syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Thu Sep 12, 2013 10:45 pm Post subject: |
Thank you.
Now back to your regularly scheduled programming.
Thanks for sharing 0cean |
0cean Samba Member
Joined: February 29, 2012 Posts: 1149 Location: California
Posted: Thu Sep 12, 2013 10:52 pm Post subject: |
Phishman068 wrote: |
NICE!!!
There isn't a "bolt pattern" on the vanagon sender, it simply is held in place by putting it in and giving it a quarter turn compressing an O ring under a tapered sleeve. |
Thanks for the info. We are working on different capacitors and it’s just a matter of finding the right one. It will be posted here for sharing the info.
big swifty wrote: |
Nice! Where are you going to put the smaller gauges? |
I currently have some VDO gauges under the stereo area. They will be replace with the new gauges.
Franklinstower wrote: |
For the printed circuit board, These guys will make three boards for you at a cost of $51.
http://www.expresspcb.com/
Paul |
Thanks for posting that. I couldn’t find there web site when I was writing this up.
syncroluvr wrote: |
Very cool and your van held together at close to 100 MPH! (158Km/h) Congats! |
Had the van up to 90mph one time on my way to las Vegas. Little scary even for a guy that use to drive the autobahn to work for years.
greenbrier62 wrote: |
This is exactly what I was thinking about doing...Glad you were able to see it through to completion! Speedhut in UT are nice folks. I called them about a month ago asking about their gauges...I'll be using this write up for sure when I pull the trigger. WELL DONE! |
If you do use there gauges wiring them up is easy, not much to them at all. Its the foil thats the problem. I guess if you really wanted to, you could leave the foil back there and tap into the wiring harness that plugs into the cluster for signals and power. I almost went that route, but i wanted the water light and a clean cluster. It could be done though.
obieoberstar wrote: |
awesome upgrade and well documented.
I looked at the website for the gauges quickly. I would assume the gauge has an internal GPS receiver based on the price. Correct? |
There is an external magnetized GPS. I have it right in front of the cluster near the window. Can’t tell it’s there are all. The GPS looks the same as a Sirius receiver. Small and black. |
0cean Samba Member
Posted: Fri Sep 13, 2013 6:33 pm Post subject: |
Anyone know about a small box that was used on Fords to regulate the fuel gauge? I may be able to get one, but I don’t know anything about it or if it would work. |
0cean Samba Member
Crankey Samba Member
Posted: Sat Oct 05, 2013 5:50 pm Post subject: |
man that's really cool.
I want a pair of LED's above the clock for left/right blinkers.
and I don't want the clock.
doesn't speedhut have a tach with additional small gauges in it too ? |
0cean Samba Member
Posted: Sat Oct 05, 2013 10:03 pm Post subject: |
yeah I looked, they sort of do. speedo/tach combo with a second 4 way gauge all the options are cool too. |
0cean Samba Member
AdrianC Samba Member
Joined: January 13, 2012 Posts: 526 Location: Wherever the road's gone
Posted: Sun Oct 06, 2013 10:29 am Post subject: |
GPS speedo...?
So, umm, what happens when you're going through a tunnel? Or an "urban canyon"? Or under trees...? Or any of the multiplicity of situations where GPS loses signal?
Does it have some kind of signal strength/number of satellites display?
How long does it take to get a fix when you first start up? _________________ Adrian
Zookeeper of a miscellany of motoring silliness, from 0.75bhp to 9ft tall.
Living life on the road in an '88 2.1DJ Westfalia Club Joker Hightop.
www.WhereverTheRoadGoes.com |
Posted: Sun Oct 06, 2013 11:13 am Post subject: |
I don't know, interesting point though.
