Stocknazi Samba Member
Posted: Sat Nov 09, 2013 5:18 pm Post subject: |
indent cargo door; high light 59?
post some pics of the front bumper bracket holes when you get a chance manfred
looks like a solid bus _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
andre b Samba Member
Joined: August 10, 2004 Posts: 806 Location: San Jose C.A.
Posted: Sat Nov 09, 2013 7:23 pm Post subject: |
I would change the topic to standard not kombi..looks like its a standard pgsg under the blue! |
Posted: Sat Nov 09, 2013 7:55 pm Post subject: |
it looks like some beige grey may be fading through; mango std? _________________ WANTED:
Thomas Jefferson |
Posted: Sat Nov 09, 2013 8:01 pm Post subject: |
Look again...the roof is dark green and the nose you can see the sand green |
Posted: Sat Nov 09, 2013 8:03 pm Post subject: |
..its for sure a pgsg. with wrong cargo door |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sat Nov 09, 2013 8:10 pm Post subject: |
andre b wrote: |
I agree that is PG/SG, but the only definitive place I can see the color is in the engine bay. Where are you seeing Palm Green on the roof? _________________ nothing |
Manfred58sc Samba Member
Here are some more pics and a cool story..first its a 59 (maybe a late 58 build however) it has an m-code. I was not able to get a good look at it due to the over paints,crap inside, and the P.O. bolted the doors shut. Clever, he drilled a hole through the lower part of the door and hooked it to the seat bracket. Also it has a mostly complete tan interior so its more than likely a standard..till I run the tag I won't be sure.The tree caused the dent _________________ Fat chick owner/operator |
Posted: Sat Nov 09, 2013 8:12 pm Post subject: |
That looks like sand green to me. I've been wrong before, though. Many times. _________________ nothing |
Posted: Sat Nov 09, 2013 8:15 pm Post subject: |
As you can tell the poor Bus was consigned to shed service and was jammed between 2 sheds,a fence, and the tree (only recently cut down). The racks held pipe for the PO (recently deceased) since 1963!!!!!!!!! That is when it left the road. The son of the PO knew some of its history. _________________ Fat chick owner/operator |
BUCIOBATISTI Samba Member
Joined: April 17, 2002 Posts: 6956 Location: San Diego, California, USA
Posted: Sat Nov 09, 2013 8:17 pm Post subject: |
I'm going with it being a low taillight 1959 L345 Light Grey Kombi. _________________ Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings! |
Posted: Sat Nov 09, 2013 8:23 pm Post subject: |
Well as you can see, the bus was 100% on the ground, no front beam, no transaxle, and no spring plate-torsion bar. luckily the housing were unmolested and rust free. The PO bought this, and backed it into its spot..then proceeded to rob everything for a aftermarket Meyers Manx style buggy. The son had a super old poloriod of it, Very beach looking affair..wouldn't let me get a shot of it though. No deck lid..
Posted: Sat Nov 09, 2013 8:39 pm Post subject: |
BUCIOBATISTI wrote: |
I'm going with it being a low taillight 1959 L345 Light Grey Kombi. |
good eye...damn..the first pic looked like a pgsg for sure.. |
Posted: Sat Nov 09, 2013 8:47 pm Post subject: |
Off the ground now..better get a transaxle in there (Doug, I used the one that was in the Wolf!! hey, it was good for 2K last year should be good for another 100 feet). So far I see some type of darker green on the door jambs.
Posted: Sat Nov 09, 2013 8:57 pm Post subject: |
Once we had the transaxle in we hooked a come-along to a "deadman" fence post and carefully move it away from the tree. I did not have a correct early front beam so we did a "2-bolter" with a 64 beam up front. The PO's son found the pitman arm bolt in the dirt, so..ta-da..we had steering!! _________________ Fat chick owner/operator |
Posted: Sat Nov 09, 2013 8:58 pm Post subject: |
Posted: Sat Nov 09, 2013 9:00 pm Post subject: |
ON YOUR FEET MISTER!!!
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Sat Nov 09, 2013 9:05 pm Post subject: |
drive out?
nice condition though, like it. _________________ regards
Uli
And on to the trailer (homemade job, used to be a boat trailer..walking axles and a tilt bed, perfect for VW's). Total recovery time 3 hrs! Lots for pics Monday, hopefully I will have the m-plate decoded by then.This was 6 miles from my house!
CaLiBus Samba Member
Posted: Sat Nov 09, 2013 10:20 pm Post subject: 58 kombi |
Yup like I ask earlier . It does looked to be light grey. Would be way cool if it turns out to be light grey pressed bumper! Very few floating around. Earliest I've seen was June 58 light grey. |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
