Max drop with 4.5 steelies 145/56 15's, 2inch beam
webbaldo
webbaldo is offline
PostPosted: Tue Oct 29, 2013 7:43 am    Post subject: Max drop with 4.5 steelies 145/56 15's, 2inch beam Reply with quote
Hi there, ive spent the past 3 hours reading various threads and have an idea but im struggling to find a rough idea.
I have a 1960 bug,
I intend to fit air shocks to the front of my beetle (link pin kind)
I want (don't have yet) steelies 4.5/15s on the front with 145/65 15's
I have a 2 inch narrowed beam adjustable.
Now I want to get as low as possible for shows, and with air ride im not bothered about turning clearance as wheels will be straight/static when slammed using air ride. (In other words I wont be driving/turning when at lowest possible height.)
Therefore, how low can I go with this setup without hitting the fenders? If I fit drop spindles will they stick out too far? I also have discs fitted, 5 stud.
Any help would be brilliant! I currently have 5inch wide wheels with a different offset so Im having trouble visualising a steelie wheel setup.
jhicken
jhicken is offline
PostPosted: Tue Oct 29, 2013 5:01 pm    Post subject: Reply with quote
Maybe this will help with your visualization.
Not sure of the set-up but most likely with at least a 4" beam and widened steelies in the rear.
-jeffrey
Der Kleiner Kampfwagens
Central Jersey Volkswagen Society
