JMuckian Samba Member
Joined: August 28, 2013 Posts: 4 Location: Tacoma, WA
Posted: Fri Sep 13, 2013 11:47 pm Post subject: Automatic Differential oil plug? |
New Westy owner, and I've discovered that I have an oil leak from my automatic differential. I was looking at possibly fixing it myself, but have had difficulty in finding much information on replacing the oil on the differential part of the A/T... particularly where the fill plug is. I at least want to be able to check the level/add oil.
I think I found it today, and would like some independent verification if it's not too much of a bother. So, is it this thing here with the huge hex head indicated by the arrow?
Thanks. |
MSmyth Samba Member
Joined: September 02, 2008 Posts: 39 Location: Morgantown, WV
Posted: Sat Sep 14, 2013 3:29 am Post subject: |
That's it... drop the pan, check the magnet for filings, replace with new gasket, refill at that plug with gear oil (I like Royal Purple). From your picture it looks like the PO tried to seal with silicone.
I made a tool for pulling that plug with the appropriate sized bolt head (I don't recall the size) maxed out with nuts and lock washers... worked like a charm.
Edit: The plug takes a 17mm hex. _________________ Current driveway art:
1984 Westy / Bostig
2013 Toyota Prius Plug-in
1979 Land Rover Series III 109 Safari
2000 Dodge Dakota 4x4 Magnum
2004 Range Rover HSE (latest project... looking for a motor!) |
Posted: Sat Sep 14, 2013 9:31 am Post subject: |
Awesome. Thanks for the verification, and the info on getting in there an replacing that gasket. One other question...
... I think I may have a leak from the oil governor on the other side of the differential. I know there's a seal in there, but how easy is that to fix? Can it be done without dropping the transmission? |
