Revel_stoked Samba Member
Joined: October 21, 2003 Posts: 25 Location: Revelstoke,BC
Posted: Thu Dec 04, 2003 7:21 pm Post subject: fuel tank size 73bus |
Well I'm pretty sure that they are standard 15us gallons(57 liters)cause I thought I was having the worst gas mileage ever,then checked to see how many liters it took to fill at half tank and it only took 15liters.So really it should be reading 3/4.It shows full though when filled.But ya can someone verify that or is it only 10gallon?Thanks Mike _________________ vw_stoked
73'bus |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Thu Dec 04, 2003 8:10 pm Post subject: |
It is a 15.8 U.S. gallon tank. Fuel senders/gauges on this vintage bus have a habit of losing calibration in your favor, i.e. at reserve mark on gauge, you still have a quarter tank. Run a couple of tanks to determine your average fuel mileage. Then fill the tank, multiply your mpg X 8 and drive that distance. Your correct fuel gauge should be at 1/2.
Colin |
Posted: Thu Dec 04, 2003 8:16 pm Post subject: |
Thanks colin,I figured the sender was a little out of whack.I'll do that multiplication to get a better idea of where the 1/2 tank is.Thanks _________________ vw_stoked
73'bus |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Fri Dec 05, 2003 12:09 am Post subject: |
This is picking nits, but the early bay window tank was 15.9 gal and the later one was 14.6 gal. Once in a while the topic comes up wrt how much fuel you can cram into the tank during fillup and it turns out that it depends on which tank you have. I'm not sure which year (72,73,74) the tank changed but the difference in numbers will affect your mileage. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
Posted: Fri Dec 05, 2003 9:05 pm Post subject: |
ratwell wrote: |
This is picking nits, but the early bay window tank was 15.9 gal and the later one was 14.6 gal. Once in a while the topic comes up wrt how much fuel you can cram into the tank during fillup and it turns out that it depends on which tank you have. I'm not sure which year (72,73,74) the tank changed but the difference in numbers will affect your mileage. |
The Bentley Manual suggests that all bays were 15.8 US/13.2 Imperial/60 Litres. I really do not recall any little 14.6 job?
Colin |
Bottomend Grease
Joined: September 20, 2003 Posts: 1500 Location: Smell Aye! via Nude Hamster!
Posted: Fri Dec 05, 2003 10:29 pm Post subject: |
You two fightin' again/... ok, well, anyway... colin, you say to<< Run a couple of tanks to determine your average fuel mileage. >>
but, if you cant run it down to zero, how will you actually know? What your average is?
for example; I put in 12.5 gal at 32,567 mi ( give or take 100,000 miles... ) and now I'm at 32,797. thats 240 miles multiplied eight times I get... 1840. thats either the year of the first successful hot air ballon flight over Paris or i'm getting astronomical fuel economy. 'splain please. |
westy78 Samba Member
Joined: August 20, 2002 Posts: 2005 Location: Portland OR
Posted: Sat Dec 06, 2003 1:16 am Post subject: |
[email protected] wrote: |
ratwell wrote: |
Colin |
The Bentley must be wrong. Richard is correct the later bays had the smaller 14.6 gallon tank. I'm not sure when the change was. That is the spec in the back of my owners manual. Its also on page 77 here http://www.type2.com/bartnik/t2manual.htm _________________ Jasan C.
'78 Westy
VW Campmobile, it goes on vacation with you. |
Posted: Sat Dec 06, 2003 3:18 am Post subject: |
Bentley has a few goofs in it that hopefully Stan is correcting for future printings as he receives and verifies the corrections.
There is a 68-71 tank which is 15.9 gal. A 72-mid 73 tank, a mid 73-75 tank and a 74-79 tank for FI. Looking into it closer I believe all 72-79 tanks are 14.6 gal and the various changes during 72-74 have little to do with capacity. _________________ '78 Westfalia CDN
'76 Doublecab
Posted: Sat Dec 06, 2003 7:56 pm Post subject: |
ratwell wrote: |
I have an early 73, (mfg date 12/72) have never run it dry, and the most I ever crammed into it was 15.2 with the gauge well below R.
The things we learn around here. . .
Colin |
Posted: Sat Dec 06, 2003 8:00 pm Post subject: |
Bottomend wrote: |
Okaaaaay. 12.5 into 240 is 19.2 mpg X 8 is 153.6 miles. Soooooo, fill it up, drive 154 miles and you should be at 1/2 tank on your gauge. You get a B for Creative Writing, a C- for comprehension, and a D for Math.
See me after class.
Colin |
Posted: Sat Dec 06, 2003 8:16 pm Post subject: |
Thanks,ratwell,so ya 14.6 gallons 55 liters give or take a little,so my gauge is reading 1/2 tank when it should be 3/4.On my next fillup I'll take the odometer reading and start calculating.Mike _________________ vw_stoked
73'bus |
Bottomend Grease
Posted: Mon Dec 08, 2003 9:21 pm Post subject: |
I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class I will not talk in class I will not talk in class I will not talk in class I will not talk n class |
