half a handbrake (shoes on one side MIGHT be made of duct tape...)
Here's the photo from 2012 when it went INTO the garage to start the project. For all the work that has gone in so far it looks worse now, not better! But that is the way these things go... It looks good on the Porsche 17's though!
My son has got a lot bigger in the same period!
Anyway, the hasty rebuild (throw everything back together) was because this happened...
New garage / house remodel now in progress, more updates on the Beetle build to come when building work is complete and I get to play in the new improved garage! _________________ '75 1303 (current project) owned since 1989!
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Gee George Samba Member
Joined: June 08, 2018 Posts: 2 Location: Leicestershire
Posted: Fri Jul 13, 2018 8:26 am Post subject: Re: '75 UK 1303 Build Thread |
Wicked to see someone from Leicester on here!!! I gotta do simelar work on my 1977 standard beetle. I have replaced both floor pan halves and now I have to replace the nearside inner wheel arch, bulkhead, far side heater channel and do some work on the rear bumper mounts. This has given me good motivation for working on it over the summer. |
Volt01 Samba Member
Joined: March 25, 2019 Posts: 31 Location: British Columbia
Posted: Tue Mar 26, 2019 9:52 am Post subject: Re: '75 UK 1303 Build Thread |
Cool! i got a miami blue bug too! |
beetlenut Samba Member
Posted: Tue Mar 26, 2019 10:10 am Post subject: Re: '75 UK 1303 Build Thread |
Dodgy wrote: |
I’m hating bodywork already... The cutting / welding bit is OK, but sanding and prepping for paint is just tedious... |
Wait till you get to the color/wet sanding! Just when you think you're done,.... you're not! Worst yet, you have to get that last part done before you can bolt all those nice new trim parts back on. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4408 Location: Stuck in Ohio
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Tue Mar 26, 2019 7:32 pm Post subject: Re: '75 UK 1303 Build Thread |
Buggeee wrote: |
Front to back on this thread here and am stunned by the metal work.
Looking forward to an update! |
In total agreement! WOW! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
chicagovw Samba Member
Joined: January 06, 2007 Posts: 1419 Location: Chicago IL/CHandler AZ
Posted: Wed Mar 27, 2019 3:36 pm Post subject: Re: '75 UK 1303 Build Thread |
Any updates on this car? |
Dodgy Samba Member
Posted: Fri Apr 12, 2019 3:42 am Post subject: Re: '75 UK 1303 Build Thread |
Thank you all for the comments, it's been a long time since my last post. Unfortunately not much progress on the car as I am still plugging away at the house remodel (will be a while longer yet). Building work has been completed a while ago but loads of decorating to do, plus life distractions in general.
BUT the car is back home...
...and I have a swanky new garage I'm enjoying using!
FINALLY - a flat floor and a roof that does not leak!!!
Notice the two lifting eyes in the roof - positioned precisely to lift the body when it comes off the floorpan again! VW garage luxury.
Gee George - good to have a Leicester neighbour here on the Samba! _________________ '75 1303 (current project) owned since 1989!
1303s Samba Member
Joined: February 12, 2006 Posts: 82 Location: New Zealand
Posted: Sat Aug 17, 2019 3:24 pm Post subject: Re: '75 UK 1303 Build Thread |
Great work Dodgy! It's guys like you who post about what they're doing that get the rest of us motivated to try this on our cars! I started on mine in January: front valance, inner wheel well, death foam ... and Klokkercrap panels!
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
TK-CS Samba Member
Joined: April 15, 2019 Posts: 279 Location: D - Deutschland
Posted: Mon Aug 26, 2019 1:31 pm Post subject: Re: '75 UK 1303 Build Thread |
Dodgy wrote: |
Heater channel I fitted on the LH side was branded 'JP Group / Denmark' and looked like this:
Because it had been a long time since I bought the LH part, it didn't hugely surprise me when I went to the same supplier and walked out with a different one to before, this time branded 'Klokkerholm' that looked like this:
So the pressing looked much better, especially the detail around the heater outlet in the front footwell This was unexpected bearing in mind previous rants about Klokkercrap panels, BUT...
The paint finish is not nearly as good, and doesn't extend inside the tube at all
The fit wasn't as good, I had to extend the front by about 15mm (way more than the JP Group panel). After fitting none of the threaded inserts lined up with the floorpan, which will now need the holes lengthened or moved
To lengthen the heater channel front end I flattened the factory flange and extended it by adding a new one:
Today I came across a document from Klokkerholm at the Cagero Shop:
When I saw this document I recalled your build thread and was curious which version you got. Compared to your photos seems that you got one of the old ones (LH) and one of the revised (RH) Klokkerholm heater channels. Unfortunately the new ones are still by far not as good as they should be.
They sell these parts at around 99€ in Germany. Why don't they make it perfect and call 199€? A lot of people would pay if they get a perfect fitting part. _________________ AC:
'71 1600LE (Type 3 Notchback FI/AT) Sunroof
'75 1303 (Super Beetle) 1600DP, Sunroof
WC:
'77 Audi NSU Ro80
'88 GTI 16V
'91 Corrado G60
Daily:
'04 Passat Wagon 2.0TDI
'13 Passat Wagon 2.0TSI |
