sonofamitch Samba Member
Joined: May 27, 2012 Posts: 325 Location: Evergreen, CO
Posted: Fri Sep 20, 2013 6:56 pm Post subject: What is this? |
This thing came off of the crankcase out of the hole shown. I'm not quite sure what it is. Can anyone help me out? Sorry for the bad quality pictures
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Fri Sep 20, 2013 6:58 pm Post subject: |
TDC sensor for obsolete VW diagnostic equipment. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Fri Sep 20, 2013 7:03 pm Post subject: |
VDubTech wrote: |
TDC sensor for obsolete VW diagnostic equipment. |
Thanks for the speedy response. So in other words, it does not need to go back in. |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Fri Sep 20, 2013 7:58 pm Post subject: |
Correct. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Sep 20, 2013 7:59 pm Post subject: |
But some detail oriented restorers may need it for cosmetic reasons, don't toss it out just yet. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Feb 13, 2014 10:36 pm Post subject: |
How do you remove it? _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Fri Feb 14, 2014 12:00 am Post subject: Timing Sensor |
BUSBOSS,
KNOCK IT OUT WITH A BRASS punch from the flywheel side & YOUR
safety glasses ON. _________________ V.W.owner since 1967 |
Posted: Fri Feb 14, 2014 7:25 am Post subject: |
I'm fairly sure it'll only come out towards the flywheel side, you have to pound on the end with the wire to remove it, usually requires breaking the black cone shaped plastic part off first. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Fri Feb 14, 2014 7:51 am Post subject: |
And leaves you with a hole to plug if you don't want things to get blown or accidently dropped into the area between the flywheel and case. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1881 Location: N.W. Georgia
Posted: Fri Feb 14, 2014 8:23 am Post subject: |
... unless any of you bus drivers out there with the T IV engine and the TDC sensor removed work on your bus standing on its nose, or you drive in reverse very very fast with the engine cover open, I can't see how having the opening unplugged would cause an issue. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
SGKent Samba Member
Posted: Fri Feb 14, 2014 8:35 am Post subject: |
Jeff Geisen wrote: |
... unless any of you bus drivers out there with the T IV engine and the TDC sensor removed work on your bus standing on its nose, or you drive in reverse very very fast with the engine cover open, I can't see how having the opening unplugged would cause an issue. |
it must be another snowy day in GA. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
curtis4085 Samba Member
Posted: Fri Feb 14, 2014 9:14 am Post subject: |
SGKent wrote: |
it must be another snowy day in GA. |
I would think most if taking a poll would recommend plugging the hole if you removed this item. Better safe than sorry. And if you seen all the nuts, washers, screws, sockets I've found toward the back area of the engine you would make sure it was plugged. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
SGKent Samba Member
Posted: Fri Feb 14, 2014 10:09 am Post subject: |
edited _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Fri Feb 14, 2014 11:43 am Post subject: |
Thanks Steve! _________________ I Corinthians 4: 1 thru 5
Posted: Fri Feb 14, 2014 5:46 pm Post subject: TDC Sensor removal |
Boy, did this thread go to hell in a hand basket
BUSBOSS asked how to remove the TDC sensor. He didn't ask how to ruin it.
I posted how to remove it without cutting the wire, or breaking the black plastic end.
You have to remove the flywheel in order to drive it back out of the case
but, I have also seen where twisting the plastic end back and forth will sometimes work also.
In either case removing the 'sensor' leaves a hole approx: 9mm or if you also remove the Brass insert that the sensor sits in you can get a plastic plug to fit the hole.
I do have pictures posted in my gallery. _________________ V.W.owner since 1967 |
Posted: Fri Feb 14, 2014 7:53 pm Post subject: Re: TDC Sensor removal |
old DKP driver wrote: |
I do have pictures posted in my gallery. |
Well that isn't like any of the ones I've ever encountered, or are you leaving the steel insert in the case and just driving out the guts? If that's the case I wasn't aware they came apart in a civilised and reuseable manner.
All the ones I've dealt with had a flange on the flywheel side that was larger than the hole in the case, there's no F'n way you'll dive that through towards the rear without breaking off the bellhousing flange first.
BTW VW Canada had a plastic plug that filled that hole when a universal case was used for an earlier model build, I'll try to find one for a pic. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
