Wiring Diagram for Oil Cooler Fan
dgsaz
dgsaz is offline
PostPosted: Wed Sep 04, 2013 1:01 pm    Post subject: Wiring Diagram for Oil Cooler Fan Reply with quote
Hello all,
Would you have a look at my wiring diagram for an oil cooler fan with a relay and an in-line thermostat switch.
As my oil temp has yet to go much over 180 degrees I'm not sure if it's wired right or it has never gotten hot enough to turn on the fan.
I'm thinking about hitting the t-stat switch with a hot air gun and see if that will cause the fan and indicator light to come on. Then on the other hand it could be wired wrong.
Here's how I have it wired now. Right or wrong, or just not hot enough yet?
Thanks for looking.
dgsaz
[img][/img]
risk
risk is offline
PostPosted: Wed Sep 04, 2013 1:16 pm    Post subject: Reply with quote
85 should be ground and 86 is trigger from your thermostat... try it that way and I bet the fan comes on.
dgsaz
dgsaz is offline
PostPosted: Wed Sep 04, 2013 1:39 pm    Post subject: Reply with quote
I look on the net and some diagrams show 86 as ground:
http://www.google.com/imgres?imgurl=http://www.cla...mp;dur=625
and other 85 as switched. I'm a bit confused.
dgsaz
risk
risk is offline
PostPosted: Wed Sep 04, 2013 3:16 pm    Post subject: Reply with quote
There are a few different ways to wire it up depending on how you are using it.. for your application I think you need to swap 85 & 86.
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Wed Sep 04, 2013 3:40 pm    Post subject: Reply with quote
Something else to consider is adding a diode to the warning light from your alternator. If the cooling fan is running when you go to shut off the engine, the fan blades spinning to a stop can cause feedback into the charging system. MSD recomends using a 1 amp, 100 volt diode. I think the Radio Shack part # is 276-1103. Just wire it inline of the wire between the alternator, and charging light. The diode should have a stripe on it, and the stripe end goes to the alternator. Another thing to consider is running the thermostat after the cooler, so the cooler has an opportunity to cool some without the fan.
bsairhead
bsairhead is offline
PostPosted: Wed Sep 04, 2013 3:42 pm    Post subject: Reply with quote
85 is the ground. Edit, Or 86, should not matter
dgsaz
dgsaz is offline
PostPosted: Wed Sep 04, 2013 4:10 pm    Post subject: Reply with quote
Thanks for the answers. I'll try it and report back.
dgsaz
risk
risk is offline
PostPosted: Wed Sep 04, 2013 4:58 pm    Post subject: Reply with quote
Yeah I guess it could go either way.. I have always wired them the same way, 85 to ground and never had an issue.
Dale M.
Dale M. is offline
PostPosted: Wed Sep 04, 2013 9:42 pm    Post subject: Reply with quote
dgsaz
Should work either way unless there is a diode across internal coil of relay..... The relay is just a electromagnetic switch and in most cases does not care what polarity is on 85/86...
But the correct way is...
85 ground
86 12 volts
87 Output
30 + 12 volts input...
http://www.motor.com/magazine/pdfs/042003_07.pdf
To test total circuit, just take a jumper wire and go across the two terminals of t-stat switch, fan should start up.......
Dale
Dale M.
Dale M. is offline
PostPosted: Wed Sep 04, 2013 9:48 pm    Post subject: Reply with quote
Fan is not going to generate enough electricity to keep engine running.... Besides, if wired correctly relay coil 12 volts should be sourced by ignition switch and once key is off, relay contacts "open" and there is no electrical path from fan motor to possibly cause run on condition...
Diode that MSD supplies and shows in its diagrams do nothing to stop run on unless there is a malfunction in MSD box and it puts out a voltage on IGN (control off-on) wire.... Which under normal circumstances it should not do....
Dale
jason
jason is offline
PostPosted: Wed Sep 04, 2013 10:10 pm    Post subject: Reply with quote
I do mine backwards, do all the triggering with the ground legs and the fan will stay on after the car is turned off.
jason
jason is offline
PostPosted: Wed Sep 04, 2013 10:16 pm    Post subject: Reply with quote
My fan usually only comes on after shutting the motor off. I think it has something to do with the motor not blowing the air to cool. It's usually only a minute or two.
Dale M.
Dale M. is offline
PostPosted: Thu Sep 05, 2013 4:33 am    Post subject: Reply with quote
IF fan is running after car shuts off, its because of two things, temperature rise at t-stat because oil is no longer flowing and not cooling t-stat and control circuit for fan (relay) is not wired for control by key switch, its wired direct to battery which is not necessary or desirable...
Dale
Dale M.
Dale M. is offline
PostPosted: Thu Sep 05, 2013 4:45 am    Post subject: Re: Wiring Diagram for Oil Cooler Fan Reply with quote
dgsaz wrote:
Hello all,
Thanks for looking.
dgsaz
Actually T-stat should be on out put side of cooler.... IF cooler is doing its job of cooling oil with out fan running then t-stat does not need to trigger fan into coming on by temperature of hot oil coming into cooler, fan only needs to run if COOLER is not capable of cooling oil to below t-stat temp because there is not enough ambient temp change in cooling coil of cooler by natural air flow through cooler IE: cooler buried someplace deep in vehicle where there is no natural air flow.......
And as I mentioned above, control circuit should be under ignition switch control, there is no reason for fan to run if oil is not flowing through cooler...
Dale
jason
jason is offline
PostPosted: Thu Sep 05, 2013 8:37 am    Post subject: Reply with quote
Dale you are correct, key does not not actuate fan. I prefer not having extra hot wires all over. I also don't see a problem with the fan on after the car is off, my new car does it.
jason
jason is offline
PostPosted: Thu Sep 05, 2013 8:39 am    Post subject: Reply with quote
Also make sure your fuse is as close as possible to the battery.
Dale M.
Dale M. is offline
PostPosted: Thu Sep 05, 2013 12:30 pm    Post subject: Reply with quote
And the cooling fan conversion I put on my JEEP specifically has relay (fan) controlled with ignition switch..... Go Figure....
Dale
mondshine
mondshine is offline
PostPosted: Thu Sep 05, 2013 4:41 pm    Post subject: Reply with quote
Try this:
Good luck, Mondshine
dgsaz
dgsaz is offline
PostPosted: Wed Sep 11, 2013 4:52 pm    Post subject: Reply with quote
Ok, I finally got around to troubleshooting the wiring. When I split the relay and took a good look at the internals I realized that the ground from the 86 terminal was run to the thermo switch and the 85 terminal was running to ground.
If I would have followed my own diagram it would have worked, but noooo....
I write this off to the mirror image when the relay is split. Right is left and left is right. That and I'm a part time dyslectic just a pinch of adult ADD.
Tested the new set up with a jumper at the thermo switch and both the fan and indicator light work.
Now all I need is a good blast up the I-5 and see what happens when I pass 180 degrees.
Better late that never.
dgsaz
Ellis' Bug
Ellis' Bug is offline
PostPosted: Thu Sep 12, 2013 1:35 pm    Post subject: Reply with quote
Sorry guys but I'm a little electrically challenged. I have one side of the t-stat grounded..... and my fan isn't coming on.
Can someone re-do the drawing above so that it is correct...... or is it already correct?
74 Super drag car
63 Bus, work in progress
65 Bug project
63/64 Ragtop
2006 Beck 356
