Once warm splutters and won't rev.
Notablecarrot3
Notablecarrot3 is offline
PostPosted: Sat Sep 28, 2013 6:45 am    Post subject: Once warm splutters and won't rev. Reply with quote
Hi guys, firstly I'm starting to hate my beetle after 4 years of ownership, problem after problem after problem Crying or Very sad
Basically now my problem is that when I start it up it runs perfectly until the engine is warm after a few minutes. It still ticks over perfectly but when I try to accelerate it either stalls or starts popping. Carb was set up by pro and hasn't been adjusted since, worked perfectly. Timing OK, haven't checked points yet.
Any ideas?
P.S it's a RHD '67 standard with a 1200
Your Donkey has a large head. I like your donkey.
Is it wrong to be jealous of their facial hair abilities?
KTPhil Premium Member
KTPhil is offline
PostPosted: Sat Sep 28, 2013 9:18 am    Post subject: Reply with quote
I would start with the usual tune-up stuff, both to make sure they are right, and also because many minor failures are discovered while checking and adjusting these things.
Do you know how to adjust the choke? Sounds like it might be stuck closed. You may also have a vacuum leak that is masked by the operation of the choke when cold.
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Sep 28, 2013 9:24 am    Post subject: Reply with quote
Agreed, do a tune up first.
If still a problem check if the accelerator nozzle is partly or fully clogged.
In Stereo, Where Available!
KTPhil is offline
PostPosted: Sat Sep 28, 2013 9:31 am    Post subject: Reply with quote
A couple of specific things to check as you tune it: check the ignition advance as well as the spray of the accel pump.
Danwvw
Danwvw is offline
PostPosted: Sat Sep 28, 2013 9:33 am    Post subject: Reply with quote
Point's cans sure cause this, It could be last time they were changed they were not re-adjusted after a drive. Points tend to close up over time. I set the new points at 20 thousandths then after about 100 miles or so check the timing it will usually be retarded 5' degrees sometimes more. After the points have a few miles on them check the Dwell or make sure they have at least 16 thousandths of opening. Are you intake manifold and carb to manifold bolts tight?
1971 VW Bus Sundial Camper, 1960 VW Beetle, 1988 Porsche 924s
Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? And 1960 Beetle Original 36 Horse And Porsche 924s.
