Breather hose connection
frogman_94
frogman_94 is offline
PostPosted: Tue Oct 29, 2013 12:48 pm    Post subject: Breather hose connection Reply with quote
I'm confused. Is there two types of oil bath air cleaners for the Think? The one I have, the breather hose connection goes straight down but I've seen ones that have a 90 degree elbow. I just got the hose from The Thing Shop and it is a straight hose. It would work great if my air cleaner had the 90 degree elbow but it doesn't. So when I attach the hose it gets a kink in it. Do they make a different hose with a 90 degree on one end to account for the air cleaners with the straight down connection?
stl_stadtroller
stl_stadtroller is offline
PostPosted: Tue Oct 29, 2013 2:37 pm    Post subject: Reply with quote
pictures would help, but there are 2 hoses to the air cleaner that could be called "breather hose"
There's a hose to the oil tower, and one that goes to the port on top of the fan shroud.
In some way that I can't recall off the top of my head, parts of this involves the vapor canister / fuel system.
Brian W
St. Louis, MO
'64 SO-33 Hatch Top Westy | '73 Thing | '87 Syncro Westy: Subaru EZ30D powered | 2002 VW Winnebago Vista
View user's profile Send private message Visit poster's website Facebook Twitter Instagram Classifieds Feedback
citroen
citroen is offline
PostPosted: Tue Oct 29, 2013 5:15 pm    Post subject: Reply with quote
here is a picture of brothers engine which is about as close to stock as you can get how does yours compare to this
Wildthings
Wildthings is offline
PostPosted: Tue Oct 29, 2013 9:12 pm    Post subject: Re: Breather hose connection Reply with quote
I just bought a preformed piece of heater hose from my FLAPS to replace my original breather hose with a 90į bend in it. I know that I will have to replace this hose every few years if I don't find one more suitable for use with oil and engine gases.
The one thing you want is for the hose to drain back into the engine. If there is a downward sag in it it will trap oily sludge and will easily clog at which point the resulting back pressure will blow all of your oil out of any and all available orifices in your engine. Believe me this is not a cool happening.
frogman_94
PostPosted: Wed Oct 30, 2013 11:29 am    Post subject: Reply with quote
Here are pictures of the two different breather hose connections. One has the 90 degree elbow and one goes straight down.
Mine is straight down. It looks like the hose will work for either one.
Another question ..... What should the orientation be for the oil filler? Should the breather hose be next to the cap like the picture on the right or below the cap like the picture on the left?
perello
perello is offline
PostPosted: Sat Nov 02, 2013 12:29 pm    Post subject: Reply with quote
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
Wildthings
PostPosted: Sat Nov 02, 2013 1:43 pm    Post subject: Reply with quote
I always position the breather so that it drains back into the engine as well as it can. Don't know what is considered correct though.
citroen
citroen is offline
PostPosted: Sat Nov 02, 2013 1:53 pm    Post subject: Reply with quote
ok this is a picture of a 74 with less that 9000 original miles so this is the way they come from the factory
4118thing
4118thing is offline
PostPosted: Fri Nov 17, 2017 4:59 pm    Post subject: Reply with quote
Iím having trouble getting to the alternator strap, because the oil filler is positioned like this, with the breather neck up. Should it be positioned down, or up and rotated only when needing to get to the strap.
Wildthings
PostPosted: Mon Nov 20, 2017 9:07 pm    Post subject: Reply with quote
Rotate it as needed to get to the strap. I have a tool made up in a few minutes by grinding down the strap from a gate hinge to do this job. Lots of stuff you may have laying around may suffice for a oil filler tool.
