Which hightop version is the best? |
I like version 1 |
1% |
[ 2 ] |
I like version 2 |
13% |
[ 14 ] |
I like version 3 |
39% |
[ 40 ] |
I like version 4 |
24% |
[ 25 ] |
I like version 5 |
0% |
[ 1 ] |
I like version 6 |
18% |
[ 19 ] |
Total Votes : 101 |
3dig Samba Member
Joined: October 20, 2012 Posts: 142 Location: Bellingham, Wa
Posted: Wed May 17, 2017 9:31 am Post subject: Re: Aluminum High top design |
Thank you Pedrokrusher for your kind words! |
3dig Samba Member
Posted: Wed May 17, 2017 9:44 am Post subject: Re: Aluminum High top design |
Team WorldTour wrote: |
Since it would be prohibitively expensive to ship this bad boy to Germany, can I buy a set of schematics instead?
I like the Weinsberg style! |
Lets chat via email and work something out! Ideally, yours would be one of 20 in a container, but I need European orders... |
canasync Samba Member
Posted: Wed May 17, 2017 8:48 pm Post subject: Re: Aluminum High top design |
Could you post some shots head on from the front and rear?
How tall is it from the gutter to the highest point/or how much higher than a westy top? _________________ 1987 Syncro
3 knobs
PumpeDüse TDI (17mm Garret Turbo, bigger injectors, stage 4 malone tune, intercooled)
Cruise Control
Remote Start/locks
Custom Lift
Custom Bumpers with receivers
Coast Mountain Hightop - Comming Soon
1985 2wd Vanagon Pre-runner in the making
soon to be powered by 2.5L Subaru
Custom Lift |
dkoesyncro Samba Member
Posted: Thu May 18, 2017 9:31 am Post subject: Re: Aluminum High top design |
How much higher is this the the WB top?
What's the weight of the top?
I like it, I'm glad you committed and that rear bumper is great! Does the front bolt to the existing uni-bumper? With storage that might be a long front, sacrificing approach angles?
Keep it up👊 |
3dig Samba Member
Posted: Thu May 18, 2017 11:31 am Post subject: Re: Aluminum High top design |
dkoesyncro wrote: |
Keep it up👊 |
Weight of the top, aluminum only, is 165lbs
gutter to top of top is @ 24"
As for the front bumper, I have yet to remove the original to see what Im up against. Your right on the storage vs the uni bumper. Storage may be limited.
Remember, the height of the top is subject to customer needs. It just so happened a customer and my self are both 6'-2", hence the finished height. |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Thu May 18, 2017 11:36 am Post subject: Re: Aluminum High top design |
3dig wrote: |
Weight of the top, aluminum only, is 165lbs.... |
Any idea what a fiberglass Weinsberg weighs?
Beuler?
Beuler?
Beuler? _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 660 Location: Lancaster PA
Posted: Thu May 18, 2017 11:48 am Post subject: Re: Aluminum High top design |
The NAHT weighs 110lbs. The Weinsberg is shorter but it has more interior structure. |
3dig Samba Member
Posted: Thu May 18, 2017 1:22 pm Post subject: Re: Aluminum High top design |
MayorMcCheese wrote: |
Just to clarify, there is aluminium structure on the interior. Perfectly suited to hide 1" insulation, and attach paneling. |
yiucycle Samba Member
Posted: Thu May 18, 2017 1:36 pm Post subject: Re: Aluminum High top design |
Do you have interior pic? also what will be the cost of shipping to california? or you planning to run through a distributor? thanks for the work. _________________ 1980 2.8LV6 Fiero ASI/Riviera Vanagon
"there is no point in being embarrassed of all the stupid shit i done and will continue to do"
3dig Samba Member
Posted: Thu May 18, 2017 2:17 pm Post subject: Re: Aluminum High top design |
yiucycle wrote: |
Do you have interior pic? also what will be the cost of shipping to california? or you planning to run through a distributor? thanks for the work. |
Interior structure is a T shape. Drawing is shown with the minimum structure. Depending on use of the Alumatop™ more structure can be incorporated.
I am getting a quote for shipping to Ca.
I was approached by a well known to Samba distributor much earlier in this process, I need to reconnect.
Thank you, and more to come. |
3dig Samba Member
Posted: Thu May 18, 2017 2:22 pm Post subject: Re: Aluminum High top design |
3dig wrote: |
Beuler?
Beuler?
Beuler? |
Sorry no Idea. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Thu May 18, 2017 4:08 pm Post subject: Re: Aluminum High top design |
Maybe it is just the CAD drawing, but I may suggest that instead of having the 90°corners on the 2nd bulkhead inside cutout you use a small radius on the interior corners. It will resist stress cracking better. ( I think you may already know this!) _________________ This free advice is worth exactly what you paid for it.
3dig Samba Member
Posted: Thu May 18, 2017 6:24 pm Post subject: Re: Aluminum High top design |
The cutouts on the bulkheads are TBD ATM I need to source a flush hatch on the forward one, and a cutout in the aft one big enough for the hatch to make the fwd dry storage accessible when the top is down. Good point tho I use radius corners throughout. I've built over 400 aluminum boats, and have seen what stresses do to sharp corners. |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Fri May 19, 2017 7:19 am Post subject: Re: Aluminum High top design |
Fantastic work. It wouldnt take much to talk me into hauling these from our area to sunny California, especially in the winter.
Neil2 |
3dig Samba Member
Posted: Sat May 20, 2017 11:25 am Post subject: Re: Aluminum High top design |
Playing around with this idea...Clam style tent option:
jimf909 Samba Member
Posted: Sat May 20, 2017 7:04 pm Post subject: Re: Aluminum High top design |
^^^ That's a nifty guesthouse! It's not something that would work for my needs but if one has a kid or two that'd be a nice place to set them up. _________________ - Jim
Abscate wrote: |
3dig Samba Member
Posted: Tue May 23, 2017 11:54 am Post subject: Re: Aluminum High top design |
Finally, got a website up. Still setting up the pricing page..
www.mtbakermetal.com
Thank you! |
scottz Samba Member
Joined: April 13, 2008 Posts: 477 Location: Bellingham, WA
Posted: Tue May 23, 2017 12:26 pm Post subject: Re: Aluminum High top design |
3dig, your tops look great!
Where in Bellingham is your shop located? |
3dig Samba Member
Posted: Tue May 23, 2017 1:27 pm Post subject: Re: Aluminum High top design |
Shop is on C street first set of building on your left.
give me a text so I can meet you at the perimeter fence.
Cheers! |
Red Beard Samba Member
Joined: May 09, 2006 Posts: 463 Location: Seattle, WA
Posted: Tue May 23, 2017 2:29 pm Post subject: Re: Aluminum High top design |
Is that bumper aluminum?
EDIT: I see from your website that it is. Awesome to have a lighter weight option with bumper mounted swing aways. I'll be hitting you up for that shortly!
J |
