Trailing arm bushing
ronbug73
ronbug73 is offline
PostPosted: Thu Sep 19, 2013 5:36 am    Post subject: Trailing arm bushing Reply with quote
Hi
when do i know its time to replace the trailing arm bushing?
thank you
Ron
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Sep 19, 2013 7:38 am    Post subject: Reply with quote
Fronts? Almost never if you keep them greased.
Rears? Probably now. They work hard and deteriorate, so if you hear squeaking, or the rear alignment is off, or the end of the spring cover is not centered on the cover, the rubber is perished. Make a day of it and replace them, set the rear ride height and toe-out, and be amazed how much smoother it all works!
ronbug73
ronbug73 is offline
PostPosted: Thu Sep 19, 2013 8:52 am    Post subject: thank you Reply with quote
yes the rear one on irs.
KTPhil is offline
PostPosted: Thu Sep 19, 2013 8:57 am    Post subject: Reply with quote
I had a pair of squeaks and poor handling, and traced it to rotted rear torsion arm bushings and also diagonal arm bushings. Consistent alignment was not possible with all the slop. I replaced both (though all I could find for the diagonals was urethane--lube it well on installation!), set the height, and had the rear aligned. Quieter, better tracking, and I was no longer feeling small or large bumps as much. Definitely worth the effort!
You can take off the cover and see if the outer rubber is squashed or cracked.
ronbug73
ronbug73 is offline
PostPosted: Thu Sep 19, 2013 9:09 am    Post subject: irs arm Reply with quote
its not the ones of the rear Axel its for the irs arm
i mean this part.
http://www.kaeferland-shop.de/index.php?action=sho...3.10393585
KTPhil is offline
PostPosted: Thu Sep 19, 2013 9:56 am    Post subject: Reply with quote
That does not look like my diagonal arm bushings. They look like this (urethane shown, originals were rubber):
Yours might be for an IRS Bug, not late Type 3.
ronbug73
ronbug73 is offline
PostPosted: Thu Sep 19, 2013 9:59 am    Post subject: cip1 Reply with quote
at cip1 its the same part
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-113-501-541-C
for bug end type 3
gtixpress
gtixpress is offline
PostPosted: Thu Sep 19, 2013 10:31 am    Post subject: Re: cip1 Reply with quote
for bug end type 3
Between my two Type 3's that I've owned, neither had rear bushings that looked like that (with the metal piece mounted on it).
Joe P.
1969 VW Type 3 Squareback
2002 VW GTI 337 (Limited Edition)
2018 VW Atlas SE VR6 4Motion
2019 VW Beetle S Final Edition Convertible
KTPhil is offline
PostPosted: Thu Sep 19, 2013 11:42 am    Post subject: Reply with quote
Another part from CP1 that is more like what I remember:
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D4300
Brent
Brent is offline
PostPosted: Fri Sep 20, 2013 2:45 am    Post subject: Reply with quote
I used new rubber ones, same as what CIP is selling and they are the same as what was originally in there. You need to pound out the steel cups too. The rubber is bonded to the metal cup pretty good and they're a pain to get out of the trailing arm.
69 Fastback Build
Berg5 Build
vlad01
vlad01 is offline
PostPosted: Fri Sep 20, 2013 3:27 am    Post subject: Reply with quote
i bought these so i can cross reference the dimensions for superior ones made by fulcrum her in oz. Cheap(quality wise) ones fall apart easy, fulcrum (aka superpro) have knurling inside them for grease retention and the material lasts absolutely ages with years of abuse.
currently they have no kit for the diagonals for VW but a vast catalog of standard bushes to choose from. So I bought an example.
one day I might post them up if I do manage to find the bushes required.
ronbug73
ronbug73 is offline
PostPosted: Fri Sep 20, 2013 6:32 am    Post subject: thank you Reply with quote
when its time to do it together with the SPRING PLATE bushing?
or when taking out the sub-frame?
do i have to remove the engine?
witch leads to another question. when to replace the sub-frame 3 bushing
that connects to the body?
thank you
Ron
KTPhil is offline
PostPosted: Fri Sep 20, 2013 8:46 am    Post subject: Reply with quote
I would make a combo job of it... spring plate and diagonal arm bushings at the same time. Both can throw off your alignment, so this way you only align once, and you get your ride height correct as well. Read up on setting ride height so you are ready when the torsion bar comes out and you have to set it back correctly. I would measure your ride height now and if it is correct, mark the outer spline/hob with paint or a chisel, and be sure to NOT pull out the inner ends. In this case you don't have to even get out the bubble protractor.
No need to change the body bushings unless they are broken. It is not a friction surface like the other rubber bushings. Mine are original on my '71 and give no trouble.
Bobnotch
Bobnotch is offline
PostPosted: Fri Sep 20, 2013 9:45 am    Post subject: Reply with quote
Keep in mind that you'll need a couple of extra M10 bolts (10x1.50) that are about 3.5 inches long, and some spacers for them (that you can add as needed), to help get the spring plate cover back on. I only mention it, as I've found I needed to use them just for raising or lowering a type 3, and that's with used bushings. Wink
The hardest part will be getting the spring plate off the stop, and getting the diagonal bolt out. See the lowering thread for removing the spring plate, and the Bentley manual for the diagonal bolt.
Bob 65 Notch S with Sunroof
Tram wrote:
KTPhil is offline
PostPosted: Fri Sep 20, 2013 9:55 am    Post subject: Reply with quote
Yeah, it's a day's work but it will set you up for like 50,000 miles or more.
Read up first. And be ready to reset the torsion bars a couple of times to get it right. I have the Pieseler tool but it's still some trial and error if you want to dial it in exactly. Worth the effort for the ride and quiet and better alignment.
aaronsneary
aaronsneary is offline
PostPosted: Sat May 08, 2021 10:43 am    Post subject: Reply with quote
My mechanic pointed out that one of mine is missing. Besides the bushings and bolts, are there specific nuts required? I found the bolts and bushings on JBUGs.
