Jens-Ole Samba Member
Joined: March 30, 2010 Posts: 74 Location: Beyond Reason (Norway)
Posted: Sun Oct 27, 2013 1:19 pm Post subject: The "magnesium treatment"? |
So, i've been searching this big old internet for a way to make my new Radar repro's look older than they are. I might have read a how to on this page somewhere on what he called "the magnesium treatment" of new alloy wheels. But I cannot seem to find it. Or it's all just in my imagination
Anyway, what i'm aiming for is to have a polished edge/rim and to get the 5 spokes look something like this:
Is this possible? |
slalombuggy Samba Member
Posted: Mon Oct 28, 2013 6:22 am Post subject: |
Tape off the lip, strip the wheel with a mild abrasive such as glass and take them for a blast down the track at the Bonneville Salt Flats. That will give it the nice aged treatment It did on all my untreated aluminum.....
brad |
Posted: Tue Oct 29, 2013 5:31 am Post subject: |
Sounds perfect, only it's a pretty long way from Norway
But i guess that method will work "manually" too?
slalombuggy wrote: |
brad |
Posted: Tue Oct 29, 2013 7:06 am Post subject: |
You could always experiment on a piece of scrap aluminum using different media to blast the wheels and using an acid to oxidize the metal. Aluminum is much more resistant to oxidization than magnesium so it will be hard to duplicate. Know any good airbrush artists?????
brad |
Posted: Fri Nov 01, 2013 7:10 am Post subject: |
Airbrush, that's cheating I might just blast them and drive over the winter with snow all over and salted main roads. |
restojohnny Samba Member
Joined: February 13, 2004 Posts: 2764 Location: SPLITSVILLE , SON !!!!
Posted: Fri Nov 01, 2013 8:27 am Post subject: |
I would take the clear coat (if there is one) off with the rim down to bare metal and use wheel bearing grease and rub it into the bare metal real good then wipe it off that would give it the look you are wanting but let the grease sit awhile like a day or so.... _________________ ** HELL YEAH I'LL SELL IT TO YOU**
O.G. POMONA VULTURE
$$ SWAPMEET MAFIA $$
53 LHD, LH cargo door standard kombi
54 Pre-A Porsche
55 oval ribbed door non-semiphore
56 semiphore ragtop
63 notchback (work in progress)
67 OG black paint beetle sedan empi accessorized
67 original Empi GTV beetle convertible !!
67 euro squareback
67 deluxe walkthru (work in progress)
67 convertible ghia (work in progress)
"STAY OUTTA MY BACKYARD !!! " |
Posted: Sun Nov 03, 2013 12:59 am Post subject: |
This sounds a little more "easy accessible" compared to the Salt Flats, unfortunately.. Would love to blast down Bonneville with my 2109 engine: "just to get the look on my wheels"
But back to business, have you done this before and if so do you have any pictures?
This is the car and wheels by the way..
restojohnny wrote: |
I would take the clear coat (if there is one) off with the rim down to bare metal and use wheel bearing grease and rub it into the bare metal real good then wipe it off that would give it the look you are wanting but let the grease sit awhile like a day or so.... |
Crankey Samba Member
Posted: Fri Nov 08, 2013 11:07 pm Post subject: |
sure, this can be done.
first strip the wheels of clear coat. then mask the areas you want to stay polished. 2-3 layers of masking tape or maybe one layer of duck tape for masking.
sand blast exposed areas. after blasting, don't touch these areas at all with bare fingers or anything that can contaminate the surface.
now over the blasted face, do this process
http://www.youtube.com/watch?v=_rD7o_WXwIA
you can re do the chemical process like the video shows. rubbing the edges of the spokes to highlight them should make them look a bit more worn and used...like they have been in a giants pocket for a thousand years...
or, an easier way to fake that is to rub black paint onto the blasted surface with a sponge. then, after it's dry, rub the surface with scotchbrite until you get the desired grey/black tones you want.
after you have the amount of blackness you like, either chemical or paint process finished, clear coat the whole wheel to seal it. I would do a gloss clear, 3-4 coats. then a mat clear over the center blackened area.
search for "aluminum patina" to learn more.
chemical patina usually works better in a warm condition. not super hot just not in freezing cold open garages. heat up the wheel and chemical to comfortable room temperature.
the process with chemicals will be more frustrating as the chemicals don't usually work as well as the video shows. it will also less durable and harder to control. more toxic as well. but worth a try if you can find the patina chemicals.
the paint method would be easier and more controllable and most likely more durable.
whatever you do, post up your results ! |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Sat Nov 09, 2013 5:57 am Post subject: |
oven cleaner will etch and oxidize aluminum _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
sbnova Samba Member
Joined: January 27, 2005 Posts: 741 Location: Lakeland,FL
Posted: Sun Nov 10, 2013 12:06 pm Post subject: |
I know you want something permanent, but I would suggest Plasti-dip. It comes in spray cans, in many colors, and leaves a mat type finish. You can tape off the rim lip (just be careful when un-masking) and don't have to worry about sandblasting ruining tape or chemicals bleeding under. Using chemicals or sandblasting to oxidize may start a process that eventually ruins your wheels so be careful!
