safariboy Samba Member
Joined: August 21, 2013 Posts: 28 Location: Los Angeles
Posted: Sun Sep 08, 2013 9:47 pm Post subject: Cables near CV joints |
I have two cable ends at the rear CV joints goint to nowhere. What are these? They have some cone shaped ends on them |
hobie16 Samba Member
Posted: Sun Sep 08, 2013 10:28 pm Post subject: |
Parking brake? _________________ Don't be fooled by appearances. In Hawaii, some of the most powerful people look like bums and stuntmen.
--- Matt King
If anything’s going to happen, it’s going to happen out there.
---Captain Ron |
Banker Samba Member
Posted: Mon Sep 09, 2013 3:23 am Post subject: |
Heater cables? _________________ Brian
07 Charger Sublime
03 Goldwing
74 Thing |
kubelmann Samba Member
Posted: Mon Sep 09, 2013 5:18 am Post subject: |
Try this. Hope it helps:
Posted: Mon Sep 09, 2013 1:50 pm Post subject: |
Kubelmann
That is an awesome photo. Jealous to have that set-up |
Posted: Mon Sep 09, 2013 3:29 pm Post subject: |
I am not sure that Cessna 140's have CV joints, what did you say you were working on again? |
Posted: Mon Sep 09, 2013 3:34 pm Post subject: |
come on fellers. duck tape and bailing wire makes everything look fancy and special. Also 944 rear arms and brakes are a nice mod. |
Posted: Mon Sep 16, 2013 9:34 pm Post subject: |
kman nice pic but wher do those cables go to in the rear. There is no play and they sit right over the cv joint area |
Semper_Dad Samba Member
Posted: Mon Sep 16, 2013 9:44 pm Post subject: |
safariboy wrote: |
They connect to your heater box levers (if you still have heater boxes). They are controled by the little handle on the passenger side of your emergency brake. If you don't have heater boxes then you can remove them from the parking brake end. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Tue Sep 17, 2013 12:06 pm Post subject: |
Semper Dad
When I move my heater levers at the parking brake the flaps open and close. So would those cables even be for heater? |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Tue Sep 17, 2013 2:53 pm Post subject: |
When you move the levers, the one that says heat- defrost will move the flaps inside the car. The lever that says temp will move the cables to the engine. |
thinghunter Samba Member
Joined: May 18, 2004 Posts: 403 Location: North Texas
Posted: Tue Sep 17, 2013 4:18 pm Post subject: |
I would bet a pic of what you are talking about would solve your issue in a matter of minutes. |
Posted: Tue Sep 17, 2013 5:46 pm Post subject: |
thinghunter wrote: |
Review page 126 of the Parts Manual available in the technical section. That will give a better idea of how the cables are ran and how they work.
The heating levers work exactly as they do an a Beetle. Passenger side lever controls the amount of heated air coming out of the rear heater boxes. Driver's side lever controls the direction of the heated air (Cabin or defrost) _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Banker Samba Member
Posted: Wed Sep 18, 2013 3:03 am Post subject: |
Great Picture. I need cable #4. It broke off on one side. Does anyone have the part number or the name of the cable for me to find?
Thanks _________________ Brian
07 Charger Sublime
03 Goldwing
74 Thing |
tallman206 Samba Member
Joined: January 06, 2006 Posts: 316 Location: St.Petersburg Florida USA
Posted: Wed Sep 18, 2013 6:02 am Post subject: |
Permit me to help you help yourself.
(Give a man a fish and feed him for a day, teach a man to fish, and feed him for a lifetime).
Go to the top of this page and find the tab "Technical"
Under that tab, select "Owners Manuals"
When that page loads, look down the page for "Thing" and under that, select "Owners Manuals / Parts Manuals".
When that page loads, look down the page to "Parts Manual" and select that.
When that page opens, look for the link "Thing Parts Manual - PDF" and open that.
This is an invaluable tool for Thing Owners that all should have in their collection. Inside this document, go down to the 126th page to find the picture that is shown in the above post. Then go to the next page (page 127) for the parts list for that page. Look for item #4 to find your part number and description that you are looking for.
Easy Peasy. _________________ Jerry Henning
Southern Classic Works
St.Petersburg, Florida
1973 VW Type 181 with 616/33-6 powerplant
1962 356B-T6 Cabriolet Rustbucket |
Posted: Wed Sep 18, 2013 6:38 am Post subject: |
tallman206 wrote: |
Easy Peasy. |
Couldn't have said it better myself. No, really,.....
However, in all fairness.
I seriously doubt that the 181 cables are still available. You may be able to use a set of Beetle cables and modify them to fit. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Wed Sep 18, 2013 7:39 am Post subject: |
Semper_Dad wrote: |
tallman206 wrote: |
Easy Peasy. |
I seriously doubt that the 181 cables are still available. You may be able to use a set of Beetle cables and modify them to fit. |
TTS has a listing for this item:
http://www.thethingshop.com/prodinfo.asp?number=133711717 _________________ Ghia Owner Emeritus |
Posted: Wed Sep 18, 2013 2:02 pm Post subject: |
Those are standard heating cables that go back to the heater boxes. I was referring to the defrost cables (P/N 181711713). I don't see why you couldn't modify (shorten) 133711717 and turn it into a 181711713) _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Banker Samba Member
Posted: Wed Sep 18, 2013 2:03 pm Post subject: |
Thanks for the directions on how to find. Easy Peasy, sometimes once you know. This will help in most cases, but I need Part 4 which on the diagram 181 711 713 cable for footwell heating, rear. Will part number 5 work? Is the one end the same and just cut the other end off?
Is there a beetle cable number that someone else has used? ie 111 711 713A?
07 Charger Sublime
03 Goldwing
74 Thing |
Posted: Wed Sep 18, 2013 2:07 pm Post subject: |
Banker wrote: |
....., but I need Part 4 which on the diagram 181 711 713 cable for footwell heating, rear. Will part number 5 work? Is the one end the same and just cut the other end off?
Thanks |
I've never had to do that yet but it seems like an easy modification to shorten a 133711717 into a 181 711 713. Let us know how it works out. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
