THINGONER Samba Member
Joined: April 13, 2008 Posts: 674 Location: riverside ca
Posted: Mon Sep 09, 2013 12:54 pm Post subject: Oil cooler fan power supply |
Is it ok to run a power wire to my oil cooler fan from the positive side of my coil or is this a bad idea? I would be using an inline fuse-thank you. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Mon Sep 09, 2013 1:13 pm Post subject: |
Its a switched 12v power line from ignition. Since you are putting on an inline fuse, your good to go. I have hooked up fuel pumps to that same service line. No ill effects.
I installed an ext 6 position fuse block for extra electronics, radio, amps, gauges, etc. If you intend to do the same, might be a good idea to put one in. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Mon Sep 09, 2013 1:20 pm Post subject: |
Ok great news thank you for replying! |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Mon Sep 09, 2013 1:47 pm Post subject: |
Any idea how many amps the oil cooler fan draws? Perhaps it should have a heavier gauge wire direct to the battery and a relay if you want it off when ignition is off. _________________ 1958 Karmann Ghia owner |
SRP1 Samba Member
Posted: Mon Sep 09, 2013 2:13 pm Post subject: Re: Oil cooler fan power supply |
THINGONER wrote: |
NO....Not a good idea. You will not have enough current to operate both the fan and the ignition. The voltage drop on that line over such a long distance is bad enough as it is, it's just barely enough juice to power the stock ignition and that's it. On top of that the fan can act like an alternator as it spins down, it will back feed the coil and the engine will remain running until the fan comes to a stop unless you install a diode.
The way to wire your fan is to install a fan relay with diode (anywhere near the fan is good) and use a wire from the coil + switched on lead to the relay to activate the relay. All main line power comes directly from the battery and goes directly to the this way (fuses as needed of course). The minimal amount of power needed to activate the relay will not effect the ignition power. |
Posted: Mon Sep 09, 2013 2:51 pm Post subject: |
Ok so instead of going directly to fan run that same power wire from coil to a relay and then power fan from relay-does the relay require more than one power wire? Also where would I purchase this relay?-thank you |
rays-64 Samba Member
Joined: April 02, 2010 Posts: 343 Location: corona, CA
Posted: Mon Sep 09, 2013 3:34 pm Post subject: |
I have my fan wired directly to the starter extra terminal with a fuss. The fan does stay running for a couple of minutes after ignition is turned off. |
SRP1 Samba Member
Posted: Mon Sep 09, 2013 8:48 pm Post subject: |
THINGONER wrote: |
A fused power wire will go directly from the battery to the relay then on to the fan. The relay is nothing more than a high amp switch. The wire from the coil simply triggers the relay which takes very little power to do. Once triggered power travels through the relay and onto the fan. This way the load does not go through your vehicles wiring which is not capable of supporting that type of amperage draw.
Here is a diagram from this site off of a different thread.
The relay is a universal 12 volt 30 amp relay, looks like a black ice cube and.they come in 4 or 5 prong. Does not matter which one you get there both the same in your case. They are available at most any auto parts store. Just ask the counterman for a 12volt 30 amp.relay, you want the one with the mounting tab. If he looks at you like you speak a foreign language just ask for the manager, this is a very common part. A quick search on google.will give you dozens of.sources.
Here's one, but again local parts store is the easiest.
http://m.delcity.net/store/Relay-&-Socket-Harness-Kit/p_72563 |
Posted: Mon Sep 09, 2013 10:26 pm Post subject: |
Ok-thank you! |
Dale M. Samba Member
Posted: Tue Sep 10, 2013 7:09 am Post subject: Re: Oil cooler fan power supply |
SRP1 wrote: |
THINGONER wrote: |
Ditto....
And wire per sketch....
woodoctr Samba Member
Posted: Tue Sep 10, 2013 9:21 pm Post subject: |
Yep, that drawing is the same way my rotary conversion is set-up with my oil cooler. I also incorporated an adjustable fan switch so I could control my on and off temp.s. It's the type that uses a probe through the fins. Working with a non-contact laser probe I was really able to fine tune when that fan comes on and off. |
