56samba Samba Member
Posted: Tue Aug 14, 2018 10:05 am Post subject: Re: '46 Generator? |
Alright going to show another strange generator that's probably from the 40's (5C)?
Found it two weeks ago...
As you can see, the marking area looks different than on later generators, but it has 130W power output, thought that was introduced in 49ish?
Yes I know the backing plate and fan don't fit pre 49 engines
The casted number on the front plate is also different compared with an 1F generator, but my 44 generator also has another number.
Another thought was that it's a May 51 generator and that the G looks a bit strange. Also bought a 47-48 fan shroud from the seller, so the old men was definitely in contact with that sort of early stuff.
Jan
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Posted: Tue Aug 14, 2018 9:35 pm Post subject: Re: '46 Generator? |
It might be factory rebuild and restamped. Looks like there is number 9 under the 3? So it was 90W but updated during rebuild to 130W?
Early fan/plate with slots discountinued late 1947 or early 1948. Maybe at the same time when generator updated from 90W to 130W. As you know the 90W was use only in 1947, before it was also 130W. _________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
Posted: Wed Aug 15, 2018 12:54 am Post subject: Re: '46 Generator? |
virtanen wrote: |
Early fan/plate with slots discountinued late 1947 or early 1948. Maybe at the same time when generator updated from 90W to 130W. As you know the 90W was use only in 1947, before it was also 130W. |
Good eyes Mika, thought the same, but was curious if the distance between RED and 90 was too big, but you might be correct.
Going to put it up for sale as I can't use it... |
derschar Samba Member
Joined: September 17, 2018 Posts: 1 Location: detroit
Posted: Wed Aug 07, 2019 7:16 pm Post subject: Re: '46 Generator? |
hello...looking for info on date codes for my starter...i have a 41 dated generator if anyone wants pics ...it is off the car....the one on my 44 kubel i can not see the stampings too good,,,i have a starter i think is dated 1944 ,,,it looks like a 10 Z code on it...also reads EE004/6L4 and on the part going to the solenoid it reds 371/1 ...is this a 1944 starter or am i missing a code somewhere?
thank you |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu Aug 08, 2019 8:34 am Post subject: Re: '46 Generator? |
Did VW make industrial engines back then? No headlights needed, so a lower capacity generator would work fine. |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 726 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
