guitarman63mm Samba Member
Joined: September 03, 2008 Posts: 797 Location: Asheville, NC
Posted: Sun Jul 15, 2018 7:51 pm Post subject: Foam rubber engine seal alternative for Type 4s? |
My seal has begun to seriously disintegrate on the top side over the last 4 years (and the bus was parked for 2.5 years of the 4!), with the slightest touch sending tufts of foam flying. Although $35 isn't that much money for a consumable part with a 5 year lifespan, I'd much rather spend it on something that would last longer (and be less attractive to malevolent critters looking for insulation).
I've been looking at H-shape silicone extrusions, and I haven't had much luck with finding anything pre-made that you can get in 5-10ft lengths to test. Has anyone had any luck with alternatives? It seems like making one out of silicone sponge foam (or a variety of cheaper rubbers) would be leagues above our current options.
This is the kind of thing I initially had in mind:
https://www.alibaba.com/product-detail/Factory-pri...c8fd4EmMbh
Another option would be the bulb seals on the top - but I'm not sure how well they'd seal:
https://www.mcmaster.com/#bulb-seals/=1dqcfr4 _________________ Jimmy
- 1974 Safaré Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine. |
busdaddy Samba Member
Posted: Sun Jul 15, 2018 8:16 pm Post subject: Re: Foam rubber engine seal alternative for Type 4s? |
Get yor butt over to Walmart for some pool noodles before they blow out the summer stuff and stock up on Halloween decorations. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jul 15, 2018 8:27 pm Post subject: Re: Foam rubber engine seal alternative for Type 4s? |
busdaddy wrote: |
Get yor butt over to Walmart for some pool noodles before they blow out the summer stuff and stock up on Halloween decorations. |
Good idea, I can pick up some gorilla glue while I'm there - then this pool noodle will be stuck in my engine bay until the end of time. _________________ Jimmy
Posted: Sun Jul 15, 2018 9:44 pm Post subject: Re: Foam rubber engine seal alternative for Type 4s? |
I typically get around 8 years out of a foam seal. When they were asking over $60 for them maybe 15-20 years back I certainly was looking for alternatives, but at around $30 today it just doesn't seem worth it. I had considered getting some 3/8" - 1/2" thick heat rated silicone sheets and seeing what I could glue up.
Ray Greenwood has mentioned that he smears the available foam gaskets with RTV silicone in an effort to get more life out of them. |
Randy in Maine Samba Member
Posted: Mon Jul 16, 2018 7:29 am Post subject: Re: Foam rubber engine seal alternative for Type 4s? |
Make sure you install the shiney side down please. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Jul 16, 2018 10:00 am Post subject: Re: Foam rubber engine seal alternative for Type 4s? |
Randy in Maine wrote: |
X2. Everyone I run into seems to think the shiny side up is better. Always fun to point out it’s upside down and see their reactions _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Jul 16, 2018 10:10 am Post subject: Re: Foam rubber engine seal alternative for Type 4s? |
Years ago I trimmed back my engine surround tin to leave a more even space for the foam seal to fit, maybe as much as 3/8" in the right rear corner area. Makes the foam go and out easier and keeps it from being damaged as much. |
Tcash Samba Member
Posted: Mon Jul 16, 2018 1:35 pm Post subject: Re: Foam rubber engine seal alternative for Type 4s? |
I didn't realize you were semi-serious about the noodle! Seems like LDPE is only good to 220-240F per google - not sure the heads/exhaust will like that very much, but I suppose it depends on the environment and engine.
Can't figure out what this is (expanded EPDM?), but I seem to recall a low melting point in other projects I've worked on:
https://www.homedepot.com/p/Armaflex-1-in-x-6-ft-R.../100569382
Then there's this stuff:
https://www.homedepot.com/p/1-1-2-in-x-3-ft-Fiberg.../100134569
Scraping the bottom of the DIY barrel here. _________________ Jimmy
