Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1867 Location: Pittsburgh PA (ish)
Posted: Tue Oct 01, 2013 5:32 pm Post subject: |
I pulled the lifters and the ones I thought to be soft were infact, quite hard to push in still, so I believe they're fine.
After a long day of cleaning things up, I got the heads on!
This feels like a big accomplishment, as it means things are finally coming together rather than being torn apart.
Rather than painting all the accessories body color, I chose to go the easy route and went with hi temp engine paint in semi-gloss black. I was able to get a good deal on a few cans, and threw down some paint.
Tomorrow I can start bolting things back on!
The engine I am using is out of a 1990 manual transmission van and it's going into a 1987 automatic van. So, I replaced the main seal with the "proper" one, checked the endplay to be the same, and went to bolt on the flex plate. However, I couldn't get the pilot bearing out.
Upon examining the engine originally in the automatic van i discovered it has a pilot bearing in place (AND A FLEX PLATE!), so apparently the engine isn't original to that van, and apparently you can run an automatic transmission with a pilot bearing still in place???
Does anyone know this to be the case FOR SURE?
I will be switching over the lower studs as well, as I know they're different. _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry." |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
randywebb Samba Member
Posted: Fri Oct 04, 2013 2:50 pm Post subject: |
worn throttle body _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Fri Oct 11, 2013 6:08 am Post subject: |
Well The engine and trans were assembled and put back in the bus!
It turns out this engine was def out of a manual trans car. The lower engine studs from a manual trans engine still work on an automatic if you stack 4 washers on each stud. The pilot bearing can remain as well.
Well I bolted the whole thing in when I had a chance to get some extra hands, and it only had a few things left to take care of. I needed to install the exhaust and Timesert the oil drain plug. When the engine was out I tapped all the bolt holes in the heads and chased the studs. One hole wasn't so good so I stuck a helicoil in it.
Anyway, I was assembling the exhaust yesterday, excited and anticipating getting it running....
when "BANG".
As I tightened the bolt, the piece of the head popped off. This was not the hole that was helicoiled.
Bummer.
Ruined that head......
I guess my options are to either replace that head with the engine in place, using a used head I have lying around that came off a running engine (Small crack between valves but seems to hold its Laquor Thinner well), or find a known good 2.1 and stick it in.
The problem is the bottom end of this engine is somewhat unknown, and If I put a whole bunch more effort into bringing this beast to life and it ends up with oil pressure problems or similar, i'll be stuck.
Is it possible to reuse a head gasket? It's never been run.
What about the compression gaskets atop the jugs?
Winter is coming. The syncro will be parked and this bus has to become my daily driver.....
And I still know nothing about the condition of the transmission, bearings, suspension, or brakes..... _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
Posted: Fri Oct 11, 2013 8:58 pm Post subject: |
Well, life's improving my Lemonade Recipe daily!
It looks like this engine will be getting one of the heads back that came off it (Engine not original to the vehicle now). These heads are in "ehh" shape, including some pitting, cracks between the valves, and seized studs/bolts. Both heads did hold their laquor thinner for at least an hour though... So they're usable.
I took out the first head that seemed to hold its laquor a bit better. I cleaned it all up, Removed all the bolts/studs except one that broke off, and prepared to drill that out. I did everything right, ground it flat, center punched, put it on a drill press in a level jig, drilled a pilot hole, then started to drill.
Things were going well, Then somehow the bit wandered and ate into the aluminum.
So..... that head's no good now.....
SO I guess i've got to try the other one. Luckily it turns out this head was in a bit of better shape. The bolts and studs all came out with NO thread damage (no need to helicoil, SCORE!) and the cracks between the valves (really only on one side) is well within VW spec. There are no pits within the combustion chamber area.
It cleaned up nicely and it's time to fill the pits.
This is my recipe for filling pits, which has worked well in the past.
First, clean things up with a SOFT wire brush and a can of brake cleaner.
Then tape off the areas you Don't want JB weld. Do a good job, as JB Weld is tough stuff once its hardened!
Mix up twice as much JB weld as you think you'll need:
Apply the JB weld with a small plastic body filler wedge. Use alot of pressure as you pull it along, forcing it into the pits.
