pondoras box Samba Member
Joined: March 22, 2004 Posts: 1227 Location: Eerie PA
Posted: Sat Oct 26, 2013 2:59 pm Post subject: |
When you patched the frame did you lay one continuous bead on a series of spot welds? It looks continuous and was just wondering if you had any warping issues or is the steel thick enough to handle the heat? _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
wrstp Samba Member
Posted: Sat Oct 26, 2013 3:22 pm Post subject: |
pondoras box wrote: |
When you patched the frame did you lay one continuous bead on a series of spot welds? It looks continuous and was just wondering if you had any warping issues or is the steel thick enough to handle the heat? |
I ran a continuos bead with my welder set on its highest setting to ensure plenty of penetration. The rail is plenty thick enough to handle the heat and no warpage was noticed. |
Posted: Sat Oct 26, 2013 3:27 pm Post subject: |
Thanks, I am getting ready to do a patch on my frame and was thinking it could handle it but wasn't sure. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1957 Oval ragtop
wrstp Samba Member
Posted: Sat Oct 26, 2013 3:31 pm Post subject: |
Thanks, I am getting ready to do a patch on my frame and was thinking it could handle it but wasn't sure. |
No problem and be sure to leave a gap between pcs and bevel both pcs. This will help with penetration and give the wire a place to go and not just sit on top. |
1967250s Samba Member
Posted: Tue Dec 03, 2013 7:35 pm Post subject: |
Anything happening with that Splitty, Wrstp? Let's see some more of your work! |
AlteWagen Troll
wrstp Samba Member
Posted: Wed Dec 04, 2013 3:27 am Post subject: |
The split is still on stands in the garage patiently waiting further repair. I am almost done helping with an all metal Harley bagger project and will be back on green mountain rust.
The jack points I used 14 gauge to reproduce. The small piece in the center is thicker on the original the rest is pretty close as the original is pretty swelled up so can be hard to mic. Thanks for asking and sorry it's taking so long. |
Posted: Thu Dec 05, 2013 2:39 am Post subject: |
It's worth the wait. Just checking up on you. :p |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Sat Apr 19, 2014 8:58 am Post subject: |
What happened to this? Any news? |
wrstp Samba Member
Posted: Sat Apr 19, 2014 9:06 am Post subject: |
1967250s wrote: |
Sorry nothing new to report but I will hopefully get back to work on it soon. |
OCWest Samba Member
Joined: December 30, 2007 Posts: 67 Location: Westminster , California
Posted: Tue Apr 22, 2014 9:04 pm Post subject: |
I love the fact that your saving this bus from the grave. You might want to even call it the Easter Bus when your done because it's more like a resurrection. I was a little concerned about my new purchase knowing I need to replace my rocker panels inside and out. After removing an ez bed I found a couple of more holes in the floor board the previous owner didn't tell me about and surely he knew because he covered the hole with some metal tape. I don't understand what the deal is with preserving as much of the original paint when its so far gone. Maybe someone can please enlighten me please. My bus still has the original paint and I might say doesn't look that bad however I can't wait to get the body straight and give it a fresh coat. My metal guy says after he replaces the rockers to just blend the paint. I guess he's of that same opinion too.
Anyway, I look forward to see how this bus is going to look and I'm very happy for the bus. You're doing fine work!! _________________ 1974 project Thing |
kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Tue Apr 22, 2014 9:31 pm Post subject: |
I'm into original as much as possible too, but thats not the "right"... just another way. You do whatever the eff pleases YOU! _________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Tue Apr 22, 2014 10:10 pm Post subject: |
Larser wrote: |
Maybe someone can please enlighten me please. |
It may be an overused phrase, but "they are only original once". If you want nice shiny paint, buy a bus that has already been repainted and make it your own. If your bus (or any other vintage vehicle for that matter) has solid original paint and your body guy knows how to blend in any rust repairs, do it.
My opinion, of course. Your bus is just that. Yours. Do with it as you please. _________________ nothing |
GTV Samba Member
Posted: Tue Apr 22, 2014 10:33 pm Post subject: |
IMO, having old original paint is the only way to enjoy these vehicles like they were meant to be when they were new(ish). If you're like me, if you do something you want it done 100%. That includes paint. To give a bus a PROPER paint job requires a LOT of time and money. Then, if you choose to use it like it was meant to be used (a utility vehicle), you will scratch it, chip it, dent it, etc and it will ruin your f-ing day when that happens.
If you scratch, chip, dent original paint you just ad character. And you aren't afraid to drive it like it was meant to be. _________________ EMPI Power Rules! |
wrstp Samba Member
Posted: Wed Apr 23, 2014 3:19 am Post subject: |
For me and the owner it's the character and the many stories behind the bus and it's paint. I agree this isn't for everyone or every bus and enjoy the many shiny new buses cruising the streets as well. I guess it's like someone above said it's your ride do what you want and I'm more then happy to help anyone achieve there vision and get another vdub back on the road. |
2true Samba Member
Posted: Wed Apr 23, 2014 5:16 am Post subject: |
wrstp wrote: |
After removing what was left of the floor and some of the bulk head a nice surprise reveled itself.
Welded up and ready to grind smooth.
[/img] |
Beautiful Weld. _________________ AKA Destroyer of the Rants...... |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Wed Apr 23, 2014 7:21 am Post subject: |
Larser wrote: |
Anyway, I look forward to see how this bus is going to look and I'm very happy for the bus. You're doing fine work!! |
Let's see a pic. Got a thread already? |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Wed Apr 23, 2014 2:36 pm Post subject: |
Here is larser's bus from his Gallery. It would be a crying shame to repaint that bus. If you do, DO NOT post that you have done so. You will become a pariah. I'm just warning you! _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
the.fordhams Samba Member
Joined: February 11, 2004 Posts: 471 Location: Charlotte, NC
Posted: Sat Sep 17, 2016 2:39 pm Post subject: Re: Green Mountain rust bus!! |
The story continues.. green mountain Bus earlier this year. Moving to a new home garage.
_________________ 63 OG Turkis Bug project
65 OG Safari Beige Notch
65 OG Pearl SO42 Patina
67 SO42 welding project
03 Eurovan Weekender
08 Touareg 2 V6
WANTED :
Bob King VW dealer Wilmington NC dealer tag surround and any Literature for 03 Weekender |
