crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Sat Oct 05, 2013 2:17 pm Post subject: Syncro owner puzzler question, SOLVED |
Coming home at night I hit a long board with nails in my street, probably dropped during trash pickup earlier that day. Before I could identify the danger and stop , my front wheels hit it. My otherwise stock Syncro has 2 badly punctured front tires in size 215/70/16. I need to drive the Syncro 20 miles on a busy interstate to a tire shop. I don't have 2 spares of that size, only 1 spare. I still have the puny 205/70/14 wheels I took off. I have the normal tools any syncro guy should have. How do I solve this with the least amount of work using what I have and without any extra stress to the VC?
Mark
Last edited by crazyvwvanman on Sat Oct 05, 2013 9:27 pm; edited 1 time in total |
DAV!D Samba Member
Joined: September 10, 2013 Posts: 979 Location: EL CAMINO
Posted: Sat Oct 05, 2013 2:32 pm Post subject: |
Use fix a flat to get to the tire store. Just let them know you put it in the tires. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Sat Oct 05, 2013 2:41 pm Post subject: |
Remove frt shaft, put two 14" on front n head to tire shop. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
insyncro Banned
I would swap in good wheels in the front, pull the driveshaft and away I would go to get the punctured tires fixed...or have a Buddy drive me and my wheels to a shop and leave the Syncro at home. |
Posted: Sat Oct 05, 2013 3:05 pm Post subject: |
That could work if they weren't so badly punctured. The tires picked up the board and when the board hit on the front diff carrier the multiple nails ripped their way out of the tires. I tried my can of flat fix on the one that didn't seem as bad but it didn't hold. Easy to try though not the solution.
Mark
DAV!D wrote: |
oldskewlsk8ter Samba Member
Posted: Sat Oct 05, 2013 3:13 pm Post subject: |
Did you try to plug the tires? I've had punctures bad enough I had to use 2 plugs tot get me on the road and to the tire store to get a proper patch. _________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project |
insyncro Banned
Posted: Sat Oct 05, 2013 3:21 pm Post subject: |
If the tires are radial type and punctured badly, the plugs will need to be put in from the inside, meaning the tires need to come off and if any inner damage is seen, the tech may advise you to purchase new tires and I concur. |
chazz79 Samba Member
Posted: Sat Oct 05, 2013 3:38 pm Post subject: |
insyncro wrote: |
I've never had a problem using a plug, radial tire or not, from the outside, as a temporary fix until I could get to the tire store...unless the puncture was a sidewall, or too big and nasty. Of course that's just been my experience, and being a poor country boy, I've "fixed" lots of tires this way. _________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
Posted: Sat Oct 05, 2013 3:45 pm Post subject: |
Sure that could work. But I just got all my driveline vibrations resolved. I finally lock-tited the driveshaft bolts in and they are staying in. I'd rather pay for a tow than open that can of worms again. But I still won't need a tow to get it to the tire shop.
It is just a dumb puzzler, not real situation.
Mark
IdahoDoug wrote: |
Remove frt shaft, put two 14" on front n head to tire shop. |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Sat Oct 05, 2013 4:47 pm Post subject: Syncro |
Sounds like a good time to buy a decoupler , then put your stock wheels on the front. _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
insyncro Banned
Posted: Sat Oct 05, 2013 4:59 pm Post subject: Re: Syncro |
joseph928 wrote: |
Sounds like a good time to buy a decoupler , then put your stock wheels on the front. |
Word up
Decouplers are a great addition to any Syncro. |
Posted: Sat Oct 05, 2013 6:04 pm Post subject: Re: Syncro |
Yes, decouplers are great and I already own 3 of them. But this puzzler Syncro is stock. That is part of the puzzle. Adding new equipment isn't in the answer.
But lets see, stock front 14 alloys came with 820 rev/mile tires. At 60 mph that is a mile per minute, so 820 front wheel revs per minute. Multiply by 4.86 for a stock front r&p ratio , gives front pinion shaft speed as 4000 per minute.
Rear tires of the puzzle van 215/70/16 about 745 rev/mile X 4.86 rear r&p ratio give rear pinion shaft speed at 60 mph of about 3600 rpm.
