slunk33 Samba Member
Joined: November 28, 2004 Posts: 326 Location: Tacoma, WA
Posted: Sat Oct 26, 2013 11:43 am Post subject: Drivers Door Trim Stuck?!? *Update* Actually Hinge Mechanism |
The drivers side door on my 89 Vanagon fell open when park sideways on an incline. The door made an unusual pop noise, and it was difficult to close. I was able to close it, but when I got home, the door would not shut at all. I thought it was the fiberglass side skirt, and removed it, but it still would not close. I forced it shut to go to work, but it pops every time I open and close it. The hinge molding looks out of place. Anyone know how to fix that? It appears as if the molding is behind the door, instead of in front of it.
Thanks! _________________ Current VW's:
'70 Standard Beetle Convertible, '89 Vanagon Wolfsburg (Bluestar) "Gonzo", Peg-Perego Magica
Former VW's:
'72 Bus, '75 Bus, '78 Sunroof Bus, '87 Vanagon GL, '00 Jetta TDI (Gas companies don't miss her, but I do), '04 Passat Wagon
Posted: Sat Oct 26, 2013 12:55 pm Post subject: Worse Than I Thought |
Looks like I did some damage. The door retention mechanism(?) broke (I'm not sure what its called). I took the door panel off and there was a plastic cap on it. When I took the cap off, there was sheered off metal and broken plastic. Looked on van-cafe, but could not find it. Do I need to get this from a junk van? Can I remove this without any harmful effects? If so, how do I? Any help would be greatly appreciated.
Mechanism:
What it looks like inside the door with plastic cap removed:
Broken metal and plastic:
Former VW's:
'72 Bus, '75 Bus, '78 Sunroof Bus, '87 Vanagon GL, '00 Jetta TDI (Gas companies don't miss her, but I do), '04 Passat Wagon |
Posted: Sat Oct 26, 2013 2:34 pm Post subject: |
That is commonly known as a check strap (if your old) or a check rod. I don't think that they are available new in the US. That strap limits how far your door opens. Without it, all of the stress is put into the hinges and the door can actually open far enough cause damage to to it. You can get away without it if you are really careful about not letting the door fly open, but I would replace asap.
To remove it, first remove the circlip on the bottom of that pin that you can see in your first photo, then drive the pin up and out and that potion of the strap should pull right out. Next remove the two phillips head screws from inside the door to remove that portion. Your mounting tabs where the pin goes through appears to be bent a little, so you will have to straighten those before reassembling things. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
bluebus86 Banned
Posted: Sat Oct 26, 2013 4:37 pm Post subject: |
Yes get that door check strap (rod) replaced asap. Without it, the door can over swing open and body / door damage can result if this happens. granted the check strap is a little weak for such a big door. If you call Van Café, thy may be able to source a used part for you, they do not have everything they can get online in their catalog. they do have resources to find used parts, of course if you have a local wrecker to pull it out of a dead van, it will be considerably less expensive. one other source would be to call Fred's Garage in Redwood City calif. they have some wrecks their too.
from your first photograph, it might be that the bracket that holds the pin may be bent up or torn. (hard to tell, maybe it is ok????) make sure it is in good condition too. |
Posted: Sat Oct 26, 2013 6:12 pm Post subject: |
Awesome! Thanks for the replies. Going to check with a local yard, first. Is that part the same on all Vanagons or is that an 86-91 only style? _________________ Current VW's:
Former VW's:
