EPETREA Samba Member
Joined: September 07, 2007 Posts: 391 Location: DFW TX
Posted: Tue Jan 10, 2023 3:39 pm Post subject: Headlight assembly clocking |
Does any know of any diagrams showing the placement of the headlight assembly in my ghia. Where are the 2 adjuster screw supposed to be located ect. Have searched both here and in beatle forums with no luck. Fighting to get everything to work nicely. |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3907 Location: In Molinya Orbit
Posted: Wed Jan 11, 2023 5:13 am Post subject: Re: Headlight assembly clocking |
74 sealed beam it would appear. All original bucket The part’s diagram is awesome, had never discovered it before. I did find one pic that would suggest that the adjusting screws would be at 9 and 12 o’clock position. Problem I might have is the the lugs on headlight only seat int assembly a certain way and throws everything else off. I have originals but decided to buy the Airhead version and that might be a little off too. Thanks for info. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Wed Jan 11, 2023 6:56 am Post subject: Re: Headlight assembly clocking |
The headlight fits into the holder one way. The headlight is marked 'TOP'. Then it fits into the bucket one way. TOP to the TOP.
Adjuster screws and the tension spring are movable. You want the spring between the two adjusters locations, it holds the two halves together. The 'up-down' adjuster location should either be at the top or bottom. Most times at the top so the beams can be adjusted downward. The 'right-left' adjuster location can be at 3 or 9 o'clock. Most times at 3 o'clock so the beam can be adjusted to the right better. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
