nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Tue Sep 03, 2013 6:02 pm Post subject: Bosch generator parts |
I'm looking for a couple of parts to rebuild a BOSCH RED generator. Specifically I'm looking for #17, #18 and #21
I'm wondering if these parts may be scavenged from thin slot or other 6V generators. Anyone know?
I'm also wondering about the armature would a thin slot one work in a RED generator? I realize the part numbers are probably different.
billmetric Samba Member
Joined: March 16, 2006 Posts: 1061 Location: Columbus City USA
Posted: Wed Sep 04, 2013 3:20 pm Post subject: |
I believe 17, 18 and 21 are the same on thin slots, I just had my RED gen. apart last week, I'm pretty sure mine also has a newer armature in it as well as the threaded part where the pulley and fan nuts screw on seems very short, as in when using the correct deep 36mm #1/#10 nuts in your photo the threads are way down in there, I would think the correct armature would have a longer threaded part than what i'm dealing with, otherwise it was working just fine with the short armature and D reg. , was charging fine, just had it apart to repack the bearings _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
Posted: Wed Sep 04, 2013 8:34 pm Post subject: |
OK, thanks for the help. I'm missing 16 and 13 also. I guess I'll sacrifice a thin slot. |
Posted: Thu Sep 05, 2013 7:08 am Post subject: |
I believe 14-16-18 and 20 are just dust seals, if you purchase newer sealed bearings they would not be necessary, also the spacers and possibly the 17 holding plate may be common to all older bosch 6v generators, probably unnecessary to source them from a perfectly good thin slot _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Thu Sep 05, 2013 10:38 am Post subject: |
I agree with Bill about the dust shields. But the later retainer plates were held in with a circlip if I recall correctly, not a screw held retainer. I could be wrong, but that is what I recall. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Mon Sep 16, 2013 7:35 pm Post subject: |
I finally tore down an October '50 generator that was in my shop. A few notes relative to what Nancy asked about.
The spacers 13 and 21 are identical. 5.9mm thick.
There is a part not shown in the diagram, it is a "C" steel ring that gets slipped down over the commutator end of the armature. It sits down in a groove cut around the armature shaft, just above the commutator. Maybe it is always supplied with the armature.
Anyway, part number 16 sits down against it, it keeps the bearing from pressing down on the commutator. Part 16 is pretty thick and not like the other dust shield pieces. Not sure if the thin slots used this setup or not. I can take pics later if it is not clear. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue Sep 17, 2013 6:47 am Post subject: |
johnshenry wrote: |
I can take pics later if it is not clear. |
Good info, thanks John.
Pictures would be helpful if you have time. I'm still looking for the parts. So I have not been able to find an appropriate donor. |
Posted: Mon Sep 23, 2013 5:38 pm Post subject: |
Here's the pics from a '51 Gen I tore down. I munged up that disc that sits on the ring clip by whacking it with a hammer and flat bladed screwdriver to get it off. You's need a very special kind of puller to get it off clean. The pics show the parts in order of how they sit in the armature. SOme pics show the same parts, but flipped over.
'57 Deluxe
'56 Single Cab |
Joshua B Samba Member
Joined: January 03, 2004 Posts: 273 Location: Colorado
Posted: Wed Jan 03, 2018 10:24 am Post subject: Re: Bosch generator parts |
So when putting in new sealed bearings do you use 14, 16, 18 and 20? Was wondering if leaving them out would affect spacing? Also, any recommendations on a locally purchased fabric wrap to rewrap the fields? |
Posted: Wed Jan 03, 2018 10:38 am Post subject: |
billmetric wrote: |
I believe 14-16-18 and 20 are just dust seals, if you purchase newer sealed bearings they would not be necessary, also the spacers and possibly the 17 holding plate may be common to all older bosch 6v generators, probably unnecessary to source them from a perfectly good thin slot |
And 3M makes a nice fabric tape that works well |
Posted: Wed Jan 03, 2018 10:54 am Post subject: Re: Bosch generator parts |
Ok, thanks. I had read that, but then it looks like in one of the last photos John posted there looks to be a sealed bearing in the view with all the washers, so I figured I would clarify.
Also any US sources for the optibelt A34 13x850Li fan belt, can't seem to find one and would hate to have an international shipment for just a fan belt. |
empiracer Samba Member
Joined: December 17, 2002 Posts: 1098 Location: Issaquah / Seattle, Wa.
Posted: Wed May 17, 2023 8:48 am Post subject: Re: Bosch generator parts |
Carious if anyone knows the interchangeability of the armatures , I have a “red” gen that the threaded post on the armature was cut off , wondering if I could rob a armature from a later 6v unit |
Posted: Wed May 17, 2023 9:50 am Post subject: Re: Bosch generator parts |
empiracer wrote: |
Don't know for sure, but I would think possibly. The armatures are date coded BTW, small numbers stamped on the armature core. _________________ John Henry
'57 Deluxe
'56 Single Cab |
