EVfun Samba Member
Posted: Sat Sep 07, 2013 11:44 am Post subject: |
I really think that car is a great candidate for inside door handles only. Just reach inside and open the door. _________________
Wildthings wrote: |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Sep 07, 2013 8:39 pm Post subject: |
didget69 wrote: |
Grab hood/trunk hinges out of an old MG Midget/Austin Healey Sprite & graft into the LaDawri. Use plywood cut/drilled to shape to mate up with hinge mounting bases, insert T-nuts through backside of holes & epoxy plywood to underside of hood & trunklid - the T of the T-nut should be facing the hood/trunk skin - fiberglass over the plywood without filling in threaded insert holes. Then you'll need to figure out how to mount latches... Voila!
External hinges tend to look like zits on a fashion model...
http://m.ebay.com/search?kw=+MG+Midget+hinges&...get+hinges
bnc |
Take a look at the hood hinges from a Ford Pinto/Mercury Bobcat. Nice simple design. They use a rubber boot in the mounting hole that gives them a nice finished look too. I think they might've also used the same thing or a very similar hinge on the hoods of some of the Ranger pickups. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sun Sep 08, 2013 9:40 am Post subject: |
Ford Pinto? Mercury Bobcat? Dang, Son.... HOW OLD are you??
With a little digging, the OP will discover a lot of options for latches/hinges.
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
SBD Samba Member
Posted: Sun Sep 08, 2013 8:59 pm Post subject: |
didget69 wrote: |
bnc |
If I'm your son then you're ancient. I'm pushing up close to 56.
(There's a Pinto wagon with a 302 V8 & an AOD trans in it sitting in my shop! ) |