Once you have a layer all the way around, scrape off the remaining with a single edge razor blade using the same pressure to remove any excess. You want to leave only the stuff in the pits.
The end result:
Remove the tape while it's still wet and clean up the edges so you're left with only the JB weld in the pits.
Let it dry overnight.
Tomorrow, the sanding begins..... _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
Posted: Tue Oct 15, 2013 5:42 pm Post subject: |
Well, I got that head all cleaned up and installed, reusing the head gaskets (they had zero miles..... cleaned up the old goop and put on new stuff).
Before using this head though I made sure I had all the bolts out, all the holes tapped, etc.
Except.... the spark plugs.
Well now that it's in place, guess what went wrong!?
Yep, stripped a spark plug hole.
Luckily NAPA has a very nice kit for repairing spark plug threads that has a timeserts style insert and it went together seemingly well.
My new NKG spark plugs are in and torqued.
I also rebuilt the axles using used boots and Redline CV-2 Grease. That grease really is sweet! Its significantly pastier than what i'm used to for CVs and it sticks really well.
Also my CV bolts came in. I tried and tried to find CV bolts available at a good price, perhaps in bulk, but to no avail.
Luckily my local NAPA was able to sell me bolts at a bulk price that was quite good.
The Bolts are 12.9 grade (stamped right on them) and the packages read made in Italy or Made in Czech Republic. Half and half. They look to be quite good, so I bought 50 of them. : )
The last thing to deal with is the coolant pipe from the water pump to the thermostat housing. I went through 5 used ones and 1 new one trying to put on this bus, all failed in some way. The new one was bent wrong and didn't fit, the used ones all failed at rust spots. Finally got a good used one, and its in good shape.
I cleaned it up like I do, removing the rust, treating with RUST MORT, and painting with High Temp Paint.
I hope to get the Timesert in the oil drain plug tomorrow, the exhaust on, and this sucker started up!
Hopefully things continue to move along.
I cannot find 7mm coolant hose anywhere, especially not in any usable quantities. With another bus yet to do, I'd like to buy a roll..... but I can't find any anywhere.
Anyone know of a source? _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
Posted: Thu Oct 17, 2013 1:14 pm Post subject: |
Phishman068 wrote: |
I thought they wear by wobbling?
So this throttle body is no good and not worth using?
Bummer. |
it can be refurbed - you trade it in for a refurbed one a la core charge type thing
even my on hwy fuel mileage improved when I put in a refurbed one
there is a guy here who does it (in batches IIRC) and Van-Cafe either does it or goes thru him _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Thu Oct 17, 2013 2:42 pm Post subject: |
Looks like i got it fixed.
Yep, that throttle body was worn. I stuck another known good one in thats off a very low mileage engine. Works great.
It now runs smooth as a whistle! The valve adjustment to 1.5 turns in made a surprising difference in the smoothness and quietness of the engine.
The transmission operates properly as well! I've driven it forwards and reverse. Power steering works (i've turned it around), and it's running pretty nicely. No oil pressure lights on, all warning lights are off, and the temps stay steady.
HOWEVER....
I think it's burning oil or coolant.
I theorize it to be coolant just in that I reused the Green Cylinder Gaskets when i swapped the heads and they surprisingly didn't look perfect upon removal (Despite having zero miles on them).
What's the best way to test for this?
Again, its running quite nicely. It hasn't even been fully tweaked or adjusted yet. It's only run 4 heat cycles of about 10-15 minutes each, so it's possible the smoke is still just internal crap burning off. Every time I bring a bus back to life I'm used to there being some nasty smoke and terrible smells at first, but generally it goes away about now.....
Thoughts? _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
wecm31 Samba Member
Joined: August 05, 2012 Posts: 358 Location: Eganville, Ontario
Posted: Thu Oct 17, 2013 5:17 pm Post subject: |
Just got one of these in the mail yesterday....
Got one?
http://www.harborfreight.com/cylinder-leak-down-tester-94190.html
Might help tell what is leaking from where... _________________ Gerald P
1985 Vanagon (Betty) & 1985 BMW R80RT (Wilhelm)
vintage boxers!!
Gone are the days we stopped to decide
Where we should go, we just ride:) |
