Rene60 Samba Member
Joined: December 18, 2012 Posts: 118 Location: Crescent City Ca.
Posted: Thu Oct 24, 2013 4:40 pm Post subject: Steering damper bushing |
What is the easiest way to install a new bushing without removing the drop arm. I have been trying all day to get that little sucker in there, it just don't want to go in. I have tried talcum powder, grease, liquid soap, nothing seems to work. The PO had a smaller diameter bolt and nut holding it in place, which wobbled around and tore up the bushing.
Any help wil be greatly appreciated.
Thanks for all the help. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Thu Oct 24, 2013 4:54 pm Post subject: |
Great -and rare - question.
Any way to rig up a makeshift puller/compressor using a bolt, a nut, and two large washers? As you tighten the nut, the washers will pull towards each other and push the new rubber bushing into place.
At least it works great in my mind !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Rene60 Samba Member
Posted: Thu Oct 24, 2013 5:00 pm Post subject: |
That's what I thought too.
It goes in just to were the drop arm tapers then the bushing starts to compress. |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Thu Oct 24, 2013 5:17 pm Post subject: |
On tough situations (and ive had success with it)I heat the rubber up some it goes right in with a lil twisting.. |
Rene60 Samba Member
Posted: Fri Oct 25, 2013 5:17 pm Post subject: |
Well I finally got the bushing in. I tried Cussers way, and I tried 68IHscout's way, either one worked. What I ended up doing is sanding some of the bushing down used graphite for lubrication and with a little force it popped in.
But I do appreciate the help Cusser and 68IHscout offered.
Thanks again |
cjsuner Samba Member
Joined: January 04, 2013 Posts: 476 Location: Bay area CA
Posted: Fri Oct 25, 2013 10:51 pm Post subject: |
Just incase anybody else is wondering how to do it, me and my dad used a ball joint remover/popper thing to compress it into place, worked like a charm! |
Rene60 Samba Member
Posted: Sat Oct 26, 2013 6:56 am Post subject: |
I didn't have a ball joint remover tool. So I had to come up with a make shift tool. But I would like to get an assortment of pullers and other tools that would make working on these easier.
But half the fun working on these is busting your knuckles up. |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Sat Oct 26, 2013 8:05 am Post subject: |
I always use a chatter gun (air Hammer) with a valve guide bit with a large washer, shave a little off the bushing and Push it in. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
Gerrelt Samba Member
Joined: December 22, 2004 Posts: 682 Location: The Netherlands
Posted: Sat Oct 26, 2013 8:26 am Post subject: |
I used a socket and a long bolt, see this superbeetle topic for pictures: super beetles only link _________________ homepage
_________________ |
Rene60 Samba Member
Posted: Sat Oct 26, 2013 8:54 am Post subject: |
The old bushing basically fell out. I started with the bolt and nut but when I loosened the nut the bushing just popped out.
Thanks for the link though, I'll hang on to it for reference. |
Posted: Sat Oct 26, 2013 9:07 am Post subject: |
Glad you got it fixed ,....good info here from all who posted , just goes to show you ,,there are almost always more ways to skin a cat.... |
FlyAU98 Samba Member
Joined: September 12, 2020 Posts: 67 Location: Milton, FL
