junichi Samba Member
Joined: September 12, 2005 Posts: 749 Location: brentwood bay, bc
Posted: Tue Jun 03, 2014 11:24 am Post subject: |
FWIW, I just took my slats off. They were mostly rotten and underneath them was full of grime. Some spots had started to rust because of it. I live in a wet climate.... _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf |
xriss55 Samba Member
Posted: Thu Dec 05, 2013 7:09 pm Post subject: |
and again matt...
Posted: Thu Dec 05, 2013 6:56 pm Post subject: |
matt your load bed slatts should be something like this
Syncrozilla Samba Member
Joined: September 11, 2004 Posts: 772 Location: Santa Barbara
Posted: Fri Nov 29, 2013 10:25 pm Post subject: |
Only the 16" rear wheel cylinder body is different. The pistons and seals are the same. It the body is in good shape you can rebuild it with 14" parts. _________________ Please do not message me on TheSamba. Use my email, [email protected] |
syncroid Samba Member
Posted: Fri Nov 29, 2013 10:12 pm Post subject: |
I love this: Rear wheel Cylinder: €10.90; Rear Wheel Cylinder 16" syncro: €98.00
Maybe I'll just buy the rear brake "cheeks" for now and hope that my cylinders are healthy.
Thanks for the link! |
Reventlos Samba Member
Joined: May 24, 2009 Posts: 103 Location: Costa Mesa, CA
Posted: Fri Nov 29, 2013 5:37 pm Post subject: |
syncroid wrote: |
Do I understand correctly that Europro in Costa Mesa managed to rebuild your 16" rear brakes? Shoes, cylinders, etc? |
Nothing too esoteric about the brakes themselves, it's all about the parts! Lots of hard-to-find stuff here, and they ship to the US!
http://www.vwbusshop.de/epages/GuenzlClassicParts....mse_hinten |
Posted: Fri Nov 29, 2013 2:01 pm Post subject: |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Thu Nov 28, 2013 10:27 pm Post subject: |
You can free that locker. Pull the actuator ( if it leaks vacuum, just crush it with diagonal cutters and pull the bits off), wire rush the shaft where it enters the case and spray PB Blaster or similar. Not wd40 as it's not strong enough but will do a beautiful job of blocking anything you subsequently spray from working into the corrosion. Then commit to tapping it vigorously with a brass hammer a few hundred times a day. I just kept a clean cloth down there to lay on and whenever I thought of it I would flop down there in street clothes, spray and tap. When it starts to move, you will need to pull it back out manually with protected vice grips and something to pry with such as a stout screwdriver. I moved it an eighth inch then pulled it back out many times. I also removed the switch above it which lets you apply PB blaster directly on the shaft inside. You should change the gear oil after that, however. A new actuator is only 85 or so from van cafe. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4087 Location: East Kootenay, British Columbia
Posted: Thu Nov 28, 2013 8:44 pm Post subject: |
So very nice!
I'm looking forward to some of this work on my 16" Joker Fortunately I don't have the rust issues but I am planning on chasing down all those 16" specific bits.
One can only hope that VW Classic will come through on the wear items since there are the LTs to rebuild also.
Clip1 has started to carry the 16" rear drums (made in Italy) Hopefully more bits on the way!
edit:typo _________________ Currently:
Tristar Eric Samba Member
Joined: July 25, 2004 Posts: 1242 Location: Portland, Or
Posted: Thu Nov 28, 2013 7:35 pm Post subject: |
Uber cool Matt! can't wait to see it at Syncrofest.
Eric _________________ Vanagon/Transporter flares here: www.terrawagen.com
[email protected] |
Posted: Thu Nov 28, 2013 3:43 pm Post subject: |
I'm with Shaun on the bed. Leave the factory paint. Add some wood slats. I'm pulling for you on the rear diff lock. _________________ Please do not message me on TheSamba. Use my email, [email protected] |
GreenMachineVW Samba Member
Posted: Thu Nov 28, 2013 1:54 pm Post subject: |
syncrodoka wrote: |
There are many differences with the syncro 16 model... |
And I am seeing more and more. Rear brakes was just a new one to me, and was more wondering if it was a difference, or a customization. And even though the differences are mentioned, nice photos like that one sure make it easier to ... visualize! |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Thu Nov 28, 2013 1:36 pm Post subject: |
There are many differences with the syncro 16 model. Brakes, suspension, drivetrain, body reinforcements etc. They have low production numbers and were only for the european market as well.
They aren't like any run of the mill vanagon and that has been mentioned many times in the past. |
Posted: Thu Nov 28, 2013 1:23 pm Post subject: |
syncrodoka wrote: |
GreenMachineVW wrote: |
I was under the impression that the rear brakes were the same on all years and models, but yours sure look stock (or at least VW, by the label). Also looks like six big bolts going through the brake plate into the trailing arm, where mine only has four behind the brake plate. |
syncro 16 |
I thought syncro 16 was a Vanagon model, and "I was under the impression that the rear brakes were the same on all years and models" The real answer and explanation was above, not simply repeating that we are talking about a 16 inch version, which must have got lost in the title ... Thanks for you two words anyway ... |
Posted: Thu Nov 28, 2013 1:09 pm Post subject: |
syncro 16 |
zeohsix Samba Member
Joined: August 31, 2012 Posts: 501 Location: United States
The same ... but different!
Nice work! |
Syncro 16's have larger front/rear brakes. The rear drums share parts with VW LT commercial series vehicles. Syncro 16 rear bearing carriers and outer axels......we're talking rare hard to find stuff there! |
Posted: Thu Nov 28, 2013 1:04 pm Post subject: |
Nice work! |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Thu Nov 28, 2013 12:48 pm Post subject: |
MAtt
Looks like your checkbook got quite the workout there . Nicely done and done by a real pro .
I'm with Shaun ,leave the bed alone . Buy some Bed slats and return it to stock . I have a set of them sitting at home if you want to have them copied .
As far as speakers, I made a set of speaker boxes that mounted below the seat belts on the B pillars . I found a project box at a FLAPS that fit perfectly in that space . I put a bracket on the back that bolts up to the seat belt retract-er and was able to install it with no holes drilled . Sorry I have no pictures ,but my Doka is now in Hawaii and the new owner " Zohami" might be able to forward some shots to you .
Are you going to take your Jag and duplicate the picture of your camper on Truck hill that you use for Avatar .
Look forward to seeing it at Syncrofest .
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
trailnewt Samba Member
Joined: February 17, 2008 Posts: 248 Location: Northern California
Posted: Thu Nov 28, 2013 8:36 am Post subject: |
That's beautiful Matt! I'm eager to see it in person. Some list members have reported diff lock success with daily applications of WD-40 and tapping on the shaft; after a few days of this it finally loosens up.
Brent _________________ '87 Syncro Westy TDI
Too many bicycles
Maybe an old unicycle around here somewhere |
shaun0008 Samba Member
Joined: December 14, 2004 Posts: 58 Location: San Francisco
Posted: Thu Nov 28, 2013 8:18 am Post subject: |
Hello Matt, My vote is to leave the factory paint on the bed as it is. Unless you plan to do heavy work from this truck a bedliner coating would be overkill. And the bed only has factory paint once. A couple of tarps or some plywood cut to fit would work well for the odd DYI project. I just painted my Tristar and I use it for some heavy work and will be having it X-lined as it is far from OG paint. I will send you a few photos when it is done and you get idea of what it will look like. Shaun _________________ 1990 Tristar Syncro Doka
1987 German fire van
1987 German Army Radio van
1987 German Ambulance
1990 16" Syncro Westfalia
1963 Beetle Convertible |
