61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Posted: Wed Nov 22, 2017 8:47 am Post subject: Re: Share your wrenching tips and tricks! |
Thought I'd share a shop trick, though perhaps this is common knowledge?
Repairing some plastic that has cracked but not split apart and need to glue it back together using super glue? Well, how do you get the glue down into the crack?
The trick is to use a needle. Gently wedge the needle into the crack and then apply the glue to the needle. The super glue will then travel down the needle and into the crack, where it's needed. This is also a far more clean repair then trying to force the glue through the dull tip, which ends up mostly smearing the glue on the surface of what you're trying to repair. This trick also works for precision oiling, btw.
Hope everyone has a happy Turkey day!
-Kevin _________________ 1986 Westfalia Weekender Wolfsburg, RJE 2.3
1985 Tin Top, Subie 2.2 + 5MT
Floppy Mirrors no more: http://www.thesamba.com/vw/forum/viewtopic.php?t=653018&highlight=
Remove the front spindle nut with ease: https://www.thesamba.com/vw/forum/viewtopic.php?t=679567&highlight=
Remove the rear wheel bearing housing without messing with the big 46mm nut: https://www.thesamba.com/vw/forum/viewtopic.php?t=679507&highlight=
-Nec Spe, Nec Metu |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9616 Location: Western WA
Posted: Wed Nov 22, 2017 8:50 am Post subject: Re: Share your wrenching tips and tricks! |
Kevin I LIKE that! _________________
....KTMs, GasGas, SPOT mtb |
RicoS Samba Member
Posted: Sun Dec 10, 2017 5:50 pm Post subject: |
dhaavers wrote: |
. . . I had 3 hardened steel wedges made by a blacksmith friend (or a machine shop could do this - not
sure if there's anything ready-for-sale out there...)
In case you don't have a friend, wedges like these are called flange wedges and any decent industrial supply house will have them in various sizes for a few bucks a piece.
As is usually the case, that wheel is already rolling.
Richie (near The Burgh) |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Sun Dec 10, 2017 8:11 pm Post subject: Re: Share your wrenching tips and tricks! |
#4 Rod holder.
_________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Abscate Samba Member
Posted: Sun Dec 10, 2017 11:32 pm Post subject: Re: Share your wrenching tips and tricks! |
I need a rubber band like that, that goes through the little end...
_________________ .ssS! |
Posted: Sun Dec 10, 2017 11:43 pm Post subject: Re: Share your wrenching tips and tricks! |
Another Volvo fanatic like me!
One tip on loosening soft brake lines. Crack the connection on the caliper before you remove it so you can put pure torque on the connector as it is held tight on the car, a lot easier than trying to hold it while torquing.
If you crack the connection and run just a dribble of brake fluid each time you replace pads or your 24 month fluid change, the lines will come free when they need replacement EZPZ
I keep four bleeder screws for every car in my toolkit every time I do brakes, and they get replaced each time I do pads. I haven’t wrestled with snapped bleeders in decades, even in the Northeast _________________ .ssS! |
RicoS Samba Member
Posted: Mon Dec 11, 2017 6:53 am Post subject: Re: Share your wrenching tips and tricks! |
I think I bought from Grainger . . . once. Same with Fastenal. Both places have a large inventory of stuff, but they also want you to bend over whenever you buy something.
McMaster-Carr has flange wedges for a reasonable price. Of course you have to pay shipping.
Some notes on sourcing:
1/ With the de-industrialization of our great nation, Mc-Master-Carr seems to have become the de facto hardware of the USA. Although, they have changed a bit over the past 20 years, McMaster-Carr still has damn near anything, they answer their order line on the first ring, stuff usually arrives the next day with no expedited shipping charge and, if you buy enough, they will still send you a copy of their 4-inch thick catalog. Also, they may be the ONLY source for those out there in the hinterlands.
Unfortunately, as I've recently observed, McMaster seems to have hired the clueless to work their warehouses which results in small purchases, at times, arriving in coffin-sized boxes. Still, they do not pad their shipping rates.
2/ For those who live far away from a large city, do not overlook the supply houses which service the various trades; electricians, plumbers, HVAC guys, etc. You might be surprised what you will find there. Also, don't forget the farm supply joints or those places which serve the heavy truckers.
