Karly Samba Member
Joined: August 01, 2002 Posts: 641 Location: Australia
Posted: Sun Oct 20, 2013 3:23 am Post subject: |
What a beautiful car, you are very lucky and I think the car is also lucky to have fallen into the hands of someone who appreciates its originality!
I can't believe the mileage.. that's amazing! _________________ 1960 Beetle ''Heidi" daily driver
1964 Karmann Ghia project |
Bruce Berman Samba Member
Joined: April 13, 2004 Posts: 148 Location: Long Island, NY, USA
Posted: Sun Oct 20, 2013 10:10 am Post subject: |
Canni wrote: |
I can't believe the mileage.. that's amazing! |
Hi Canni,
Thanks for the nice comments! Yes, I am something of a fanatic about maintaining the "from the factory" originality of this car. Next spring, I'll be replacing the now 35 year old (and dry-rotted on the inside, no doubt) Continental bias-ply tires with the correct style Firestone "pie-crust" sidewall bias-ply tires. They will not be whitewalls, as the car was shipped from the factory with blackwall tires.
As you can imagine, it takes a fair amount of dedication and effort to preserve the paint, chrome, rubber components, and the interior from the ravages of time. I thank goodness the original owner always kept her garaged and treated her with real pride of ownership before I acquired the car in 1978.
The original owner was a man born in Germany who was 70 years old (!!!) when he purchased this VW in July of 1957.
Best Regards,
Bruce _________________ Factory original 1957 Type 1 Deluxe Sedan, with 13,000 miles. I purchased her from the estate of the original owner in 1978. Color: L324 Polar Silver, with light beige leatherette interior, dealer-installed Dehne fuel gauge and Motorola Volumatic radio. |
Posted: Wed Oct 08, 2014 1:55 pm Post subject: |
Several fellow enthusiasts have requested that I post a photo of the outer rim color of the road wheels on my car, to assist in correctly duplicating the color for their restoration.
This is the original paint on these rims from May of 1957. You can clearly see that the color is not Polar Silver, but rather an almost light slate non-metallic gray color. Polar Silver is of course a metallic finish. The two colors are completely different.
Wolfsburg West has a color chart for the 1956-1957 L324 Polar Silver finish cars that states that the color and related VW color code for the outer wheel rim is Steel Gray, L328. I do not believe that this aspect of the color chart is correct. If I am not mistaken, VW may have also used the color name and paint code "steel gray, L328" for another color they used on the 1950s Karmann Ghia cars, as well as other trim parts, such as the door handles for the type 111 Standard model, etc., and that color is completely different from the color of the outer wheel rim on my car. As such, I believe that L328 is not the correct color for the outer wheel rim, and my guess is that perhaps the correct paint color code is lost to antiquity at this point.
My feeling is that if you have a 1956-1957 Polar Silver vehicle, and desire to paint the outer wheel rim in the correct color, I think you will have to match the outer rim paint by taking either an actual sample of it (from a 1956-1957 wheel rim from a Polar Silver color car, probably easier said than done) to an automotive paint supplier, or provide them with a high quality photo of the outer wheel rim color. They can then custom mix the color for you. And honestly, even the gray color depicted in the photo I have posted here does not look 100% quite right from an exact color/shade standpoint, when compared to actually looking at the outer rim color in person. It could be my camera, my monitor, the lighting when I took the photo...........
I hope that this helps!
Last edited by Bruce Berman on Thu Oct 09, 2014 8:43 pm; edited 10 times in total |
Posted: Wed Oct 08, 2014 2:07 pm Post subject: |
Several folks have requested that I post a photo of the original rubber cover mat for the running boards, as used on the earlier VW cars. You will notice that the end of the cover has a section where the ribbing is not present. On later running boards, the ribbing extends to the end of the rubber cover.
This is the original rubber running board cover on my car, from May of 1957.
I hope that this helps. Perhaps someone will make a correct reproduction of this item for use on the earlier VW sedans.
Best Regards,
D. Haviland Samba Member
Joined: October 30, 2009 Posts: 536 Location: Burlington, Vermont
Posted: Wed Oct 08, 2014 2:47 pm Post subject: |
There are decent looking reproduction running board mats , but they are a real pain in the ass to put on because the slot that wrap around the back side is not deep enough.
And yes, beautiful car. |
Last Triumph Samba Member
Joined: October 10, 2006 Posts: 914 Location: Wirral, United Kingdom
Posted: Wed Oct 08, 2014 3:06 pm Post subject: |
Gorgeous! |
Nirvana09 Samba Member
Joined: July 11, 2009 Posts: 171 Location: Pacific NW
Posted: Wed Oct 08, 2014 6:37 pm Post subject: |
Bruce Berman wrote: |
My feeling is that if you have a 1956-1957 Polar Silver vehicle, and desire to paint the outer wheel rim in the correct color, I think you will have to match the outer rim paint by taking either an actual sample of it (from a 1956-1957 wheel rim from a Polar Silver color car, probably easier said than done) to an automotive paint supplier, or provide them with a high quality photo of the outer wheel rim color. They can then custom mix the color for you. And honestly, even the photo I have posted here does not look 100% quite right from an exact color/shade standpoint. It could be my camera, my monitor, the lighting when I took the photo...........
Bruce |
Bruce thank you so much! It's information like this that will make the restorations of the future that much more correct. Keep up the good work! _________________ A few '56s, a '64, and some late model stuff. |
Posted: Wed Oct 08, 2014 7:45 pm Post subject: |
Nirvana09 wrote: |
Bruce |
Bruce thank you so much! It's information like this that will make the restorations of the future that much more correct. Keep up the good work! |
You are very welcome!
If anyone needs any reference photos of my car for their restoration, please let me know, and I'll try to help out.
