gutwrencher Samba Member
Joined: November 30, 2003 Posts: 32 Location: Peoria, AZ
Posted: Sun Nov 30, 2003 8:42 pm Post subject: seat release latch help |
Anyone have any nifty ideas about how to rig a fix for a front seat missing the pull handle that releases the latch so the back of the seat can be moved up? This is on a 64 notchback where I have a missing one on the passenger side. Thanks for any help!
Gut |
Bobnotch Samba Member
Posted: Mon Dec 01, 2003 6:05 pm Post subject: |
I was hoping somebody else with more knowledge of the early cars would have answered this, but since nobody did, I guess I will try. The 64 didn't use a pull lever on the side of the seat. It used a spring loaded cable release that was operated by the door. Look at the front lower corner of the door opening and see if there are remenents of the flipper device still there. If so then you need to look under the seat and see if the cable is still at that end. If so, you might be able to loosen the wing nut and take the slack out of the cable and try moving the seat back forward. This might require a couple of tries to get it to work. If however there is no flipper or cable, you might try using a piece of wire sticking thru the front that you can pull to release the latch. Or you can totally disable the latch by tying it in the unlatched position, this will allow you to flip the back rest anytime you want. I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Dec 02, 2003 11:04 am Post subject: |
Thanks Bobnotch. I will take a look for door release. Currently under my driver side seat facing the back seat, there is a white knob that connects via an 'L' shaped cable/tube to the latch on the side of the seat. This doesnt exist on the passenger side and I assumed it somehow was 'lost' by a PO. I will also heed your other suggestions. Thanks again.
Gut |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Tue Dec 02, 2003 7:19 pm Post subject: |
did some years of seats have both the door cable release and the knob on the side of the seat? i can't find where my cables hook to the seat. its a '66 and there are both types. |
chicagovw Samba Member
Joined: January 06, 2007 Posts: 1424 Location: Chicago IL/CHandler AZ
Posted: Thu Mar 31, 2022 1:38 pm Post subject: Re: seat release latch help |
I have a 1970 Fastback that I have a build thread already created for, but thought that an existing one on this topic might be a better place to find an answer to my problem for. I purchased a set of low back front seats from a 66-7 Type 3 for my car. These seats use the cable operated release seatback release system. Ideally, I would like to get this to work with my late model car.
Can anyone tell me if the cable operated system is reliable, and is it something I can add onto my car? I have not yet looked, but I assume I would have to locate good used parts for this. How does the system stay properly adjusted-would moving the seats forward and backwards on the track no change the cable adjustment? |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Mar 31, 2022 4:23 pm Post subject: Re: seat release latch help |
chicagovw wrote: |
It is reliable when installed correctly. If an existing system is broken and repaired correctly - it is reliable. The seats don't have enough adjustment in them to cause a problem for the seat release system. I've owned several early cars and never had an issue with the cable release system.
Adding this system to a car doesn't seem like a good time. There are brackets welded to the body that hold the lever in place and additional holes in the A pillar for the lever. to operate. It's not something I would look to add to a later car. Get seats from a 68 or 69 and convert those to low backs if that's why you're buying early seats. |
Posted: Thu Mar 31, 2022 9:59 pm Post subject: Re: seat release latch help |
That is why, and I do have the original seats...I have just not come across converted seats that don't look like they've been converted. Perhaps there is a way to make them look correct. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Apr 01, 2022 10:49 am Post subject: Re: seat release latch help |
Tram bent sheetmetal seatback foot operated releases for the lower back of the front seats. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Ossipon Samba Member
Posted: Fri Apr 01, 2022 5:35 pm Post subject: Re: seat release latch help |
I was trying to find where I had read a solution about nine months ago, but did not bookmark or print it. So Sorry about this is from memory.
What I saw as a Hack solution was using a modified choke cable attached and anchored under the 61-66 seat. The knob sort of stuck out on the seat bottom rear. (don't remember how) And the other end was attached to the eyelet on the Seat release. And the knob was pulled to release the seat.
I considered doing that before getting the correct cable and door release mounts. (Thanks to Mike F for the cable). My fear was the door mount assy. was too far gone on Gretchen. But I was lucky. I now just have to get the cable placed and functional before I install the carpeting this Summer.
My question is more about the rail mount. Would the older seats slide properly on a newer rail set up? I am ignorant about that. _________________ Ossipon
VWs in my life:
Air
Type 1 - 59, 62, 63, 71 Super 68 KGhia/ Type 2 - 59 Single Cab / Type 3 - 64 Notch
Water
GTI 83, Jetta 81, 85, 87, 91 TDI, 98 TDI, 09 / New Beetle 99 / SportWagen 05, 13 / Tiguan 18 / T3 92 |
Posted: Fri Apr 01, 2022 9:16 pm Post subject: Re: seat release latch help |
Ossipon wrote: |
My question is more about the rail mount. Would the older seats slide properly on a newer rail set up? I am ignorant about that. |
The seat rails were the same until 72 when they went to a 3 point system. |
Peters Van Samba Member
Joined: March 27, 2014 Posts: 357 Location: Goulburn NSW Australia
Posted: Sat Apr 02, 2022 3:47 am Post subject: Re: seat release latch help |
get yourself some new seat track bushings and some silicone spray
and they will slide like new
_________________ 1965 Type 3 Panel Van
1963 EH Holden Station Wagon |
Posted: Sat Apr 02, 2022 3:49 am Post subject: Re: seat release latch help |
put some in the panelvan when i redid the seats and they slide perfectly
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Mon Apr 04, 2022 9:05 am Post subject: Re: seat release latch help |
Quote: |
The knob sort of stuck out on the seat bottom rear. (don't remember how) And the other end was attached to the eyelet on the Seat release. And the knob was pulled to release the seat. |
mines like that, I just made a bar with a large bearing ball to push down to release the seat, it sticks out behind the seat _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
michaelpainter0917@gmail. Samba Member
Posted: Wed Dec 21, 2022 10:13 am Post subject: Re: seat release latch help |
I am working on a 1965 notchback for my boss. He is wanting the flip seat cables installed that function when opening the door. Is there anyone with a diagram of how it works. As well as were parts can be found. I have passenger side cable but it is not hooked up to the seat. It is missing a bracket or whatever secures it to the seat. |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3695 Location: San Jose, CA
Posted: Wed Dec 21, 2022 10:28 am Post subject: Re: seat release latch help |
michaelpainter0917@gmail. wrote: |
You should probably post up some pictures of what you're working with. The system itself is fairly simple, but some of the parts are pretty hard to come by. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Thu Dec 22, 2022 9:23 am Post subject: Re: seat release latch help |
Posted: Thu Dec 22, 2022 10:09 am Post subject: Re: seat release latch help |
So the "S" hook gets hooked into the latch that holds the seat back upright on the outside of the seat base. The piece with the part number, slides over a stud, and is held in place with a wing nut.
You can see most of the pieces here:
https://vwispwest.com/type3/body/interior/squareback/seats/
The piece held in place with the wing nut is under #13. You can probably just get away with a nut if you can't locate a wing nut.
Sometimes the switch side, where the door pushes against it or releases it when the door is open, can be very stiff and cause issues with the door closing, etc. I've seen a ton of dented doors here, where the operating switch is basically locked up. Make sure yours is functional.
Lastly, a lot of these no longer work. Don't be too surprised if yours doesn't. But hopefully it does! _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
Posted: Thu Dec 22, 2022 11:18 am Post subject: Re: seat release latch help |
Thank you so much for the help. I will keep it all in mind |
