Hacksaw-BoB Samba Member
Posted: Tue May 30, 2017 10:23 pm Post subject: Re: Starting to build my Heb. all steel replica |
Hi Matt . . . . . as a real HEBMÜLLER VW owner in the past . . . (14-00258) please take photos of your HEBMÜLLER VW
creation and post them on this site !! Over time . . . you will be a legacy as well !! I appreciate all your effort !! . . BoB _________________ Hacksaw BoB
http://www.VintageVolkswagenModels.com
Collector of Vintage VW Toys
BoB's Restor-Version Shop |
VEE DUB BOYS Samba Member
Joined: August 30, 2011 Posts: 146 Location: Greenville, SC
Posted: Fri Jun 02, 2017 9:46 am Post subject: Re: Starting to build my Heb. all steel replica |
Hacksaw-BoB wrote: |
creation and post them on this site !! Over time . . . you will be a legacy as well !! I appreciate all your effort !! . . BoB |
Thanks Bob, you have been very inspiring along the way. Pleasure to have met you last year at the Heb Reunion. I have an extensive photo documentation of all aspects. Looking forward to seeing you in September if you are able to make it.
Posted: Mon Jun 05, 2017 3:26 am Post subject: Re: Starting to build my Heb. all steel replica |
Seems like the pursuit of parts can be Endless
My fellow VW buddy Ed found these parts a couple weeks ago. They are the rear tack strip and rear window. He is a true friend and VW brother and has helped me find so many parts
peter schepens Samba Member
Joined: April 17, 2003 Posts: 1014 Location: belgium Caesars camp
Posted: Mon Jun 05, 2017 3:55 am Post subject: Re: Starting to build my Heb. all steel replica |
VEE DUB BOYS wrote: |
Sure the rear bow is from a Heb? Looks different and rather thick. Might be Karmann ghia style . Hebs had different style of joint to make the 3 parts into one. _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html |
Posted: Mon Jun 05, 2017 4:04 am Post subject: Re: Starting to build my Heb. all steel replica |
Peter, this is a rear tack strip from a Ghia convertible up to 1968. Do you have a picture of a rear Hebmuller tack strip?
Passenger side:
Passenger side and rear.
It looks to me like they did not do the joint like you are talking about and made the three pieces to fit separately. I agree, it looks like there is some more sanding/shaping to do. Thank you for your much needed help!
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Mon Jun 05, 2017 1:59 pm Post subject: Re: Starting to build my Heb. all steel replica |
That´s where you should end up with.
_________________ Master of my domain! |
Posted: Mon Jun 05, 2017 3:07 pm Post subject: Re: Starting to build my Heb. all steel replica |
usariemen wrote: |
thanks!! Looks great Carsten |
Posted: Tue Jun 06, 2017 9:36 am Post subject: Re: Starting to build my Heb. all steel replica |
No credits towards me.
Mine does not yet look like that. _________________ Master of my domain! |
Posted: Sat Aug 05, 2017 6:22 pm Post subject: Re: Starting to build my Heb. all steel replica |
A much needed update. Worked on the old gal this weekend. Passenger ribbed door is taking shape
Posted: Sun Aug 06, 2017 1:19 pm Post subject: Re: Starting to build my Heb. all steel replica |
Bravo . Looks good. Be sure the gap between the outer panel and the inner pannel is big enough, windowframe in aloy is rahter wider as a normal glass. _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Posted: Sun Aug 06, 2017 8:11 pm Post subject: Re: Starting to build my Heb. all steel replica |
peter schepens wrote: |
Bravo . Looks good. Be sure the gap between the outer panel and the inner pannel is big enough, windowframe in aloy is rahter wider as a normal glass. |
Great point Peter. I am constantly having to stop progress and check with original Hebs in Cincinnati. Hopefully, I can measure one in September. |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1772 Location: Finland, Jakobstad
Posted: Mon Aug 07, 2017 1:11 pm Post subject: Re: Starting to build my Heb. all steel replica |
Hebster52 wrote: |
If I remember correct the gap should be 30mm all the way? |
You have a good memory _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Posted: Mon Aug 07, 2017 3:45 pm Post subject: Re: Starting to build my Heb. all steel replica |
One question I would have is how does that affect the inside and outside dimensions? Does the outside door opening from the sedan remain the same or does it change? |
Posted: Sat Aug 12, 2017 4:10 pm Post subject: Re: Starting to build my Heb. all steel replica |
Had a little time to work on the tribute car today. Tightened up the cowl supports. I already had the majority of the work done on them, but had to get
the angle correct. A shout goes out to the Ken, Helen and Steve Swan family for letting me make templates of Heb 428 way back in March of 2016! Fitted nicely to my buddy's 1950 standard. The angle is so drastic on the Hebmuller compared to a sedan. Also, the inner rear door panel mounting area needs to be moved outward for the clearance of the convertible top mechanism. This is the reason for the cowl support not being all the way snug to the wheelhouse.
Posted: Sat Aug 12, 2017 4:31 pm Post subject: Re: Starting to build my Heb. all steel replica |
Also started working on the new cowl. The previous cowl was a practice piece only. Warpage occurred while peening the 84 holes. There were maybe 6-8 hammer strikes per hole!
After some metal straightening:
Posted: Sun Aug 13, 2017 6:38 pm Post subject: Re: Starting to build my Heb. all steel replica |
Thanks Kristian! The friends world wide have been a great help! |
Posted: Sat Aug 19, 2017 6:08 pm Post subject: Re: Starting to build my Heb. all steel replica |
Small victories are still fun to post. Here is the bump on the cowl for the trim.
Posted: Sat Aug 19, 2017 11:21 pm Post subject: Re: Starting to build my Heb. all steel replica |
nice detail again . That bump is bolted on the rear cowl and afterwards leaded together on older Hebs. Later cars had it pressed in the rear cowl. The same for the rain gutter. First series was hand made, second was a pressed rain gutter and welded on the rear cowl, last serie was in one piece pressed.
Greetings. _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