3/ There are still jobbers everywhere who will rebuild any alternator, re-core any radiator or provide you with any bit of hardware. The trick is finding them and knowing what you want whenever you enter their turf. Nothing tests the patience of a surly counterman more than some millennial who thinks the guy behind that counter should also be a mind reader.
Richie (near The Burg) |
RicoS Samba Member
Posted: Mon Dec 11, 2017 7:02 am Post subject: Re: Share your wrenching tips and tricks! |
Abscate wrote: |
. . . I keep four bleeder screws for every car in my toolkit every time I do brakes, and they get replaced each time I do pads. I haven’t wrestled with snapped bleeders in decades, even in the Northeast |
Great advice! Sign me up.
I'll be buying a pocketful of 8mm bleeders. One thing that has been irking me is getting rebuilt calipers with 6mm bleeders. It might seem petty, but it's a nuisance to have to carry two wrenches just to wrap up a brake job.
Thanks.
Posted: Mon Dec 11, 2017 8:17 am Post subject: Re: Share your wrenching tips and tricks! |
RicoS wrote: |
Abscate wrote: |
Thanks.
Yeah - when the rebuilders get the cores, the frozen bleeders are drilled out and retapped a size up. You can get conversions in brass but if you keep the bleeders new, you don't run into the strip problems unless you
One more reason to buy from a shop and not over the internet. BAP GEON here in Albany is great - I tell them to get me a rebuilt but the bleeders have to be stock size. Call me when I can pick them up. _________________ .ssS! |
SyncroBouree Samba Member
Joined: August 25, 2017 Posts: 26 Location: Alongside Monterey Bay
Posted: Mon Dec 11, 2017 10:57 am Post subject: Re: Share your wrenching tips and tricks! |
Having replaced my rear-axle cv joints with 944 units and new fastening hardware earlier this year, I thought to squirt a dollop of rtv into the head of each flange bolt after everything was set to torque.
The subsequent task of disconnection to drop the engine and transaxle for this season's resto-mod went much more smoothly because the cured rtv plugs just pop out and saved me the task of digging out the usual crud to ensure the that the bit bottoms out.
Seems like it might make the vow for regular maintenance of those units a bit easier to carry out. |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Mon Dec 11, 2017 11:07 am Post subject: Re: Share your wrenching tips and tricks! |
SyncroBouree wrote: |
Just ordering new boots and about to to do the same chore, thanks for the tip!
Great post for the first one too. I love those simple things that make my future self life easier....usually the opposite. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Mon Dec 11, 2017 11:26 am Post subject: Re: Share your wrenching tips and tricks! |
you guys mean THIS VW engine rebuild kit?
Posted: Mon Dec 11, 2017 11:31 pm Post subject: Re: Share your wrenching tips and tricks! |
0to60in6min wrote: |
Ha! New in the box. Genuine German rubber? Score!
(I bet it has a hefty core charge tho.... ) _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Tue Dec 12, 2017 6:32 am Post subject: Re: Share your wrenching tips and tricks! |
_________________ This free advice is worth exactly what you paid for it.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32630 Location: Reading Pennsylvania
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Dec 12, 2017 11:21 am Post subject: Re: Share your wrenching tips and tricks! |
Good lord this thread is a wealth of great ideas.
I don't know how I missed it and wish I'd seen it before entering the world of Pennsylvania Rust Hell, but I'm glad I have it now. Thanks to all who have contributed.
I know there's been a lot of discussion about that pesky front nut on the clutch slave cylinder, and that welding or JB welding works well, but I've found that using masking tape to tape the nut to a slim box-end wrench then sliding it through the slit works well to hold the nut in place while you start the bolt. Not a big deal, but it works... _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4799 Location: Bemidji, MN
Posted: Tue Dec 12, 2017 11:34 am Post subject: Re: Share your wrenching tips and tricks! |
have WHAT, man???!! i have to do bushings and what made it easier?!!
-dan |
Zeitgeist 13 Samba Member
Posted: Tue Dec 12, 2017 11:57 am Post subject: Re: Share your wrenching tips and tricks! |
Righty tighty and lefty Lucy...unless it's not.
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