3600 rear, 4000 front, decoupler sees almost 400 rpm between input and output ends at 60 mph. I wonder how long the various versions will stand for that?
Mark
insyncro wrote: |
joseph928 wrote: |
Word up
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Sat Oct 05, 2013 6:15 pm Post subject: |
crazyvwvanman wrote: |
Mark
Some options for your simulation.
Plug the tires temporarily and drive the van to a tire shop.
Pop the bead and do the proper repair yourself.
Pull the 2 bad tires and drive them to the repair shop in the wife's/husband's/boyfriend's/girlfriend's/neighbor's/mom's/dad's/friend's car.
Put the full set of 205/70/14 wheels that you took off back on.
Order new tires from the shop over the phone and take your bad wheels there and back with you on the bus. |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Sat Oct 05, 2013 6:21 pm Post subject: Re: Syncro |
Yes, decouplers are great and I already own 3 of them.. |
[/quote
Quit hording the syncros. Take the wheels off and put them in another van go to the tire shop and do business, bring them home and reinstall them. |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1867 Location: Pittsburgh PA (ish)
Posted: Sat Oct 05, 2013 6:24 pm Post subject: |
Nah dude.
It's time for a bush fix, and you have all you need.
Pop out the Prop shaft.
Just take that sucker out. It's easy.
Now stick two front tires on it, whatever the heck they are (Nope, doesn't matter, ideally they're the same on both sides but again, doesn't "really" matter, and you have a matched set).
Drive it there, with the busted tires in hand.
If however you have a good working vehicle or ride to the tire shop, Take the wheels/tires to the tire shop. Easy.
If you really need to patch the tires from the inside (Which by the way, would be the "proper" fix, and is a FIX, but PATCHING it from the outside would work. As would a bottle of SLIME) just take the tire off.
Don't know how to take the tire off?
Get two big screw drivers. And I mean BIG!
Heck, a set of pry bars would be way better.....
And a good friend. Bring a 6 pack (5 packs are okay, you get a reward for planning right?).
Now do some google searching.
Basically, you deflate the tire, you stick a pry bar in and pull up, then you stick another in and start working it around. You pop one bead off, then the other.
It's physical, but not technically "hard".
Plug it.
Stick it on.
Fill it up.
Run out of beer.
Take it there tomorrow (whenever the next "tomorrow" is.)
This plan only works if your planning on REPLACING the two front tires. If not, well, this is all they're going to do anyway.....so either do it yourself and be happy, or carry your rims/tires there.
Have any tubes sitting around?
Tubes, though hard to find for modern tire sizes (especially with the proper valve stem) are awesome for a situation like this.
I carry a tube in my syncro (along with two big screw drivers and a 5 pack) for this reason.
It will get you home when nothing else will. _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry." |
Kburns737 Samba Member
Joined: October 21, 2008 Posts: 184 Location: Ventura County
Posted: Sat Oct 05, 2013 6:41 pm Post subject: |
Isn't this a puzzle guys? Quit trying to take the driveshaft out The point is a clever solution, not the most obvious one. Not that I have a clue, how about putting the two front 14" tires on and deflating the rears til they're all even, obviously you wouldn't want to let out enough air to possibly ruin the tires while driving but who knows maybe you don't have to let that much out to get it close enough. C'mon people, ets hear all the real hairbrained ideas! |
Posted: Sat Oct 05, 2013 6:48 pm Post subject: |
Kburns737 wrote: |
Grab some shoe goo and slather it onto large pan head screws and screw them back them into the holes.
Throw a few pallets into the wood chipper. Pop the tire bead and throw all the chipped wood inside to keep the rim off the ground.
Fire up your chopper and airlift the van to the repair shop
snowsyncro Samba Member
Joined: January 11, 2009 Posts: 1557 Location: East Preston, Nova Scotia, Canada
Posted: Sat Oct 05, 2013 6:57 pm Post subject: |
Put one of your old wheels on the front, and one on the back. Put one of your remaining two good new wheels (or the spare you have) on the front. Drive to the tire repair place.
Easy peasey.
RonC |
Posted: Sat Oct 05, 2013 7:02 pm Post subject: |
Ding ding ding, we have a winner!
Mark
snowsyncro wrote: |
Easy peasey.
RonC |