I did call speedhut to see if there is any way to integrate some kind of GPS pinger function that could be tracked by a cell phone when we had several stolen van threads pop up. adding that function would be super sweet I think.
aside from that I like the idea of getting rid of the speedo cable bump on the grease cap.
now I want a spare instrument pod to modify. maybe Oceans electronics buddy can work up a kit of some kind to wire these things up.
seems like the instrument cluster North Westy was working on might be using these gauges, they looked similar. |
Posted: Sun Oct 06, 2013 11:19 am Post subject: |
Crankey wrote: |
I did call speedhut to see if there is any way to integrate some kind of GPS pinger function that could be tracked by a cell phone when we had several stolen van threads pop up. adding that function would be super sweet I think. |
"GPS" just means it receives signals. No more than that. There's nothing to ping back to on the GPS satellites, and nothing in the receiver that could ping back anyway. "GPS trackers" have a cell phone effectively taped to them to do that side of the communication. The "GPS" bit, as with a satnav, just tells the rest of it where it is. _________________ Adrian
Posted: Sun Oct 06, 2013 3:31 pm Post subject: |
that's sort of what they told me, but still it seemed like a good idea |
0cean Samba Member
Posted: Sun Oct 06, 2013 4:28 pm Post subject: |
AdrianC wrote: |
GPS speedo...?
How long does it take to get a fix when you first start up? |
That was my concern also, but so far it hasn’t been an issue. One time I whent under a large bridge and noticed the speedo stayed in place for a split second. Canyons and trees havent cut the signal at all even in Mexico's wine country. Im sure if im go through a tunnel the speedo reading will just stay in place until it reaches the end. No biggie to me because it has been really nice to have so far.
The startup has been about 30-45 seconds if the van has not been started in more than 4 hours. It’s always been on before I start moving. If under 4 hours the startup is instantaneous.
Crankey wrote: |
You can always send him an email about it. I did the psycial part of installing the gauges into the instriment pannel, but I bet he could do it with no problems. I have to admit it cost me north of $800 to get this cluster right. Not easy mod at all, but the best one I have done so far and it was well worth the time, money and frustration. Im stoked on the little guy... _________________ I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3) |
westylife Samba Member
Joined: October 28, 2007 Posts: 409 Location: Anchorage, Alaska
Posted: Tue Nov 05, 2013 12:03 pm Post subject: |
this is awesome. Great job! Does anyone know how this might work with a Bostig kit? _________________ 1983.5 Westfalia Bostig RG1 |
WandS Samba Member
Joined: January 05, 2007 Posts: 228 Location: Miami, Florida
Posted: Sun Dec 08, 2013 6:41 am Post subject: |
westylife wrote: |
this is awesome. Great job! Does anyone know how this might work with a Bostig kit? |
I second this. _________________ 85 Westy Weekender with a Bostig Conversion. |
0cean Samba Member
Posted: Sun Dec 08, 2013 9:44 am Post subject: |
My guess (I'm not a mechanic, just a tinker-er) is that it would work the same way as mine. Tach signal into the tach and the just program the revolutions. Subaru 2.2 setting was 2.
The whole cluster has been great over time. No glitches or down sides to report. _________________ I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
Posted: Mon Dec 09, 2013 5:23 pm Post subject: Shift light |
Ocean,
Do you find the shift light at all distracting? Would you keep it or get one without the shift light?
Thank you, _________________ 1983.5 Westfalia Bostig RG1 |
fraggle00 Samba Member
Joined: October 19, 2011 Posts: 356 Location: Bristow, VA
Posted: Mon Dec 09, 2013 7:55 pm Post subject: |
Very cool setup, now I want a spare, too! _________________ '91 Vanagon Carat
'87 Porsche 928S4 DOWN
'12 Fiat 500 Abarth |
0cean Samba Member
Posted: Mon Dec 09, 2013 9:23 pm Post subject: Re: Shift light |
westylife wrote: |
Ocean,
No, but its a little on the bright side. The lights are all programable so you could just leave them off if you wanted. Im using it as a speed indicator by having them set to 3,9000 rpm (76 mph in forth gear). Helps my MPG by controlling my lead foot. _________________ I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
1vw4x4 Banned
Posted: Wed Dec 03, 2014 1:27 pm Post subject: |
This is a very good mod. specially since my 2wd syncro does not have
a speedo. Exactly what I need! I just purchase the 80 MPH, with tach
setup off the web page. Can't wait until its here. My 2wd syncro will be complete again, and have the latest technology without mickey mousing things.
As for the fuel gauge, the signal you get from the sending unit is exactly
what you are seeing. Basicly they bounce all over the place. Most fuel gauges deal with this at the gauge. If you understand how a fuel gauge works it all makes sense. The factory gauges work as a heater. This averages the feedback from the fuel sender. What your going to do is not
going to be easy or cheap, that why the factory did it the way they did. |
