Randy in Maine Samba Member
Posted: Sun Oct 06, 2013 8:10 am Post subject: Fan Hub Removal |
Type 4 engine. I am trying to replace the rear main seal. I am having a bear of a time removing the fan hub from the crankshaft. In the past I have just put a peice of steel behind the 3 bolts and it just popped out. The hub is made of pretty good and hard steel.
Not working this time. I have heated up the hub after soaking it in solvent for a couple of days. Some hammering on the hub to see if that helps. So far nothing.
I have a gear puller (a harmonic balancer removal puller) that I have threaded on there and in theory, the center bolt should just walk it off the crankshaft.
Not working this time. Not so much as a budge.
Has anyone ever tried to cut the hub with a dremel tool ? I have not tried that before, but I think I could get it in there to cut partially through it in a few places to remove it without damaging the crankshaft.
Any thoughts out there? |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Sun Oct 06, 2013 8:22 am Post subject: |
Hmm I've never had one give me trouble either Randy. I put a piece of steel of some sort behind the bolt holes and use the fan bolts to press it off the crank. I've even used a pair of old Bus keys as the backer. I think you'd be in for a most of the day project cutting it off. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Sun Oct 06, 2013 8:29 am Post subject: |
I even "sucker punched" the retired VW Service advisor guy here to get him over to the shop and he told me he had never seen a similar thing. He suggested that if I go that dremel route to cut on both on sides of the woodruff key in case that is the problem.
I have plenty of other things to do today, so I am just letting it sit for a while. I am still thinking about it.
If you think of anything else taht I have not tried, just chime in. |
germansupplyscott Samba Member
Posted: Sun Oct 06, 2013 8:33 am Post subject: |
get the 3 screws nice and tight and give the hub a sharp strike with a hammer. the shock wave through the hub may break it free. _________________ SL |
Posted: Sun Oct 06, 2013 10:07 am Post subject: |
germansupplyscott wrote: |
get the 3 screws nice and tight and give the hub a sharp strike with a hammer. the shock wave through the hub may break it free. |
I already tried that a number of times. I was sure it would work, but alas it did not. |
SGKent Samba Member
Posted: Sun Oct 06, 2013 10:36 am Post subject: |
Randy - take the time to look over your work for anything you have forgotten to take off. Have you tried a big washer cut with a slot behind the hub with hardened bolts thru the 3 holes working bolt to bolt until they are extremely tight - then hit it with two hammers at the same time, one from each side. That may deform it enough to pop. |
Posted: Wed Oct 09, 2013 11:25 am Post subject: |
UPDATE...
It came all last night. I used the "harmonic balancer" gear puller along with a lot of torque on the big bolt that pushes on the center point and it came off as I applied sharp wacks to the pulley using a long punch and a BFH. The hub is pretty dense metal and I don't think applying the heat helped any.
The new seal will be applied using Indian Head gasket cement to the outside of the new seal and oil on the inside of it. |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Wed Oct 09, 2013 7:55 pm Post subject: Fan Pulley |
Glad you have the fan pulley removed.
t
I too used the snap-on harmonic pulley tool and, found that if using my
3/8 snap-on air gun that they come off pretty quickly with that shock
of the hammering. _________________ V.W.owner since 1967 |
raygreenwood Samba Member
Posted: Wed Oct 09, 2013 7:57 pm Post subject: |
Be sure to check that the three ears are still flat and level. The crank hub is amorse taper. It developes many tons of joining force. When you put it back together makes sure it is dry and has 0 surface rust. Clean it only with prefferably 3000 grit sandpaper....polish only. Clean very well. Oil with thin oil and wipe dry.
Removal of any of these is with a puller.....but back up the ears with thin nuts...not just the threads in the ears. Tghen put tension on the puller and whack it hard on the center....just like a pitman arm puller is designed to be operated. It should always come right off if set up corrctly.
If humidity is an issue...you can wipe the surface with very fine anti sieze like straight nickle. Carefully wipe it all off. Microscopic amounts will remain in the pores. Then clamp tpgether. Ray |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Wed Oct 09, 2013 8:09 pm Post subject: |
raygreenwood wrote: |
Curious...why the importance of exercising such care in minimizing oil/anitsieze? |
Posted: Wed Oct 09, 2013 8:50 pm Post subject: ANTI SLEEEZ |
I have NEVER put anti-seize on any crankshaft on any Engine in my almost
50 years of building engines. And, never on any of the 500 + type-4 engines
either.
RAY' iS this some more steps that require wearing Boots that you seem to come up with from GOD knows Where??????.
