xzener Samba Member
Posted: Sat May 13, 2017 7:33 pm Post subject: Re: Had some time for my '58 low light today |
Rear apron looks great... About the only thing left mine could use. What is the procedure for getting that in? Lots of welding? I attempted to straighten mine out, had a few bumps and ripples... Lost the two exhaust arches. Debating on replacing mine. Also, seen a lot of guys have them removable... That's tempting too.
_________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Porschedave Samba Member
Joined: July 01, 2004 Posts: 454 Location: Vancouver, Canada
Posted: Sat May 13, 2017 8:31 pm Post subject: Re: Had some time for my '58 low light today |
Replacing the rear apron was a big job but then I had to replace all the engine tin as well so that made things extra difficult. If you're going to replace the apron only, you'll need to drill out all the spots on the rear engine tin as well as cut the vertical welds that attach it to the side panels. Keeping the rear engine tin should make re-alignment quite easy as it will dictate the final curve. Good luck.
Dave _________________ 1977 911S
1958 Karmann Ghia build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=571683
1965 Sunroof Notch build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?p=5600139&highlight=#5600139 |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Sun May 21, 2017 11:52 am Post subject: Re: Had some time for my '58 low light today |
Working on the left front fender is a real challenge. As you can see from the photo there is no headlight bucket and the front face is pretty messed up. Here's an early shot of when I got the car
I cut away that fender and began to work on this replacement piece.
I have a new bucket that I'm using to try and mold the front opening and then I bought a piece from Sam in Spain to replace the whole opening. My plan is to get the overall shape correct and then weld the fender to the rest of the shell. Once it is in place then I will cut away all that crap around the headlight opening and weld in the new piece from Sam. The final step will be to replace the lower rear section with the piece I bought from Danny.
But first I'm traveling to Berlin so this will have to wait until I get back.
c21darrel Samba Member
Posted: Wed Jul 26, 2017 4:56 pm Post subject: Re: Had some time for my '58 low light today |
Hello Folks
I'm back from my month-long stay in Berlin - a fantastic city. I've returned to working on the KG and have a couple of photos and an update for those of you following this thread.
The left-front fender is in place and mostly complete.
It took some work, making the three sections fit together and fit to the shell. The front headlight section came from Sam in Spain, the lower rear corner came from Danny and the fender itself from another Canadian KG guy. At least this one had a fender lip whereas the one that am with the car had none. Here's a couple more:
And now I have a set of headlight buckets.
Gosh, almost like a real car.
At this point all the major work on the shell has been completed. There remain some small bits of welding in the engine compartment area. The final BIG item is to repair the truck lid which has a rotted lower section, something that seems typical to these cars.
Anyhow, it feels pretty good together the car to this stage - it certainly looks better than when I began this project.
xzener Samba Member
Posted: Wed Jul 26, 2017 8:29 pm Post subject: Re: Had some time for my '58 low light today |
Looking good Dave. Well done. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
Posted: Thu Jul 27, 2017 5:41 am Post subject: Re: Had some time for my '58 low light today |
Great work as usual. I'm really enjoying watching this come together, very inspirational. _________________ Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807 |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Fri Jul 28, 2017 10:39 pm Post subject: Re: Had some time for my '58 low light today |
It is called heat shrinking and you need to do using a hammer and dolly to do it properly - check this out http://cid.vcc.ca/p1-dl/instructions/moodle/demo/demo-shrink.htm _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
kgj Samba Member
Joined: February 25, 2013 Posts: 418 Location: Uk, Cornwall
Posted: Fri Aug 18, 2017 1:50 pm Post subject: Re: Had some time for my '58 low light today |
Nice to see it coming on.
I'm loving the scissor lift in the floor. Can you share make and model? _________________ 1958 coupe |
