GeorgeO. Samba Member
Joined: October 08, 2010 Posts: 881 Location: Menifee, CA
Posted: Fri Nov 08, 2013 9:31 pm Post subject: Illuminated Side Marker Fix |
Well I found my side marker hanging by the wires so I decided to do a permanent fix. I first got my pem-nut kit and found the insert that best fits the hole where the two plastic hooks fit. 10-24 was the best so I installed the pem-nut and I used two 10-24 stainless steel screws with red loctite to hold the base. I screwed on the covers and they are immovable.
eche_bus Samba Member
Posted: Fri Nov 08, 2013 10:34 pm Post subject: |
That looks like a good, solid fix and maybe something that VW should have done in the first place. Have to admit the original design was cheap, but wouldn't call it robust by any means. |
Posted: Fri Nov 08, 2013 10:46 pm Post subject: |
German Industry was at one time noted for precision and craftsmanship, but I agree. They did not think that one out! Thanks you for your comment. |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Fri Nov 08, 2013 11:19 pm Post subject: |
The problem with having new clean and working rear side marker lights is that eventually a cop will ticket you because your front side marker "lights" don't work! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Fri Nov 08, 2013 11:29 pm Post subject: |
Red Fau Veh wrote: |
The problem with having new clean and working rear side marker lights is that eventually a cop will ticket you because your front side marker "lights" don't work! |
Unless he is Baywindow owner, yeah I guess your right! |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Sat Nov 09, 2013 5:23 am Post subject: |
Or you can simply point out to him that they are only reflectors not actual lights _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Sat Nov 09, 2013 9:13 am Post subject: |
udidwht wrote: |
Or you can simply point out to him that they are only reflectors not actual lights |
That doesn't always work because the cop had a bus back in the 80's and he remembers the front lights worked on his so you must have welded up the hole and pulled the wires out. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sat Nov 09, 2013 9:16 am Post subject: |
udidwht wrote: |
To which he'll say,
"don't get smart boy, they're he same as the back and they're not on, what do you think, I'm stupid? You want another ticket?"
"But officer, the illuminated side reflectors are actually in the turn signal housings with their own dedicated bulbs, honest."
"That's it, you're under arrest." _________________ www.itinerant-air-cooled.com |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Sat Nov 09, 2013 9:43 am Post subject: |
Good fix, I'll have to do that the next time mine falls off.
And yeah .. don't argue with the cop on the side of the road. Accept the ticket, take it to traffic court and have it thrown out when you can demonstrate (preferably with factory literature) that those have always been reflectors not marker lights. You're much less likely to get additional tickets/hauled to jail/vehicle searched/possibly shot that way... |
Posted: Sat Nov 09, 2013 10:11 am Post subject: |
udidwht wrote: |
That doesn't always work because the cop had a bus back in the 80's and he remembers the front lights worked on his so you must have welded up the hole and pulled the wires out. |
The makers on the left & right doors are just that...markers. They didn't come with wired lights. I thought everyone knew that... On a side profile shot of the bus at night the front & left parking/turn lights act as front side markers due to the curvature on the nose of the bus. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
SGKent Samba Member
Posted: Sat Nov 09, 2013 11:10 am Post subject: |
yeah, make those front reflectors marker lights. Then the officer will add, "I just saw a bus last week where those were lit up..." |
Posted: Sat Nov 09, 2013 12:12 pm Post subject: |
The US required cars to have either side reflectors OR lights as of 1968. This changed to requiring side reflectors AND lights in 1970. Its definitely getting to be a long time now since the law changed, and all domestic cars by the late 70s would have had pretty obvious side lights. The late 70s VW bus is somewhat an oddity, having an obvious side reflector down low where a side light would be (most cars combined them), and a small, non-obvious light up where the turn signal is located. You can see where a cop might get a little confused about what's what.
Still, many/most cars nowdays combine the side marker and turn signal assembly, so its ironic that's actually no different from our late bays. If it weren't for the reflector being down on the door, there would be no controversy. Hey, it's a conversation piece! |
HarryFD Samba Member
Joined: February 24, 2012 Posts: 751 Location: Portland, OR
Posted: Sat Nov 09, 2013 1:03 pm Post subject: |
I had a similar issue with my rear side lights.
I went to the my FLAPS and got some of those plastic push-in "thingies" that you use to hold trim in place Selected one that had a head size that fit inside the ring and a shaft that was snug in the hole. I just pushed them in, pressed the housing into the side of the van and I was done.
The part looks similar to this:
_________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4538 Location: Arizona Highways
Posted: Sat Nov 09, 2013 1:23 pm Post subject: |
GeorgeO. wrote: |
I think something not everyone realizes is that after about '65 or so EVERY change that VW made to their products was either to make them cheaper to produce or to make them more sellable in the US market.
Compromises had to be made.
You have to understand vehicle production on the scale that VW was involved in
VW's golden age officially ended when they adopted zip-ties as a fastener _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sat Nov 09, 2013 2:30 pm Post subject: |
borninabus wrote: |
VW's golden age officially ended when they adopted zip-ties as a fastener |
Haha, when did that happen?
And would you go as far to say that IRS in '68/'69 fits that list too? I've never driven a swing axle vehicle, so I can't compare. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
crushie Samba Member
Joined: September 23, 2011 Posts: 878 Location: alberta
Posted: Sat Nov 09, 2013 7:35 pm Post subject: |
I used eche-bus fix for this.
Home depot nylon bolts and nuts. Works great, no rust, and easily removed when necessary and cheap to boot.
These are all great solutions nonetheless. _________________ 1974 VW Combi 1800 Auto. Weber 32/36 |
Posted: Sat Nov 09, 2013 8:36 pm Post subject: |
tootype2crazy wrote: |
Where does one get a pem-nut kit? |
Harbor Freight and the kit comes with the tool and a set of pem-nuts. |
Posted: Tue Nov 12, 2013 8:52 am Post subject: |
That can be alleviated. I will run wires to the marker and hook them up to light switch. Easy. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Tue Nov 12, 2013 10:45 am Post subject: |
Hey GeorgeO, Great idea that I'll need to steal next time I have this problem. Another great place for using what we called "nutserts" at the airline is to hold the splash pan on.
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
