oneeyedducky Samba Member
Joined: May 04, 2012 Posts: 79 Location: SOUTHERN CALIFORNIA
Posted: Tue Sep 10, 2013 8:08 pm Post subject: Speedwell Replica of 1952-53 Porsche America roadster sump |
anyone bought one of these replicas of a 1952 - 1953 Porsche America Roadster sumps made to fit 25hp-36hp engines,from ray schubert of Speedwell USA? im thinking about picking one up. curious what the baffling looks like inside and how much better it cools the engine? |
Posted: Wed Sep 18, 2013 8:02 pm Post subject: |
Bueller, bueller? _________________ 1961 would have no sticker on the windshield washer tank, as that was the one-year-only style of "jack-off-the-wiper-knob-to-get-windshield-spray" on German made models. It was 1962 that introduced a pressurized system. |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Sun Sep 22, 2013 7:57 am Post subject: |
Sumps (even the 3 1/2 and 4 quart units) don't usually contribute much to cooling; their purpose is to provide extra oil for the engine's higher revving capabilities and when the car is driven hard enough to uncover the pick-up in a stock motor. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Sun Sep 22, 2013 8:01 am Post subject: |
ALB wrote: |
Sumps (even the 3 1/2 and 4 quart units) don't usually contribute much to cooling; their purpose is to provide extra oil for the engine's higher revving capabilities and when the car is driven hard enough to uncover the pick-up in a stock motor. |
It requires more heat to raise the temp on 5qts of oil than it would compared to 3qts. So an oil sump does aid in some cooling
What your describing can be done with a windage tray installed inside the engine block _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
ALB Samba Member
Posted: Sun Sep 22, 2013 10:47 am Post subject: |
RareAir wrote: |
ALB wrote: |
What your describing can be done with a windage tray installed inside the engine block |
While your statement about it requiring more heat to raise the temp of 5 qts of oil than 3 is correct, I (and others) have found that it simply takes the motor longer to reach it's operating temp. If the motor was overheating before the addition of a sump then it will overheat in the same conditions with it; it will just take a little longer to get there. Yes, a sump may drop oil temps a couple or very few degrees, but that's not what it's for. And if you think the simple addition of a windage tray with 2 1/2 quarts of oil will protect your motor through a slalom course or long curved freeway entrance ramp with a 6-7,000rpm blast of the motor, you're sadly mistaken. I gather you're referring to what's possible with Vee motors, but there's way more involved in case modifications than simply bolting in a windage tray. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Sun Sep 22, 2013 8:46 pm Post subject: |
Herein lies the problem with my speedwell sump.
The 36hp oil pick up tube is about 1/2 in.outside diameter, the speedwell pickup tube extension is about 7/8 In. Inside diameter. There's no way they will seal. I'm not sure of the solution from here? _________________ 1961 would have no sticker on the windshield washer tank, as that was the one-year-only style of "jack-off-the-wiper-knob-to-get-windshield-spray" on German made models. It was 1962 that introduced a pressurized system. |
Posted: Mon Sep 23, 2013 7:13 pm Post subject: |
Any ideas?
Should u remove the baffle tube, weld hole shut,
Drill a hole and replace with smaller tube that I braze to the baffle which would slip fit over the small 36hp oil pick up tube? _________________ 1961 would have no sticker on the windshield washer tank, as that was the one-year-only style of "jack-off-the-wiper-knob-to-get-windshield-spray" on German made models. It was 1962 that introduced a pressurized system. |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Thu Sep 04, 2014 10:54 pm Post subject: |
Are these sumps available for sale? If so, how much are they?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
56 VDUB Samba Member
Joined: May 28, 2013 Posts: 121 Location: Sydney, Australia.
Posted: Fri Oct 24, 2014 9:45 am Post subject: |
I want one for sure! I don't see any reference to these sumps on the Speedwell website though? _________________ .
My 1956 RHD Aussie Beetle ll (o\!/o) ll
Sydney, Australia |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Fri Oct 24, 2014 12:35 pm Post subject: |
oneeyedducky wrote: |
The 36hp oil pick up tube is about 1/2 in.outside diameter, the speedwell pickup tube extension is about 7/8 In. Inside diameter. There's no way they will seal. I'm not sure of the solution from here? |
Make a adapter from a piece of 1" aluminum round bar, turn it down to fit the sump leaving a shoulder to prevent it from sliding down into the sump, turn some grooves on the OD for O rings, then drill the center of the bar to the pick up size, you could put a O ring in side but I would just epoxy it to the pick up, make sure to cut a inverted flare to the inside to make a smoother pass for the oil.
I made my own round sump but I did it from flat plate I cut on the waterjet machine and a piece of aluminum tube and welded it together. I turned the bottom to give some affect but it wasn't enough I think, it looks a little boxy compared to a cast one...
Maybe some day I will finish it.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Sat Oct 25, 2014 2:13 am Post subject: |
earthquake wrote: |
Casey |
Hmm, doesn't look much more boxy in appearance than the Speedwell one. Other than possibly machining the grooves a little deeper, it looks awesome! I wish I had access to all the machinery necessary to fab one up and I probably would! _________________ .
Sydney, Australia |
Posted: Thu Oct 30, 2014 4:03 am Post subject: |
I wish I still had access too, the shop where I worked closed there doors.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Posted: Sat Nov 01, 2014 9:47 am Post subject: |
I'm not sure of the real preformance benefits of it, but they look killer on a 36! Why does nobody else make these? Seems like they would be quite popular considering the popularity of 36hp parts like the okrasa kit nowdays! Seems like it would be a good addition to the Wolfsburg West product line! _________________ .
Sydney, Australia |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Mon Dec 08, 2014 8:32 am Post subject: |
Yeah, I was looking at those a while back, I think the reduced temps would be mild to minimal with any deep sump on a 36, so having the vintagespeed look of the round sump would probably be 90% of the reason to shed out the cash for one......... for me anyway! _________________ .
Sydney, Australia |
GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
67zoly Samba Member
Joined: October 07, 2004 Posts: 17 Location: Big Sky Country
Posted: Sat Sep 17, 2016 12:48 pm Post subject: Re: Speedwell Replica of 1952-53 Porsche America roadster sump |
Finally getting around to my '57 build and I have the full Speedwell Pepco setup including the beehive...Just looking to see what possible fix you may have come up with for the baffle to pickup transition...Or is anyone has a suggestion...Looking for a clean install into a Mr. Okrasa shortblock...I want to avoid splitting case...Thanks |
67zoly Samba Member
Posted: Thu Oct 13, 2016 2:14 pm Post subject: Re: Speedwell Replica of 1952-53 Porsche America roadster sump |
Anyone...OS O-Ring? I am struggling to understand why they fabricated it with such a large OD tube on the baffle compared to the stock PU tube.. |
Posted: Thu Oct 13, 2016 7:32 pm Post subject: Re: Speedwell Replica of 1952-53 Porsche America roadster sump |
67zoly wrote: |
I'd probably weld or braze a washer with the right ID on the end of the pickup and weld in a new pipe inside of it, the right size for the case.... thats what I'd do anyway.... _________________ .
Sydney, Australia |
