Trinidad5 Samba Member
Joined: December 04, 2005 Posts: 135 Location: Oxnard, Ca.
Posted: Thu Sep 05, 2013 11:10 pm Post subject: 71 Bus middle seat belt floor bolt thread size? |
Hi guys, installing some seat belts on my 71 bus middle seat finally. I noticed the floor bolt holes have a few threads in them so I don't want to pop a through bolt in or chance stripping them.
Can anyone please tell me quickly what thread size and length to use? Maybe I can order online or just pick up at hardware store. Thanks. |
Desertbusman Samba Member
Posted: Fri Sep 06, 2013 6:48 am Post subject: |
I really have no idea but would be totally surprised if it was different threads than all the other seat belt fasteners. 7/16 NF and grade 8. Ace has them. _________________ 71 Superbug
71 Westy |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Sep 06, 2013 6:51 am Post subject: |
Yep, 7/16" NF. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Sep 06, 2013 8:58 am Post subject: Thanks |
Thanks guys, heading over to hardware store now. |
CoastalAirCooledVW Samba Member
Joined: September 02, 2012 Posts: 1882 Location: Mckinleyville, CA (Humboldt County)
Posted: Fri Sep 06, 2013 9:02 pm Post subject: |
So the seat belt bolts are not metric? Anyone know the size of the bolt that holds the rear seat belt mount to the gas tank tray? _________________ 1966 Velvet Green Standard |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1082 Location: wherever my baywindow takes me.
Posted: Fri Sep 06, 2013 9:45 pm Post subject: |
CoastalAirCooledVW wrote: |
So the seat belt bolts are not metric? Anyone know the size of the bolt that holds the rear seat belt mount to the gas tank tray? |
Those bolts are no doubt metric. either 10mm x 1.0 1.25 or 1.50. the reason the seat belt bolts are SAE is because that is the United States federal standard for those bolts. The standard applied to all vehicles sold in the USA |
Posted: Fri Sep 06, 2013 10:09 pm Post subject: |
sodbuster wrote: |
Ahh that makes sense. Now Im on the hunt for grade 8 metric (not sold at ace).... _________________ 1966 Velvet Green Standard |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3889 Location: Seattle, WA
Posted: Fri Sep 06, 2013 10:10 pm Post subject: |
7/16-20 thread is so close to M11x1.25 as to be completely interchangeable for all practical purposes. Current US seat belt regs
mandate 7/16-20UNF, 1/2-13UNC, or EQUIVALENT METRIC SIZE for seat belt attachment hardware (49 CFR art. 571.209). Now
maybe things were different forty years ago, but I doubt it. I also doubt any manufacturer in a metric-system country would
use the peculiar "inch" system for its bolts unless it had to. I say the seat belt bolts in VW's are M11x1.25. Of course, it's not
a common metric size and probably hard to find, and 7/16-20 will work just as well. _________________ '67 bug: seized by the authorities
stevespeirs Samba Member
Joined: June 10, 2008 Posts: 310 Location: Virginia Beach, VA
Posted: Sat Oct 06, 2018 10:09 am Post subject: Re: 71 Bus middle seat belt floor bolt thread size? |
Good info on the bolt sizes - thanks!
How about the "washer" that sits underneath the seat belt bracket? Microfiche lists it as a "seal" - would it be metal or rubber? #6 in the diagram
_________________ 1979 Microbus |
Posted: Sat Oct 06, 2018 11:15 am Post subject: Re: 71 Bus middle seat belt floor bolt thread size? |
Those "washers" are nylon, or a similar plastic. Intended to isolate the swiveling bracket at the end of
the belt. You could probably find a suitable size at a good hardware store, mcmaster.com, etc. _________________ '67 bug: seized by the authorities
Posted: Sat Oct 06, 2018 11:28 am Post subject: Re: 71 Bus middle seat belt floor bolt thread size? |
kreemoweet wrote: |
Those "washers" are nylon, or a similar plastic. |
Awesome, thanks! _________________ 1979 Microbus |
Posted: Sat Oct 06, 2018 1:16 pm Post subject: Re: 71 Bus middle seat belt floor bolt thread size? |
Well, I just looked at what my bus has, and theres a heavy metal washer 15 mm ID x 28.5 mm OD x 3.5 mm thick under the shoulder on the
seat belt bolts, and on each side of the swivel bracket there's a "nylon" washer 14 mm ID x 22 mm OD x 1.5 mm thick. There's no
seat belt parts whatever listed in the VW bus parts manual I have, so I don't know whether any of it is stock or not. The belts are
definitely stock. _________________ '67 bug: seized by the authorities
Posted: Sat Oct 06, 2018 2:08 pm Post subject: Re: 71 Bus middle seat belt floor bolt thread size? |
Usually it's a thinnish vinyl washer against the floor on solid mounted belts, and it really is a seal since the other end of that hole is outside against the splashy road. The swivel belts use more hardware. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Oct 10, 2018 6:00 am Post subject: Re: 71 Bus middle seat belt floor bolt thread size? |
Picked up some bolts and washers from the local hardware store yesterday. Worked well on my middle row seat belts. Less than $8 for the lot.
