DeVertible Samba Member
Joined: May 23, 2013 Posts: 85 Location: Sequim, Washington
Posted: Fri Oct 25, 2013 3:01 am Post subject: 6 Volt Idle Shut Off for H30/31 Solex |
Does such a shuf off exist or how have others handled using this carb on 1600 upgrades while retaining 6 volt system. Thanks Carl |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Oct 25, 2013 7:27 am Post subject: |
If you mean the fuel solenoid on the (passenger) side near the generator?
6 volt shut off solenoids were used on some Type 3 carbs (and others) until 66
They are sized and replace the standard jet.
http://www.thesamba.com/vw/forum/viewtopic.php?t=434602 _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Fri Oct 25, 2013 7:52 am Post subject: |
The shut off solenoid yhat is wired to the coil. I need a 6 volt threaded and made to fit the later model h30/31 solex. |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Fri Oct 25, 2013 10:20 am Post subject: |
It doesn't look like you'll be able to find one easily.
See if it will work with 6V...it might pull back - I've never tried it.
Other options are to modify the 12V one to work (re-wind the coil?) or just cut the plunger off. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
bluebus86 Banned
Posted: Fri Oct 25, 2013 10:51 am Post subject: |
you could try a step up device like they sell for running 12 volt radios in 6 volt cars. |
Posted: Fri Oct 25, 2013 12:23 pm Post subject: |
DeVertible wrote: |
They are all wired to the coil and are all threaded.??? _________________ aka Ken {o\!/o}
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Fri Oct 25, 2013 2:35 pm Post subject: |
He means the big plunger style. I have seen a photo of 6V version of that cutoff solenoid, but never in person. Very rare. 6V won't pull in the solenoid of a 12V version.
The kind that plugs off the (auxiliary fuel) jet on a H30/31 is much more common. You could try one of those and just cut of the plunger on the other cutoff.
However I think I'd just not worry about it and run with a cut off plunger.
(Actually I wouldn't even choose an H30/31PICT, I'd get a 30PICT-1.) |
Posted: Fri Oct 25, 2013 6:14 pm Post subject: |
So
Air solenoid
not fuel solenoid...... _________________ aka Ken {o\!/o}
Culito 11010101
Posted: Fri Oct 25, 2013 7:56 pm Post subject: |
VOLKSWAGNUT wrote: |
So
Air solenoid
not fuel solenoid...... |
'62 bug
johnnypan wrote: |
Posted: Fri Oct 25, 2013 8:46 pm Post subject: |
Thanks all for identifying my options. I'll first try using six volts to see if it pulls it back and if not . . . . just cut the plunger Thanks again |