Plasti-dip on the other hand will actually protect what it is covering, and peels off when your done leaving your wheels and their finish intact and unharmed. _________________ Link to my build thread- Updated 6-6-07 http://www.thesamba.com/vw/forum/viewtopic.php?t=210613
check my sites to see my work;
http://www.cardomain.com/ride/1564293 (bug)
http://www.cardomain.com/ride/448794 (Vette,Nova,Typhoon) |
MODIFIER Samba Member
Joined: December 09, 2006 Posts: 1560 Location: Summerville SC
Posted: Sun Dec 08, 2013 5:52 am Post subject: |
Ask Pip...... _________________ Happyasshell
USC USMC DAD OORAH!
ASE MASTER TECH BODY/PAINT and MECHANICAL
62 Beetle
63 Vert
64 Beetle
https://www.facebook.com/SmartFarmServices |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1227 Location: Eerie PA
Posted: Thu Dec 12, 2013 7:35 am Post subject: |
I would think that nothing short of faking the funk with paint would work properly. Yes easy off will remove anodized coating and would leave it looking black for a short period of time.
But the problem is that aluminum corrodes differently than magnesium. Magnesium actually corrodes to a hard surface and aluminum corrodes and leaves a soft white powdery surface. Two different looks.
Anodizing aluminum is a chemical process that actually corrodes the surface of aluminum and you just control the color. The reaction leaves a corroded surface that is very hard and seals the aluminum underneath to prevent further corrosion. I guess you could see if any metal coaters in your area do anodizing and try to match a color that would give you the effect your looking for. To do the blotchy look they could possibly leave some of the prep agents on the wheel so the anodizing doesn't come out even.
Just a thought. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
Posted: Sat Dec 14, 2013 5:02 pm Post subject: |
exactly, this is why I suggest faking it with paint dobbed on by hand with a sponge/rag. faux/fake patina with paint. then clear coat over top of it all. |
GeoffP Samba Member
Joined: July 14, 2002 Posts: 400 Location: Blaine WA / Vancouver
Posted: Sat Dec 14, 2013 6:31 pm Post subject: |
I did these 4 plus years ago...
Somics Samba Member
Joined: June 09, 2011 Posts: 3 Location: Birdsboro, PA
Posted: Sun Feb 09, 2014 8:26 pm Post subject: |
GeoffP wrote: |
Ok, I'll bite... What technique did you you use? Cause they look just right to me. |
ento Samba Member
Joined: December 31, 2008 Posts: 180 Location: el paso tx
Posted: Sat Dec 23, 2017 12:33 pm Post subject: Re: The "magnesium treatment"? |
Damm it. This thread ended on a cliffhanger. I was hoping to see how GeoffP achieved the look too _________________ 66 European bug, 66 euro sunroof
76 baja
76 sun bug sunroof
64,66,67,68 bug
69,70 bay
61 Ragtop bug, 61 sedan(looking for the vert)
61 RHD Ragtop Semaphore bug fakeAF
64,64 KG
74 thing
55 oval
70 ratrod
73 fastback pignose |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Sat Dec 23, 2017 10:24 pm Post subject: Re: The "magnesium treatment"? |
If you soak aluminum in purple degreaser it will turn it black through oxidation. Is that what you are wanting? If so, find a sample wheel and try it out first. _________________ www.vwnos.com [email protected]
'64cal lookdub 1200 Deluxe
Posted: Tue Dec 26, 2017 8:41 pm Post subject: Re: The "magnesium treatment"? |
Blast it and paint it with graphite spray, that's how I've seen some hot rod guys fake magnesium halibrands. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Dec 26, 2017 8:50 pm Post subject: Re: The "magnesium treatment"? |
'64cal lookdub wrote: |
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Dec 26, 2017 9:48 pm Post subject: Re: The "magnesium treatment"? |
^ what did I miss here? |
