veeduboscar Samba Member
Posted: Fri Mar 20, 2020 5:33 am Post subject: steering column lenght |
Good day to you all,
having to be confined these days indoors,I finally have the time to tackle the task of sorting out my column and steering wheel, that I have left until I could get hold of the correct one....
Is a bug 1960 year, and it has the steering wheel of a karmann ghia,which is sort of "flat" and has a lenght in between its back and the dashboard of 12centimetres.when I put the vw wheel it is going to come forward too much, so I guess the column is too long.
Could anyone know the total lenght of the column or at least the distance between the back of the wheel and the dashboard?
I`ll try to insert a pic to be more clear...
thank you guys and take care!
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Fri Mar 20, 2020 6:02 am Post subject: Re: steering column lenght |
See how much adjustment that you have at the T on the column and the steering box. If not enough, you can cut the end off the inner shaft and deepen the slot and add an new groove for the bolt. We are going to be doing that in the next day or two for a Manx clone buggy. fro how much you are changing, you don't need to do anything with the outer column. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Fri Mar 20, 2020 6:17 am Post subject: Re: steering column lenght |
Hello andk5591 and thanks for your answer ! yes I'll do what you suggest,which is what I had in mind.....I was wandering what distance should <i keep fron the dashboard to the back of the wheel .....I can only see some pics in the net and I'm just guessing thru them...
thanks a lot and good luck with your Manx, I love them too |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Fri Mar 20, 2020 6:58 am Post subject: Re: steering column lenght |
As you know, looks like a 1958-59 Karmann a Ghia steering wheel. Therefore, you must have a Pre ‘59 steering column and tube installed.
A 1960 wheel uses a different column & shaft. The splines are not the same as Pre ‘59 _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Fri Mar 20, 2020 7:31 am Post subject: Re: steering column lenght |
You can remove the T and the steering coupler. Loosen your column suppirt bracket (spray a little window cleaner or something on the outer shaft so you can slide it easier). Then you should be able to slide in to see what distance is comfortable. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Fri Mar 20, 2020 9:16 am Post subject: Re: steering column lenght |
Thank you Rareair, I believe you are right. It happened to me in a 58 I had,that the steering wheel and the shaft had different splines, one coarse, and one fine.I found an old guy that worked for VW and he told me that at some point they do that in order to have a finer regulation of the position of the wheel and allthough different splines,you could still fix it properly and whith the nut tighten, it would not be a problem. I did just that and never had an issue. So I don`t know exactly if that was true, but I'll chech in this one... |
Posted: Fri Mar 20, 2020 9:19 am Post subject: Re: steering column lenght |
Thanks Andk5591, I`m gonna do just that...seen a couple of pictures and have an idea what should look like!
cheers |
Posted: Fri Mar 20, 2020 12:33 pm Post subject: Re: steering column lenght |
well, having pulled all apart, the actual difference is not only in the splines (corase shaft, fine wheel) but in the diameter. The shaft is 24mm while the steering hole is 20mm. so I'll have to sort out that first. Thanks again for your help fellows |
Posted: Fri Mar 20, 2020 6:18 pm Post subject: Re: steering column lenght |
veeduboscar wrote: |
Yup, exactly what I was referring to. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Sat Mar 21, 2020 3:24 pm Post subject: Re: steering column lenght |
The splines were no problem, length is different, but it gets solved, diameter is more important and found out that there at least 3 different diameters looking in to the pile of old vw materials(you can not get this new here) 24mm ,21,5mm and also 17,5 that looks like brazilian made vw.I |
