stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Mon Sep 23, 2013 10:17 am Post subject: 205/60R15 rear tires -- suggest front size? |
Hello,
I just picked up a '67 sedan. It came with 15x5.5" cheap EMPI wheels with 205/60s in the back, and 135s in the front. PO had the front slammed for "the look", but I don't think the 135s in the front will work for me, I'm not sure they will provide enough traction for braking and steering.
I raised the front, car sits around 13 1/2" center of axle to fender lip on all 4 corners. Now the question is, what size tires to choose -- 185/60s maybe? Beam looks to be stock size but does have adjusters welded in. I threw on some GR-2s I had laying around, and the car does have disk brakes in the front. Any suggestions for front tire size would be appreciated, here is what the car looks like now:
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
slalombuggy Samba Member
Posted: Mon Sep 23, 2013 11:58 am Post subject: |
That would be my choice, 185/60 or even 195/60
brad |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
camaroboi13 Samba Member
Joined: February 22, 2013 Posts: 902 Location: San Bernardino, CA
Posted: Mon Sep 23, 2013 12:42 pm Post subject: |
All of the above are good options for tire size. If you weren't 415 miles from me I'd say we could trade...I have a nearly new set of 185 65s that I don't like, because I want "the look" lol.
For me those 135s have just the right amount of traction for braking and steering
Great looking bug ya picked up btw, congrats! _________________ 69 bug 1600sp buckpack ceramic header w mondo muffler, riviera wheels, 185/65 front 205/70 rear, dual baby webers, big stereo in the works.
2001 Yukon Denali 6.0l AWD 24s TVs surround sound playstation 6 disc dvd etc etc.
2005 Nissan Maxima 3.5l stock mama's car
FFL GUN DEALER! PM ME FOR SOCAL TRANSFERS! |
Posted: Mon Sep 23, 2013 1:08 pm Post subject: |
Thank you guys. I haven't had an aircooled VW in way too long.. finally lol! So many things wrong with it, so much to work on But it does run and drive, and I was happily surprised to find an AS41 case in there. It has a 1600 dual-port with a pair of Kadrons (I know, but they actually seem to work well). We are lucky here in California to still have a good number of these cars running around, and they can be bought fairly cheap.
I may try 195/55, I think the shorter sidewall may work better for me and I'll have more fender clearance.
Jansen Enterprise
My 1835cc build
Glenn Mr. 010
Posted: Mon Sep 23, 2013 1:11 pm Post subject: |
The 195/55-15 has a shorter sidewall than a 135-15 but is 2.36" wider. _________________ Glenn
Member #1009
#BlueSquare
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Mon Sep 23, 2013 4:16 pm Post subject: |
You may want to try 185/65R15s in front. Your back tires, 205/60R15, have a diameter of 24.7 inches. 185/65R15s have a diameter of 24.5 inches. If they fit in the front without rubbing, they would allow you to run a spare that fits both front and back, e.g., 155/80R15 (diameter 24.8 inches) or 145R15 (diameter 24.4 inches). _________________ 1966 Karmann-Ghia convertible |
Posted: Mon Sep 23, 2013 5:12 pm Post subject: |
If the front is adjustable you can't go very low on 185 65s. Infact, with just drop spindles you rub with those tires. Just a heads up _________________ 69 bug 1600sp buckpack ceramic header w mondo muffler, riviera wheels, 185/65 front 205/70 rear, dual baby webers, big stereo in the works.
Glenn Mr. 010
Posted: Mon Sep 23, 2013 5:53 pm Post subject: |
You can go 3" lower with 195/55-15.
The blue one is also a74 and stock height.
Member #1009
#BlueSquare |
Posted: Mon Sep 23, 2013 6:37 pm Post subject: |
I think I have stock spindles from a later car, I don't think they are drop spindles. I'll test fit my rear wheels on the front, I think there is plenty of clearance on the inside, it's the fender I may rub on.
Jansen Enterprise
My 1835cc build
Glenn Mr. 010
Posted: Mon Sep 23, 2013 6:44 pm Post subject: |
My car has stock height spindles, also a stock width beam. _________________ Glenn
Member #1009
#BlueSquare |
evillrdnikon Samba Member
Joined: February 26, 2014 Posts: 180 Location: Las Vegas
Posted: Wed May 03, 2017 4:31 pm Post subject: Re: 205/60R15 rear tires -- suggest front size? |
throwing this out there! Hope this works with my setup =D
205/60R15x5.5" REAR
185/60R15x5.5" FRONT
I have a 2" narrowed front beam that is adjusted up so my 2.5" drop spindles are the only thing doing the drop in the front.
I have lowered my rear 1.1" (1 spline)
currently my setup has stock wheels (15x4.5" front and rear) and I went to a junk used tire shop to get used tires to see the fit so i put 185/60s in the front and 205/60s in the rear.
so far nothing rubs. I am hoping when i get the 5.5" widths that it will continue to do the same and not rub, even with maximum turn of the wheel all the way to the left and to the right.
If anyone wants to chime in I would be glad to hear your thoughts and suggestions =D |
Posted: Thu Jun 01, 2017 6:59 am Post subject: Re: 205/60R15 rear tires -- suggest front size? |
Ok so my fronts (185/60/15) rub the outer lip of the driver side fender. I need to see if i can raise my front adjustable beam. I might go with a shorter side wall tire since i rub. |
