thinginneed Samba Member
Posted: Wed Dec 03, 2003 9:45 am Post subject: Front Beam Supports |
I'm new to VW THings, but have always wanted one. I now have one, but am starting to have questions. Can anyone tell me where the triangle shaped front beam supports are supposed to attach to the car? They came in a bucket parts with the car, but I can't see where they attach.
Thanks |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Wed Dec 03, 2003 10:34 am Post subject: |
there are two horizontal bolts on each side that attach the braces to a flange on the front beam, and two more bolts on each side that bolt up into the front bulkhead from the bottomside of the pan. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
Chris181Westy Samba Member
Joined: August 05, 2003 Posts: 148 Location: Michigan, The Third Coast!
Posted: Wed Dec 03, 2003 5:50 pm Post subject: |
One possible problem, if the beam supports were in a parts bucket this leads me to beleive that the original Thing beam rusted out and was replaced with a bug beam. And whomever did the job did not remove and replace the plates that are welded on the beam. The beam supports bolt on to those plates. If this is the case you will need to get 2 rectangle plates drill 2 holes in each of them and weld them to your beam. Then you will be able to bolt the beam supports on.
Look at the back of your shock towers if there are not two plates with holes in them, this is the case. If the plates are still there, then you are in luck! Bolt those bad boys on! If you are really lucky you have supports on your car already and you just have a extra set!
But my glass is half empty and I bet somebody did a half assed beam replacement on your 181. My first Thing was the same way, but they threw the supports away! At least you have them. _________________ "So we went for a spin in the country
To feel the wind in our hair
To feel the power of my engine
To feel the thrill of desire"
Roger Waters, The Pros and Cons of Hitchhiking |
Posted: Thu Dec 04, 2003 4:10 pm Post subject: |
thinginneed, did you look under your Thing and see what is up? _________________ "So we went for a spin in the country
Posted: Mon Dec 08, 2003 9:39 am Post subject: |
First, let me thank you both for the replies. And yes I did crawl under this weekend. I can see where the brackets were on the beam. BUT, someone has removed them and welded in a pair of brackets to mount a "home-made" bumper. Apparently there was a frontal impact and the bottom sheet metal behond the apron has been cut out, so nothing to mount the bumper to! Oh I hate butchers!
Anyway, I am working on getting myself another front beam to replace that one. And also trying to figure out what to do about the missing body section!
Thanks again for the help, and by all means if you have any suggesstions for this newest problem I would love to hear them. |
flamed74vwthing Samba Member
Joined: November 27, 2003 Posts: 21 Location: memphis
Posted: Mon Dec 08, 2003 9:55 pm Post subject: |
I have had my car on the road for 2 years without the y supports
without any problems but my car dosent see much off road |
