robin.richard Samba Member
Joined: February 17, 2012 Posts: 497 Location: V. Beach VA
Posted: Wed Oct 23, 2013 8:46 am Post subject: Sound proofing your split |
Hello,
I was walking around one of those BIG BOX hardware stores the other day and found some floor sound control material that claims it will reduce noise by up to 75%. The product is called dB-4LOORING sound control solutions. It is a thin mat made from recycled rubber that can be installed under wood, tie, carpet or vinyl flooring. It comes in large rolls and is relatively inexpensive @ 25.00 bucks a roll. Maybe 4' x 8 ' I think. Has anyone tried this stuff on the floor and over the engine compartment to reduce the noise. If it works, it may be an inexpensive option compare to some of the vehicle specific products out there, and it can be easily removed since it does not use adhesives, just a thin rubber mat you can place under your flooring.
-Rich |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Wed Oct 23, 2013 10:08 am Post subject: |
I'm not familiar with the product.
I've come across a more permanent product with excellent attenuation (spray or roll on).
It also has rust inhibitive properties.
Noxudol 3100 (regular)
Noxudol 3101 (+ fire resistant)
Cheers,
E _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
rebapuck Samba Member
Joined: May 17, 2007 Posts: 1023 Location: Chapel Hill NC
Posted: Wed Oct 23, 2013 10:38 am Post subject: |
I'm going to check that out. Thanks. I don't really want to adhere anything. This may be just the ticket. _________________ Judy
1966 Camper "Hannah"
1967 SingleCab "Khady" |
quartermilecamel Samba Member
Posted: Wed Oct 23, 2013 12:24 pm Post subject: |
We don't have BIG BOX hardware stores here. I did go to summit racing and pick up their 4 x 8 rolls of rubber mat. 50 bucks. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Posted: Wed Oct 23, 2013 7:50 pm Post subject: |
Actually, my biggest concern is whether there is an odor. Do these rubber linings smell like tires when the bus heats up? _________________ Judy
Old Paint Samba Member
Joined: May 29, 2010 Posts: 436 Location: Battle Ground, Washington
Posted: Wed Oct 23, 2013 9:13 pm Post subject: |
I used the foil backed adhesive roof flashing from the big box store in the 61 Bug, AMAZING results, took all the rattle out, whatever you use, make sure you dont get anything that will hold water. And no, the stuff I used doesnt stink, but my Bug is a Ragtop so its well ventilated, and 85 is a hot day here. _________________ Greg
1961 Ragtop
1961 Single Cab (Old Paint) |
Sdmjake Samba Member
Joined: May 01, 2012 Posts: 124 Location: Sandy Springs, GA
Posted: Thu Oct 24, 2013 6:22 am Post subject: |
I installed FatMat and the difference is amazing. My camper started out as a panel 45 yrs ago and those things are inherently noisy. Putting it in the doors made a tangible difference. The door 'clunks' (rather than a tinny clank) when closed. The engine noise was reduced a bunch too. (I didn't measure dB or anything but it is definitely quieter) I didn't notice any smell after about 24 hours...
I recommend it. |
dirtylawnchair Samba Member
Joined: January 26, 2004 Posts: 1234 Location: Bradenton FL
Posted: Thu Oct 24, 2013 6:34 am Post subject: |
I used this before installing my RJ Camper kit. Made a big difference.
http://www.lobucrod.com/
_________________ Paulie
63 Standard OG paint |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Thu Oct 24, 2013 7:04 am Post subject: Re: Sound proofing your split |
robin.richard wrote: |
Hello,
I was walking around one of those BIG BOX hardware stores the other day and found some floor sound control material that claims it will reduce noise by up to 75%. The product is called dB-4LOORING sound control solutions. It is a thin mat made from recycled rubber that can be installed under wood, tie, carpet or vinyl flooring. -Rich |
I used that stuff under my laminate floors and it works. This would require glue as well. Shop around, because I know my wife got the rolls for our floor as low as $15 a roll.
I used this stuff in the DC @ $17 a roll and it's sticky backed. Yes it works, I put it on the roof, walls and in the doors and you can tell when you shut the doors.
_________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Cuņado Wear Samba Member
Joined: December 10, 2006 Posts: 1145 Location: The "O"
Posted: Thu Oct 24, 2013 11:53 am Post subject: Re: Sound proofing your split |
DubStyle wrote: |
Hello,
This is also the stuff I used. Works great! I put that in my whole bus and wow
I did notice that if you use spray adhesive with it, it works even better.
I put it on my roof and waited a whole year before I did headliner to see if it would hold and it did. held up over many hot days over 100 degrees.
When I started it was $15 bucks a roll and now its up to $20. I believe it took 6 rolls to do my whole bus. _________________
Bulli Klinik wrote: |
I may be a little late to the party, but what the hell is Cunado Wear? |
Looking for front kick panels for late 63' Deluxe Basalt Gray
60' Double Cab
63' 15 Window Deluxe |
abritinthebay Samba Member
Joined: May 31, 2012 Posts: 294 Location: San Francisco, USA
Posted: Fri Oct 25, 2013 10:50 am Post subject: |
As a general rule - anything that is solid in rolls is roofing material that's being rebranded.
I mean... it'll work alright, and it'll be cheaper, but it's not going to be as good as dedicated materials like Fat Mat or Second Skin's products.
But... it'll work ok. While it lasts at least. |
