awalls Samba Member
Joined: March 21, 2005 Posts: 128 Location: Beaverton, OR
Posted: Mon Sep 09, 2013 7:48 pm Post subject: Positive battery cable issue |
So I went to start my bus this morning and it barely clicked before it acted like the battery was dead. No power to anything. So I swapped the battery out, assuming it was a dead battery (7 years old ) and the bus started right up. Problem solved... Wrong! It started fine for two more starts then bam, acting dead again. I measures the volts across the battery,12.56. So I reconnected the positive again and it started right up. Then I tried a second time to start it and same issue again, dead. I loosened the positive cable on the battery and wiggle it, problem solved... I can do this over and over again with the same results. What might be the issue? Could it be the starter? Or maybe just a shirt in the cable? Any help would be great. Thank you. _________________ '64 Bug
'58 Kombi |
CoastalAirCooledVW Samba Member
Joined: September 02, 2012 Posts: 1882 Location: Mckinleyville, CA (Humboldt County)
Posted: Mon Sep 09, 2013 7:57 pm Post subject: |
I suppose there could be a shirt in the cable but I dont see what that has to do with your bus. The cable has probably worn through somewhere or there is corrosion on either end. Time to climb under and check it out. Battery cables are cheap to replace _________________ 1966 Velvet Green Standard |
awalls Samba Member
Posted: Mon Sep 09, 2013 8:10 pm Post subject: |
That's what I figured. I didn't have time today to investigate too much and it was dark by the time I got home. I figured I would replace the cable this weekend. _________________ '64 Bug
'58 Kombi |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Tue Sep 10, 2013 8:52 am Post subject: |
Check your ground at the battery, ground bolt, and ground strap under the bus too. |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Tue Sep 10, 2013 9:15 am Post subject: |
It's the cable. Look at the connection at the starter or if you have one of those cheap aftermarket clamps on the battery end.
I just had to do this, a few months ago. _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Single carbs are for lawn mowers! |
Don't forget those seat-belts!
Click to view image |
