dashboard instruments and switches
safariboy
safariboy is offline
PostPosted: Thu Sep 12, 2013 10:34 pm    Post subject: dashboard instruments and switches Reply with quote
I have a 74'.
On the left side of the dash, I have a RPM gauge with two toggle switches above it. What are these switches for? When I switch the left one....nothing. When I switch the right one, the small yellow dash light lights up.
Can someone insight this newbie
I have looked at pictures but could not find the instrument configuration that I have(stock)
Thanks for all your help
ThingOw181
ThingOw181 is offline
PostPosted: Fri Sep 13, 2013 12:14 am    Post subject: Reply with quote
Post a picture in the gallery if you can. The tachometer and switches definitely aren't stock. And what small yellow dash light do you mean? Take a picture of that too.
safariboy
PostPosted: Fri Sep 13, 2013 10:12 am    Post subject: Reply with quote
The two switches are on the far left of the dash above the tach. The right switch turns on a yellow dash light on the far right of the dash above the fuel gauge. Not stock?
Semper_Dad
Semper_Dad is offline
PostPosted: Fri Sep 13, 2013 10:22 am    Post subject: Reply with quote
Very Little on that dash is stock.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
Deckard
Deckard is offline
PostPosted: Fri Sep 13, 2013 10:51 am    Post subject: Reply with quote
The "yellow dash light" is the master cylinder brake warning light, but under no circumstances that should be switch activated... Your fuse bank is also where the ashtray should go. Here is a picture of my stock '73. It should only have the light switch, gasoline heater control, Speedometer, “accessory” 12V receptacle, emergency flashers, brake warning light.
Deckard
Deckard is offline
PostPosted: Fri Sep 13, 2013 10:59 am    Post subject: Reply with quote
And yours should not have the Gasoline Heater, it's kind of rare on a '74
kubelmann
kubelmann is offline
PostPosted: Fri Sep 13, 2013 11:27 am    Post subject: Reply with quote
I am doing a resto on a 74 that has a gas heater right now. It was owner installed prior to the current owner's possesion of the car. The heater is a BN-2
safariboy
PostPosted: Fri Sep 13, 2013 1:32 pm    Post subject: Reply with quote
It doesn't have a heater, but I have yet to see this dashboard configuration yet in the gallery. Also, I can't read those illuminated little rectangle lens. They light up at start.
Semper_Dad
PostPosted: Fri Sep 13, 2013 2:41 pm    Post subject: Reply with quote
Your not going to find them because it's a PO (Previous Owner) install. Just a guess here but I bet the retangular lights are for your Oil, Gen, high beam, or turn signal indicators.
You may want to sort out which light goes to what. Turn and high bean should be easy enough. Easist way to figure out which goes to the oil pressure would be to turn the ignition to on (but don't start car). Then go to the back of the car and pull the wire off the oil pressure switch. Oil pressure light should go out. Gen light will remain on.
Rev. Scott
Rev. Scott is offline
PostPosted: Fri Sep 13, 2013 6:56 pm    Post subject: Reply with quote
Not factory! Chase the wires. May have had fog/driving lights at one time. I wire mine with a dash indicator light too. The wires will be very un-factory, which should make them easy to follow.
"I haven't seen one of those since I was shootin' at 'em!"
