Vinzanto Samba Member
Joined: March 22, 2012 Posts: 247 Location: Kansas City
Posted: Sat Oct 26, 2013 3:23 pm Post subject: Oil Pressure Sensor Woes |
So within 3000 miles I've had two oil pressure sensors/senders fail (mounted between pushrod tubes) they begin seeping oil luckily setting off my low pressure light. The first time the leak was pretty major while the second failure was slow but seeping none-the-less.
What is causing these sensors to fail in the manner they are?
Anyone else had this issue? _________________ 1984 Vanagon Westfalia Wolfsberg |
Zeitgeist 13 Samba Member
Posted: Sat Oct 26, 2013 4:11 pm Post subject: |
Are they OEM sensors? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
desertrefugee Samba Member
Joined: January 22, 2013 Posts: 476 Location: Phoenix, AZ. USA
Posted: Sat Oct 26, 2013 4:20 pm Post subject: |
The cheap ones can really spew oil when they go bad. Better to spend an extra few bucks and get good ones...or leave the engine tin off to make the next replacement go smoother! _________________ - 83.5 Westfalia - 2.2 GoWesty "power"
- a bunch of vintage motorcycles
- Numerous telescopes of various size and function
"For I have loved the stars too fondly to be fearful of the night." - Sarah Williams |
Posted: Sat Oct 26, 2013 6:56 pm Post subject: |
If by oem you mean a Bosch sensor no its not. My first thought was of course "This is Chinese junk" after seeing where it was made.
I told the guy at O'reilly that I use 20 50 and he said that is why they failed, causing too "high" of pressure. Any validity to this? Has anyone had a sensor fail that failed attributed to heavy engine oil?
I agree oem would be better but two crapping out in just 3000 miles seems subnormal. _________________ 1984 Vanagon Westfalia Wolfsberg |
Posted: Sat Oct 26, 2013 7:21 pm Post subject: |
The German vehicle aftermarket parts scene is in complete turmoil right now, so we're going to see an ad nauseating amount of these types of parts failures over the next while. OE suppliers are our only hope right now, which is expensive, and we can't necessarily rely on them to remain a bastion of quality, either. The weight of the oil theory is totally bunk. _________________ Casey--
y u rune klassik? |