GhiaBug In Chicago Samba Member
Joined: June 23, 2004 Posts: 79 Location: Evanston (Chicago), Illinois
Posted: Thu Oct 09, 2014 6:54 pm Post subject: |
Quoting from the book "The Car of the Century - Volume One 1930-1960", the color for the wheel outer rims is stated as "L329 Shetln Gray M". I have quoted from this book in previous threads and have twice received a comment from the same Samba member advising that he/she felt that there may be inaccuracies in the book. Corrections and sources were not provided by the member. |
Posted: Thu Oct 09, 2014 8:15 pm Post subject: |
GhiaBug In Chicago wrote: |
Shetland grey very well could have been the first color used from the earliest '56 models. We aren't really sure what was used on pre-april cars. From April '56 on, Wolfsburg's charts show Steel grey which very well could on Bruce's car here. Although this is from another thread.
IN2VWS wrote: |
Also, I am not 100% certain on the earlier Polar Silver, but from April 1956 your wheels should be L87 Pearl White and L328 Steel Grey.
L328 Steel Grey is very similar to Polar Silver, but not exactly the same, as can be seen in this pic. On the left is Polar Silver and on the right is Steel Grey.
I do not know where this member got those paint chip books. They do look official. Does that mean that Polar silver cars may have come with multiple different colored rims i.e. metallic and non-metallic? Are there any examples of cars painted other colors with multiple different rims?
Is the grey color on Bruce's outer rim even considered Steel Grey? We do know that due to the incredible originality of his car they are probably what the car left with the factory with. Lets just assume for a second that IN2VWS information is correct, and Bruce's rims couldn't be Steel grey. What color are they in that case? _________________ A few '56s, a '64, and some late model stuff. |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Fri Oct 10, 2014 9:22 am Post subject: |
BBT in Belgium has been reproducing those "correct" running board runner replacements for a few years now. My June '55 completely unrestored Deluxe Sunroof Beetle (we drive ours, "Martha", it currently has almost 70K miles) still has it's slightly weathered original running board mats, but I bought a set of the new repro mats to use on my '57 Deluxe Beetle Kabriolett someday.
Beautiful Oval! You need to drive it more, otherwise it's just a garage sculpture. Enjoy the ride!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Fri Jul 17, 2015 2:54 pm Post subject: |
She's finally back on the road again, with brand-new, period-correct, pie-crust style sidewall Firestone bias-ply tires.
Sorry for the terrible image quality; I shot it right into the sun. I'll post some better images of the car in a few days.
Next week she goes in for the annual New York State safety inspection.
The previous set of tires on the car were Continental bias ply, and I installed them in 1979 to replace the original Engleberts as installed by the factory in 1957. After 36 years, I deemed the Continentals to be completely unsafe to drive on, due to potential dry rot issues.
The guy who installed the new Firestone tires did a really fine job; he took great care so as to not scratch the painted rims at all, and he put the wheel balance weights only on the inner aspect of each wheel. Thanks, Carlos!
Joe 20 Samba Member
Posted: Fri Jul 17, 2015 7:45 pm Post subject: |
Wow ! Thank you for the picture. Over the past winter I picked up a 57 that was according to the birth certificate was "polar." Being new to classic bugs, and the fact the car is red with white (polar) fenders I figured it was supposed to be all white. Imagine my surprise when I found out the "polar" was SILVER!! Thank you for posting your very nice pictures. I do love my "new" old beetle!! |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6601 Location: Downingtown, PA
jz56oval Samba Member
Joined: September 03, 2007 Posts: 375 Location: bay area
Posted: Sun Jul 19, 2015 8:39 pm Post subject: |
Oh how I would love to own skmetng like this. Very nice. |
Posted: Wed Jul 22, 2015 1:18 pm Post subject: |
Here are some much better images of the car that I took earlier today. She just came back from her annual New York State safety inspection this morning, and passed with flying colors.
You can see the new Firestone period-correct pie-crust style bias-ply tires I had installed about 2 weeks ago.
Bruce
Posted: Wed Sep 02, 2015 9:32 am Post subject: My 1957 VW with 13,000 Miles |
I know that I promised these a long time ago, but here are some additional photos I shot of my car in early August.
Hopefully these photos can of be of some value to you for use in your restoration project.
And yes, I know that the ignition coil is incorrect for this car. A number of years ago, the original coil was becoming weak and she was getting difficult to start, so I replaced the coil with this later style "short" coil, as it has the correct screw-type terminals. If anyone has a NOS correct TE6B3 ignition coil (I think that is the right Bosch part number) for my car, I would like to buy it!
I'll be taking some photos of the front and trunk area of her shortly, and get them up here as well.
Last edited by Bruce Berman on Sat Aug 26, 2017 9:14 am; edited 2 times in total |
Gwdghiaguy Samba Member
Joined: December 06, 2013 Posts: 340 Location: Greenwood, SC
Posted: Wed Sep 02, 2015 11:03 am Post subject: |
Beautiful pictures! Thank you for being such a good steward of this car; it's a valuable resource and we all benefit from your care and attention. More pics please!
byron _________________ 1957 Oval Window
1963 Alabama Camper Bus
1971 Ghia
1971 Baywindow Bus
otahuhu Samba Member
Posted: Wed Sep 02, 2015 2:33 pm Post subject: |
Gwdghiaguy wrote: |
byron |
Dito!!! text book stuff, this car should be a Sticky, surely? Thanks again for posting the great photos, and hosting them on the Samba. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Wed Sep 02, 2015 11:30 pm Post subject: |
otahuhu wrote: |
Gwdghiaguy wrote: |
byron |
Yes, thanks for posting more pics, this car is incredible.
This thread is linked from the Oval Window FAQ _________________ How to Post Photos
