jimdickerson77 Samba Member
Joined: July 10, 2013 Posts: 43 Location: Southern Oregon
Posted: Mon Oct 07, 2013 11:50 am Post subject: type IV 1700cc progressive setup troubleshooting... |
ok. now that i have my distributor all dialed in where it should be, a BIG thanks to everyone for their advice and help!! now im left wondering why my carb wants to bog out when i attempt WOT. it seems if i rev it up alittle it will do it no problem but if i just do it right out the gate it bogs and falls on its face. Should i change the jets out? any certain adjustments i need to make? Its a Empi brand DFEV 160 and damn near brand new. any help would be greatly appreciated. Thx again. |
aryue Samba Member
Joined: January 16, 2006 Posts: 1027 Location: Austin, TX
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Oct 07, 2013 1:51 pm Post subject: |
When you quickly open the throttle the carb uses the accellerator pump to squirt gas down the throat. This prevents the symptom you are describing. With the engine off look straight down the carb and pump the throttle while holding the choke open. If you don't see gas squirting then that's your problem. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Mon Oct 07, 2013 5:04 pm Post subject: |
Do some reading of threads written about these carbs. They are not a good match right out of the box for a Type 4 engine. Lots of ideas out there, you will just have to find what works for you. |
Posted: Mon Oct 07, 2013 6:22 pm Post subject: |
yea took some special tweaking and changing out the primary jet to get it right but i think ive got it now..thanks again everyone for the help. more questions to follow. |
NoBudgetVWGarage Samba Member
Joined: November 27, 2008 Posts: 755 Location: Quartz Hill,CA
Posted: Mon Oct 07, 2013 7:17 pm Post subject: |
I see another thread regarding fuel injection. Your probably better off with dual carbs. Kads would be good, Dual 2BBL would be NICE (Dellorto's, IDF's) _________________ 1969 Transporter
1968 Ghia
1959 Ghia Hot VW Drag Car |
