xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Wed Feb 08, 2017 6:57 pm Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
Here's a better view of that flex piece. Again, only three months and three thousand miles on it.
199254 miles on the van and 93 hours on the engine, let's see if this one can hold up to the northeast salt. |
Vanagon Nut Samba Member
Posted: Thu Feb 09, 2017 12:06 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
does the left rear tire kick up water and road salt toward that bushing?
1988 West DIY 50º ABA
VE7TBN |
Posted: Thu Feb 09, 2017 6:56 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
Vanagon Nut wrote: |
Neil. |
yes it does, still that braided piece should not have crumbled apart like it did. |
jberger Samba Member
Posted: Thu Feb 09, 2017 9:00 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
xoo00oox wrote: |
Neil. |
Depending on the grade of Stainless, a salt spray that hits a very hot object will certainly turn that coupling to mush real quickly. Maybe wrap it with header tape to keep the salt from penetrating the loose weave and packing the internal ribbed space. I feel that is bound to happen again. |
Posted: Thu Feb 09, 2017 9:14 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
xoo00oox wrote: |
Neil. |
Though its a somewhat "apples to oranges" comparison, the outside of the bushing on my ABA NA engine still looks ok after at least 10K miles. But then its located higher (closer to manifold) than the bushing you show. But only 3 months and 3000 miles on the bushing you show? I agree. It shouldnt be failing so soon. _________________ 1981 Westy DIY 15º ABA
VE7TBN |
Posted: Thu Feb 09, 2017 10:26 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
jberger wrote: |
xoo00oox wrote: |
Neil. |
I have a feeling it is too. A lot of cars have flex sections like this on the very bottom of the car, Audi for example. They are right before the catalysts. These cars are only a about 6 inches off the ground and get this part dragged through salt and slush for about 10 years before they go bad. I think it was just inferior metal used on the mesh part of this one. |
Wangta Samba Member
Joined: November 04, 2016 Posts: 56 Location: Inland Empire, CA
Posted: Wed Sep 06, 2017 1:41 pm Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
Andrew - your van still alive and killin it on the roads? Forgo to ask - did you have to cut the crossmember at all to mount the Audi 5 speed (I believe you do for the Subi covnersions). Oh and when can you do this to my van? |
point003 Samba Member
Posted: Mon Dec 04, 2017 12:29 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
xoo00oox wrote: |
With the new engine, I need to go to drive-by-wire rather than throttle cable. This is the best solution we have found. I use the late VW accelerator pedal and use a CAT 5 cable to run the data from the cable to the ECM. I also run the OBD2 data through the same cable from the ECM to the diagnostic port we install under the dash.
best to you, please, tell me where this pedal? perhaps you know the part number? or exactly where to use this? or where exactly you bought it?
PS.. sorry for my English |
Posted: Tue Nov 12, 2019 2:54 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
Hi,
the same thing I managed to do with the Audi engine, only with a one-way camshaft.
look-
https://youtu.be/h5e_3isdy5Y |
4Gears4Tires Samba Member
Posted: Tue Nov 12, 2019 7:25 pm Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
Well that was a fun read! What a great build! _________________ '87 Syncro
elizer Samba Member
Joined: May 02, 2016 Posts: 1466 Location: Northern Virginia
Posted: Tue Nov 12, 2019 8:33 pm Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
point003 wrote: |
xoo00oox wrote: |
2006 jetta have those pedals I believe |
Posted: Mon Dec 02, 2019 11:14 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
SyncroBouree Samba Member
Joined: August 25, 2017 Posts: 26 Location: Alongside Monterey Bay
Posted: Mon Dec 02, 2019 11:30 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
Looks Hella frosty there-
Best wishes for keeping warm and safe as the next storm heads your way.
p.s. Tho' mine still twists -normally- Thank you for your 1.8T counter-twist university online course...
p.p.s. Love the Audi insignia as well _________________ --Liam
1990 Vanagon GL Syncro Westy VW1.8T Triple-Knobber
1975 911S Widened Turbo/RSR Hybrid
1979 Harley Lowrider -- Donated to a good home
1969 Ford Bronco Half-Cab 351W, Toploader, Dana 44 FE, Detroit Locker, Duffy’s Suspension – wish I still had it
1962 GMC 3/4T Fleetside, V6<-Chevy 409 w/factory headers, Camper/Tow Rig – ditto |
cptgreenvalley Samba Member
Posted: Sat Jul 18, 2020 10:24 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
Wow! Such an interesting read of an impressive build!
Any idea if this would work with A6 quattro as well?
I guess it is time to measure my A6 1.8t drive train😊
BR
Magnus _________________ 1979 T2 Camper 2.0FI - Sportsman Conversion ( US import)
1987 T3 Syncro Vanagon 1.9TD ( Decoupler, Double Diffs, Westfalia conversion)
1991 Golf MK2 Country Syncro 1.8
2010 BMW 330xd & 320xd |
Posted: Tue Jul 06, 2021 5:09 pm Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
Quattrosyncro is still running like a top! I had to move my boat and the trailer I'm building is not ready yet so....
Just fits!
Zeitgeist 13 Samba Member
Posted: Tue Jul 06, 2021 5:53 pm Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
Awesome! _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
fleet_maintenance Samba Member
Joined: November 01, 2013 Posts: 323 Location: Upstate NY
Posted: Tue Jul 06, 2021 9:44 pm Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
xoo00oox wrote: |
Just fits!
Like something out of a Bond movie. |
Posted: Wed Jul 07, 2021 6:13 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
That's a beautiful little boat. _________________ '87 Syncro
Posted: Wed Jul 07, 2021 6:40 am Post subject: Re: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL |
4Gears4Tires wrote: |
That's a beautiful little boat. |
Thanks! Learning woodworking was my Covid project. I started in February '20 with little wooden boxes and worked my way up to building the boat. Just got it in the water for the first time this past weekend.
It was a happy surprise to find that it fits inside the Vanagon. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
