Bostig Muffler Upgrade
Page: Previous  1, 2, 3  Next
MsTaboo
MsTaboo is offline
PostPosted: Tue Jun 23, 2015 1:19 pm    Post subject: Reply with quote
OK, thanks for the update! So the main reason you changed from the Magnaflow SS unit was because it was too loud?
Currently:
Defend democracy, support Ukraine.
LemonCove
LemonCove is offline
PostPosted: Tue Jun 23, 2015 3:36 pm    Post subject: Reply with quote
Yep. Especially under acceleration; the maganaflow sounded great, but hey, this is no sports car. I really notice the difference now with the Walker on long drives at highway speeds . . . now we can have a normal conversation, listen to the stereo, less stress from the constant din. The Walker still announces you're coming . . . . my cat is always at the door to greet me. Very Happy
'88 Bostig Westy
shizzon
shizzon is offline
PostPosted: Tue Jun 23, 2015 3:39 pm    Post subject: Reply with quote
Do you know how the walker 17904 compares to the bostig-spec quiet-flow in terms of volume?
1989 Bostig Syncro Westy
LemonCove
PostPosted: Tue Jun 23, 2015 7:59 pm    Post subject: Reply with quote
Using the dimensions from the table on the previous page it compues to appx:
17904 = 383 ci
Bostig Spec = 570 ci
As I indicated earlier, I spoke to Walker tech support to ask about the "quietest" muffler. The Walker tech rep indicated that the noise level for all the Walker mufflers in the table (except the megaflows) would be equivalent (tone and volume) on the Zetec. All have similar internal construction. None of them should create any significant back pressure concerns.
'88 Bostig Westy
shizzon
shizzon is offline
PostPosted: Tue Jun 23, 2015 8:56 pm    Post subject: Reply with quote
Oops. By volume I meant noise, not mass divided by density Wink
LemonCove
PostPosted: Wed Jun 24, 2015 10:02 am    Post subject: Reply with quote
Thanks for that. I was wondering how you were going to make a decision based upon the internal capacity of the mufflers . . . . I should have figured that out Embarassed. I guess it was a good math exercise for me.
I use a research grade sound level meter for doing environmental assessments, and actually attempted to evaluate mufflers using that. Trouble is it's real hard to do this . . . what's the proper methodology? My tailpipe and van interior tests proved inconclusive . . . the Magnaflow was somewhat louder based on those measurements, but the 2 Walkers were essentially the same. Honestly, the measurements did not agree with my subjective evaluation. The sound level meter (as I recall) measures at 3 distinct frequencies, while the human ear hears full spectrum.
https://picasaweb.google.com/13VelosdeRemi/BostigMufflerUpgrade#6001992353038131842
The van interior sound level (volume if you will) is what counts; I went from relatively quiet (Bostig spec), to agressive, throaty, louder (Magnaflow), to relative quiet again (17904). I couldn't honestly notice a "volume" difference between the 2 Walkers.
'88 Bostig Westy
shizzon
shizzon is offline
PostPosted: Wed Jun 24, 2015 9:12 pm    Post subject: Reply with quote
To be clear... is the fitting the same with both the bostig-spec and the 17904? Do you still use the same shim and clamp?
LemonCove
PostPosted: Wed Jun 24, 2015 9:43 pm    Post subject: Reply with quote
it can be, and others have done so. PM Kourt to see how he did his.
Because the offset design moves the "centerline" of the muffler outward, the Bostig hangers are too far "inward." The inboard rubber isolators are now pretty much centered on the 17904 case. I decided to use modified Walker 36273 hangers ($5/ea). I took off the rubber strap, and shortened the hanger to one hole from 2. I still used 2 of the the Bostig rubber isolators (inboard) and S/S screw clamps.
This is all detailed in a picasa album "Bostig Muffler Upgrade":
'88 Bostig Westy
shizzon
shizzon is offline
PostPosted: Wed Jun 24, 2015 10:03 pm    Post subject: Reply with quote
The hanger connection looks slick, but I meant the part that connects the muffler to the exhaust. Is that part of the muffler the same diameter as the bostig-spec muffler? I.e., no welding or funny business required at that connection?
thanks!
LemonCove
PostPosted: Thu Jun 25, 2015 11:00 am    Post subject: Reply with quote
Same diameter, Same slot cuts in the muffler pipe, Same overlap on the cat pipe, Same clamp for the 17904. I don't recall using a shim, but did use the AcoustiSeal.
