Stock 71-74 T1 AE engine (Dynomation 5 engine simulation)
Lionhart94010
Lionhart94010 is offline
PostPosted: Sun Oct 06, 2013 9:58 pm    Post subject: Stock 71-74 T1 AE engine (Dynomation 5 engine simulation) Reply with quote
Stock 71-74 T1 AE engine simulation
In order to see what engine modifications are beneficial on T1 engines Id like to start with an accurate simulation of a stock T1 AE engine, I have entered the parameters I could find and measure parts I have, and would be thankful if anyone as any additional information(specs) or corrections to what I have so far or knows where I can find the information I am missing
After getting the most accurate stock simulations possible, I will make changes to the stock configuration and post the results for the benefit of thesamba community :0)
The current simulation specs I am using are below:
And Give the following Simulation result = Max HP
Wave Action Simulation
Wave-Action Cycles: 4 Wave ---------- Action Model: Fine
Wave Action RPM Step: 500 ---------- Start RPM: 1,000 ----------- Finish RPM: 5,000
Environment
Equivalent Elevation: 0.00 ft ---- Air Temp: 70.0 def F ---- Humidity: 50% (= Afternoons)
Short Block
No Cylinders: 4 ----- Bore: 85.5mm (3.366in) -------- Stroke: 69mm (2.717in) ------- Volume: 1,584.51cc
Rod Length: 137.11(5.398in) ---------- Rod Ratio: 1.987 -------- Wrist-pin offset: 1.5mm
Cylinder Head
Type: 2-Valve, Wedge Low/Perf Stock Ports/Valves
Intake Valve: 35.61mm(1.402 in) -------------- Exhaust Port Valve: 32.11mm (1.263 in)
Induction (If anyone has stock head flow data there is an option to enter it :0)
Intake Manifold Design: Non-Tuned, Small Runner, Restrictive
Plenum configuration: Common Plenum
Total Induction Air Flow Rate: 114.9 cfm ----- @1.50 inHg
Wave-Action-Intake
Intake Runner Length: 685.8mm (27in ) ------ Mini Port aria (per Valve) 812.9 sqmm (1.26 sqin)
Beginning Aria: 864.1 sqmm (1.34 sqin ) ----------- Average total Taper Angle: 0.1 Deg
Camshaft
Cam Specifications--------- Intake -------- Exhaust
Gross Lobe Lift: -------------- 0.309 in ------- 0.291 in
Rocker Ratio: ----------------- 1.10 ------------ 1.10
Gross Valve Lift: ------------- 0.340 in -------- 0.320 in
Valve Lash: -------------------- 0.006 in ------- 0.006 in
Net (Sim) Valve Lift: --------- 0.334 in ------- 0.314 in
Valve Dur @ .006: -------- 256.0 --------- 256.0
Center Line Angle: -------- 108.0 ---------- 108.0
True Center Line: ---------108.0 ---------- 108.0
Cam Adv(+)/Ret(-): ---------- 0.0 -------------- 0.0
Lobe Centerline: 108
Valve Overlap: 40.0
Lift Accel Rate: 2.52
Valve Events ------------------------------------IVO------IVC------EVO------EVC
Seat-to-Seat Event Timing -------------------20.0-----56.0-----56.0------20.0
720-Based --Event Timing ------------------340.0---596.0----124.0----380.0
0.050-inch ---Event Timing ------------------(-)1.0----35.0------35.0----(-)1.0
True Timing (Adv/Ret and Rocker Ratio): 20.0-----56.0-----56.0------20.0
Combustion
Compression Ratio: 8.0 ------- Combustion Space 56.59cc----- Cylinder Volume 396.13cc
Fuel Type: Gasoline --- Air Fuel Ratio 12.5:1 (max power, WOT)
Combustion Chamber design Wedge, Open --- Chamber Timing requirements 24 Deg
Basic Ignition Timing @ Crank: 5 BTDC ---- Estimate Ignition Timing (for best Torque @ Each RPM Point)
Timing Advance (Mechanical) 10.0 Deg Per 1,000 RPM until 3,000 RPM
Exhaust
Filling / Emptying Exhaust Model
Wave-Action-Exhaust
Style: Normal --------------- Mini Port Aria (Per Valve): 1.18 qsin
------------------------Header ------------ Collector ------------ Megaphone
Length: -------------26.00 in---------------24.00 --------------- NA
Inlet Dia: -------------1.250 in---------------1.250 in ---------- NA
Exit Dia: --------------1.250 in---------------1.250 in ---------- NA
Taper Angle: ---------0.00 in----------------0.00 in
https://www.thesamba.com/vw/gallery/pix/805878.jpg
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 72 KG GT;0) 12 JSW TDI
Other owned VWs 59, 68 1500s, 69 & 71 Bugs; 72 & 73 S-Bugs; 67 Westy, 67 Deluxe, Other 71 DC
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