A properly fitted puller OR press will take the fan pulley off Period!
As for reinstalling it o a type 4 tapered crank it is an interference fit.
without any thing else. _________________ V.W.owner since 1967 |
Posted: Wed Oct 09, 2013 9:53 pm Post subject: |
Wasted youth/adulthood wrote: |
Pretty simple really....a morse taper is a dead fit...nearly swaged together part. The clearance is "0".....technically its an interferance fit but the taper is what allows it not be permanent. A layer of oil can actually keep from locking if its just thick enough...which may be as little as a few microns. It works off of compression, deflection of the metal and surface friction. Its a precision fit and a marvel of design.
Old DKP driver....wear your boots if you want. How many regions and weather conditions have you built engines in? If its enough then you should know that cool conditions and humid weather in a garage shop can put a layer of water vapor or. Condensation on a part like a morse taper. 10 years later...you...your mama and 10 mules won't be able to pull a morse taper apart with any puller without damaging the ears on it. Simple care for those without the best tools and conditions.
I didn't say its what you "should" do...its simply what is possible to insure success under less than the best conditions.
Lighten up . Congratulations on never aquiring a type 4 crank that was not assembled to its hub either dirty or wet. Ray
Posted: Wed Oct 09, 2013 10:30 pm Post subject: Fan HUB removal |
I am talking about the Type-4 fan hub R&R and not trying to dis-prove your logic
And no, I don't live in Des Moines Iowa and have never removed or reinstalled
a crankshaft pulley at 40* below ZERO either...But I do know that using the proper method and tools that I will not ever resort to putting Anti-Seize on
a tapered,inteference fit in order to remove it again at 60 degrees below 0 _________________ V.W.owner since 1967 |
Posted: Thu Oct 10, 2013 3:31 am Post subject: |
Not a matter of temperature, but more of a matter of corrosion. On an engine that has seen salt spray, acid rain, and/or high summer humidity parts and pieces just don't come apart very readily. When I lived on the east coast I lathered antiseize, oil, and grease on everything and still fought a lot of seized parts. Living in Oregon corrosion is almost a non issue. You can typically get a 40 year old gadget apart easier in Oregon than a two year old gadget in New York state. |
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Thu Oct 10, 2013 6:34 am Post subject: |
Glad you got it apart, Randy.
What brand of seal are you putting back in? _________________ '76 Deluxe Campmobile |
Posted: Thu Oct 10, 2013 1:21 pm Post subject: Re: Fan HUB removal |
old DKP driver wrote: |
a tapered,inteference fit in order to remove it again at 60 degrees below 0 |
I'm talking about the type 4 fan hub as well.....where did I note that I was speaking about anything else?
Dont assume I'm from Iowa. I have lived and worked in many places and climates....which is how i know there can be problems depending on conditions....which was all I was getting at.
Actually...to be accurate it may not be a "morse" taper...but it is one of the standard industrial taper families....but I digress.
And...it is NOT an interference fit. It is a dead fit that is "wrung" together and uses friction.
Wildthings...it may or may not have anything to do with temperature,...but that was not my point.
If you get condensation on these parts (due to temperature or conditions during assembly) when assembling...as I think you went on to note...you get corrosion after assembly....which will lock these things dead tight...permanently sometimes.
Old DKP.....since you have never relocated and always been in one place...perhaps you dont know that under certain conditions ....anti-seize...prudently applied at a very fine level...is excellent advice for a taper joint assembled under adverse conditions.
When you give advice on a forum...dont assume that everyone works under the same conditions or has available the same tools you do for any task. Ray |
SGKent Samba Member
Posted: Thu Oct 10, 2013 1:27 pm Post subject: |
anyone care for some Fields chocolate chip cookies? I have some to spare today. Just drop by my desk... |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Sat Oct 26, 2013 12:35 pm Post subject: |
I pulled the hub off of my crank with a three-jaw puller... The puller got really tight and then suddenly the hub and puller came free and flew off the crankshaft with no warning. Scared the crap out of me! _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Sat Oct 26, 2013 5:23 pm Post subject: |
scrivyscriv wrote: |
I pulled the hub off of my crank with a three-jaw puller... The puller got really tight and then suddenly the hub and puller came free and flew off the crankshaft with no warning. Scared the crap out of me! |
I like to just loosen the center bolt a turn or two instead of removing it. This way when things pop loose everything will be contained and not fly everywhere. Don't much care for that smashed finger or lost eye thing.
Just drill a shallow divot in the center of the bolt for the point of the puller screw to sit into. |