No welding.
I found it immensely fun Wink
If you get stuck PM me.
'88 Bostig Westy
shizzon
shizzon is offline
PostPosted: Fri Jul 03, 2015 2:07 pm    Post subject: Reply with quote
I got some of the walker exhaust sealing compound. is it necessary to let it cure before using the engine and having it get really hot.. .i'm surprised there are no instructions on the bottle!
LemonCove
PostPosted: Fri Jul 03, 2015 10:32 pm    Post subject: Reply with quote
I didn't do any special "curing."
Applied it to the joint, drove the van.
No leaks, has remained leak free.
'88 Bostig Westy
shizzon
shizzon is offline
PostPosted: Thu Jul 09, 2015 5:06 pm    Post subject: Reply with quote
kourt wrote:
I've put the Walker 17904 on my Bostig, with a 9" down curve tip, and it's roomier and quiet, and gives more clearance from the AC compressor.
Kourt, do you have the part number for the 9" curve down? Does it stick out?
Does anyone know whether a tip really makes a difference in quieting things down?
I did this install and my initial impressions are that it is pretty much the same or maybe quieter than the stock bostig setup. I'd be stoked if i can quiet it even more!
kourt
kourt is offline
PostPosted: Thu Jul 09, 2015 5:11 pm    Post subject: Reply with quote
I just used a cheap tip from the local auto parts store--I think it was 2 1/4" inlet. The inlet side was widened slightly, and tapered to a standard 2" output.
kourt
shizzon
shizzon is offline
PostPosted: Fri Jul 10, 2015 8:20 am    Post subject: Reply with quote
Did that cheap tip seem to quiet it down, kourt?
kourt
kourt is offline
PostPosted: Fri Jul 10, 2015 8:27 am    Post subject: Reply with quote
It could be the placebo effect, but it seemed to help keep things quieter back there. It's hard to say--what with "sooting in" (as Bostig calls it) and other factors.
kourt
LemonCove
PostPosted: Thu Dec 01, 2016 6:08 pm    Post subject: Re: Bostig Muffler Upgrade Reply with quote
Updated link for "Muffler Upgrade" photo album (picasa link is dead):
https://goo.gl/photos/CFk44jXnuQQkiXHS6
For each photo, clicking on "i" (info) icon will open sidebar with notes.
EDIT: Ooops, I guess I'm the only one who can see the comments/notes, and only while I'm signed in (thanks, Google). Vid links don't work either.
. Can still see photos though.
'88 Bostig Westy
vwcampin
vwcampin is offline
PostPosted: Thu Dec 01, 2016 9:34 pm    Post subject: Re: Bostig Muffler Upgrade Reply with quote
I just wanted to say thanks for this thread. Helped me make the leap and definitely happy with results! Very Happy
1986 Vanagon Syncro Westfalia Weekender
Microbusdeluxe Premium Member
Microbusdeluxe is offline
PostPosted: Wed Jun 28, 2017 1:40 pm    Post subject: Re: Bostig Muffler Upgrade Reply with quote
Wanted to add my thanks for this thread. I wasn't happy at all with the original muffler set-up and the fitment of the suggested muffler.
Everything seemed to be loosey-goosey and definitely hung lower than the old waterboxer set-up. By using the Walker 17904 muffler, which is smaller than the suggested one, and especially using the vastly superior hanger suggested in the above part of this thread things look great, secure and it all fits perfectly. I added a 9" down-curved tail pipe from the FLAPS.
Sound is fine, the Zetec has a different pitch than the waterboxer, but highway noise is no worse than the old 2.1.
If you are just starting your build do yourself a favor and take back the suggested muffler before you cut it and substitute the smaller one.
'69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig!
Guybrush
Guybrush is offline
PostPosted: Wed Jun 28, 2017 1:51 pm    Post subject: Re: Bostig Muffler Upgrade Reply with quote
I use the same one too, although I find the exhaust too loud, but it's possible I didn't seal it well enough between muffler and cat.
I actually used the Bostig hangers to attach it, but only 2 of them, and that works fine.
Did the same thing as LemonCove for the tip and cut a bit of the sheet metal for clearance. I think it looks just right. The one towards the rear wanted to slip out of the rubber but I added a little clip to prevent it (the former WBX accelerator cable clip fit juuust right).
Better clearance from the A/C compressor and I'll be building a shield when I get the A/C working.
Page 2 of 3
